Question about KitchenAid Dishwashers
Our Stainless Kitchenaid dishwasher has water in the bottom and it is not draining correctly. It also leaves a soap residue on dishes.
  • 4,336 Answers
Look for restricted screens and kinked drain hose.
Posted on Oct 01, 2010
I have a kitchenaid dishwasher that doesn't dissolve even liquid soap. At the end of the cycle there is hard compacted soap residue that ends up blocking the holes where the water shoots out and there are...
Try getting some calcium, lime and rust remover. Follow the instructions on the bottle and run the dishwasher empty using only the CLR. Check your incoming water lines for calcium or lime build up.
Sep 17, 2013 | Dishwashers
My kitchenaid dishwasher leaves a white residue on clean dishes. 4 year old appliance, worked great until 6 months ago. under warranty, service repairman said i was using too much soap( am not). he cleaned...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Mar 10, 2011 | KitchenAid 24 in. KUDS01FLBL Built-in...
Top wash arm does not move under water pressure,but moves freely by hand, leaves soap residue on top rack. not clogged and bottom works ok model # fdb750rcc
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
''ll';l;
Aug 19, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Bad soap residue
Poor cleaning on this model is often due to debris in the sump area of the pump that blocks water flow to the spray arms. I have put together some instructions on how to clean this out. Follow the link and let me know if this helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
May 11, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
My dishwasher is leaving residue or soap scum on my dishes...
heatman101
0=0
May 02, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishes on upper tray are left with soap residue
Soap residue would indicate drain not holding,allowing water to seep away prior to end of cycle Check the drain valve for obstruction. (2) check and clean the filter in the fill valve as it could be partially blocked not allowing enough water to enter the machine
Apr 24, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Soap does not disolve and residue left on all
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 17, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher not washing and leaving residue on dishes
We have the same problem with the soap dish. I found that we have to be careful how the dishes are in the bottom rack. Sometimes the dishes will block the cover on the soap dispenser and keep it from opening.
Jul 12, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Not cleaning and leaving soap residue
make sure that your unit is getting enough water. the hose may have gotten pinched some or your pump may be going bad.
Jan 22, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
HElp Dishes not coming clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
98 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
