When the cycle ends the door lock remains on, unable to release with the handle
    Problem Solver:
  • 8 Answers
May need to take the face of the washer off so you can see inside and re-align the locking tab qwhich has problem fallen off track, or amybe need to replace the solenoid
Posted on Oct 01, 2010
Whirlpool front loader washer door remains locked
Here is one way: http://www.youtube.com/watch?v=gSF4JS2B_U0&playnext=1&list=PLoRcTDdjR-2afhmUpe11VXBKUReLA8CAa&feature=results_video
Jan 27, 2013 | Whirlpool Washing Machines
Door remains locked after cycle ended
Possible that the safety link lever is not disengaging . The program is not fully completing to release or the lever is stuck within the loading door latch.
you will need to look at releasing by using a scewdriver from below , the oil and set after inspection of the latch.
Aug 24, 2010 | Washing Machines
When the remaining time is one minute but wait for long time but can not open the door
The door locks need to 'cool down' after the end of the cycle. So with one minute remaining you will have to wait for the cycle to finish this minute and a further 2 minuter approx for the door to release. Thats how the machine is designed to work unless there is a seperate door release feature.
If there is you should find the instructuions in the hand book
Cheers
T
Aug 07, 2010 | Washing Machines
Unable to open door
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jul 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
Indesit wd 125. Wash cycle had finished, door lock was off but
Unplug machine, take lid off and locate the door lock. You will have to use a small screwdriver or something to release the lock. Then replace your door handle.
Jan 19, 2010 | Washing Machines
ELectrolux frontloader EWF1090 door wont open
Make sure you drain the machine first by setting a spin cycle manually and see if it releases the door after a few minutes. If that fails then switch off the machine and leave for 5 mins, door should release but you could end up with water on the floor. After this clean your filter and check you water pump, then try a short cycle without clothes.
Apr 11, 2009 | Electrolux Washing Machines
Cycle finished but door won't unlock, please help
normally, front loading machines have this bypass cables in case this things happens, if there is a small opening at the front to acces the drain filter, open it up then look for a small plastic pc with a ring at the end. this is the pull release cable of the door lock. pull it downwards and the door will be released.
if you do not have the small opening to access the drain filter, you can tilt the machine to its back, ( be carefull, its very heavy) then reach for the plastic ring underneath to pull to release the door lock.
tnx 4 using fixya..
drcool
Aug 30, 2008 | Hotpoint WMA40 Front Load Washer
I have an old(over 20 nyears) free standing magic chef model No. 177-31DB2 range. I put it on the cleaning cycle and everything seemed to be working well. But then it seemed like there was alot of smoke so...
WHEN THE DOOR IS LOCKED ON A SELF-CLEANING RANGE, AND THE TEMP GETS ABOVE 400 DEGREES, IT LOCKS THE LATCHING ASSEMBLY SO YOU CAN'T OPEN THE DOOR AND GET SCORCHED. IF YOU FORCED THE HANDLE TO TRY TO OPEN IT, YOU BENT THE ARM OF THE LATCHING ASSEMBLY. IN ORDER TO RELEASE THE LATCH,
ONLY IF YOU FORCED IT TO THE OPEN POSITION, YOU MUST FORCE IT BACK TO THE LOCK POSITION TO STRAIGHTEN THE ARM.THEN IT MIGHT RELEASE.
IF YOUR RANGE HAS A LOCK BUTTON THAT NEEDS TO BE
PRESSED TO SLIDE THE LATCH TO THE LOCK POSITION,
YOU WILL HAVE TO SET ALL CONTROLS BACK INTO THE CLEAN POSITION AND PRESS THE LOCK BUTTON TO RELEASE THE LOCK ON THE LATCH ASSEMBLY. YOU SHOULD HEAR A BUZZING OR HUMMING SOUND WHEN THE BUTTON IS PRESSED.
Mar 31, 2008 | Kitchen Ranges
Water won't heat; door won't open at the end of cycle
I drain water from drum and read out say's open door and you hear door release active but door will not open.
Oct 07, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
