Question about Nokia N95 Cellular Phone
N95 8gb hi my sim card willnot work in my fone but will in other
    Problem Solver:
  • 11 Answers
Posted on May 26, 2008
  • 139 Answers
Does other sim cards work in yr own phone if yes u need to get i diff sim card if no,
* your sim port may be bad or dirty in a way what u do is use a cleaning brush dipt in spirit or fuel then clean the sime port then leave itr to dry for a while then insert yr sim card it should work other wise u may need to flash it.
thank u.
I have downloaded the f secure to my mobile phone and locked my phone by mistake. now i can't unlock my phone because i don't have the default password.
Had same problem with Nokia N8. I removed SIM card & held on/off button & menu button(bottom right hand corner front of fone) for about 15secs until fone switched off. I then reinserted SIM card, switched on fone, entered my SIM (not F-secure) password & haven't had a problem since ! P.S. I also removed the micro sd card til fone was working correctly so as not to risk losing any data. Hope this helps...
Dec 21, 2010 | F-Secure Anti-virus Client Security...
When i poet my sim card in my fone it says sim registrasion faild pleas help
it means your sim card or phone is blocked or not activated
check with a sim which you know is working from another phone to find out if it is the sim fault or fone fault
Sep 06, 2010 | Cell Phones
My nokia says sim card not valid and off line mode
Try sim on another working fone, if it works, then your fone has a problem. if it doesn't, then your sim is the problem.
Feb 28, 2010 | Nokia 5800 XpressMusic Smartphone
I need assistance my nokia 6270 is showing no network coverage and i cant dial or receive call,no network signal on the phone..
Hi There,
There are two possible reasons why this is not working.
1). The SIM card that you are using is no longer valid in the system of your mobile provider.
2). Your fone is faulty and does not make contact or recognise your SIM card whether or not it is inserted into the fone.
Oct 27, 2009 | Nokia 6270 Cellular Phone
I turned off fone and forgot pin after 3 tries fone locked i have lost puk to unblock vodafone pin9231 fone number 918520365
puk code, personal unlocking key. It is sim card related / specific, if you take the sim card out from the phone, the phone will work with another sim card.
The puk comes up when the pin code has been entered wrong 3 times. To get the puk code for your sim card, you have to call the service provider of that sim card. They are the only ones who can provide you with the right puk code for that sim card.
The puk code may also have came with the documentation of the sim card, if its a prepaid card the puk code comes on the documents or on the box of the product.
if your unable to obtain the puk code, get a new sim card.
also entering the puk code wrong too many times will eventually ruin the sim card forcing you to buy or contact your service provider for a new sim card.
Aug 23, 2009 | Cell Phones
Nokia e65 stuck in offline mode.
step 1>switch off your phone and turn it on again
step2>you should get a respond <: continue in offline mode>: select no
finally, i believe that everything should be ok.
if it doesn't there is alternative 2???/////
ALTERNATIVE TWO: this is useful for those who got INSERT SIM CARD RESPONSE.
my phone is 1yr and 6 months now and i discovered that as you remove and replace your Sim card numerous times, there is a big possibility that Sim card port will get expanded.
SOLUTION is very simple:.>>:1. buy a black solo tape
2. place it at the outer part of the sim card and use blade to cut exactly the same shape as the sim card.
3. finally stick the tape.
WARNING>>?do not stick the tape on where you have the Sim card service sensors.make use of your brain.
Nov 05, 2008 | Nokia e65 Cellular Phone
Nokia n73
Look, your phone don't recognize the card try to put another card, if it won't help clean the place of the sim card with a tooth brush its probably dirt.
Jun 29, 2008 | Nokia N73 Cellular Phone
Sim lock
you need to put back the original sim card in the phone and do a master the phone settings.....
menu/settings/intial setup/master reset - 000000 security default code
Jan 06, 2008 | Nokia 1600 Cellular Phone
Camera says busy, try again later
did you recently dropped your fone? if yes, open up your fone on the display part and try to push back the camera connector module. hope it works. if not theres a problem with the flex cable of your fone
Nov 26, 2007 | Motorola Mobility V265
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
