Question about Optoma MovieTime DV10 Multimedia Projector
When the image is projected on to the screen using my optma LCD projector it is not a full view. the image seems to be cut of.
  • 563 Answers
Hi workcoord
Try switching in the User Menu's Ratio sub section between the different types of ratios your Projector has to offer.
Posted on May 26, 2008
How to project external device through the SONY HDR-PJ240
  • -Open LCD screen
  • -Press the 'View images' button to enter playback mode which looks like > with a square around it
  • - Then use < and > on screen to SELECT the DVD
  • -On this same screen TOP Right Hand corner of the screen you see the format mode. Select the SAME format as the file your trying to play.
Nov 25, 2014 | Sony HDR-PJ240E/B Full HD Handycam...
Words are spelt backwards
Your projector has been set up for rear projection mode (projecting the image from behind a translucent screen. You need to access the setup menus and reorientate it for front projection. Using a mirror to view the image whilst navigating through the menus may help :o)
Mar 27, 2014 | NEC VT465 Multimedia Projector
I have an OPTOMA H27 projector, I am experiencing problems with the quality of the video images displayed. I set the focus by using the internal menu as an image reference. However when I view DVD/Video...
hi,
if u are using the composite video the try component video. composite video will dive u a dull image than component one. also check the distance between the projector an screen.Make sure the projection screen is between the required distance 4.9 to 40.7 feet (1.5 to 12.5 meters) from the projector.
ok
Dec 30, 2010 | Optoma H27 DLP Multimedia Projector
Can't get my Viewsonic projector to project an image AND show image on my laptop screen
Hold the FN+CRT/LCD or (it could be an icon/image of a screen) simultanesouly and then keep press the CRT/LCD key it should eventually get around to displaying an image on just the projector or projector and laptop screen
Jun 08, 2010 | ViewSonic PJ500 Multimedia Projector
I replaced the lamp on a Panasonic PT-LC80U thinking this will solve the yellow appereance, but it did work, it seems that there are not blues in the image. What Can I Do to solve the problem?
here are some probable causes..
This appears to be an older model (over 5 years old) and LCD projectors turn yellow with age. It's just what they do
However, if you are projecting a computer signal or a component signal, a short in the blue signal of the cable can cast yellow hues over your image. The hue will cover the entire image as if you are viewing the image "through rose (or in this case, lemon) colored glasses" so to speak. That's an easy fix.
Harder fixes: the blue LCD panel is weaking and/or gone bad.
If you have a round yellowish spot in the middle of your screen, the diffuser has been overheated and is "burnt".
Apr 08, 2010 | Panasonic PT-LC80U Multimedia Projector
Uncentered image using projector
reset the settings to factory default. is it cut off evenly, or is it uneven and shadowed? if it is the latter and you have a dlp projector, you have a collapsed light tunnel. if it is cut off evenly, go into the settings and make sure the resolution and screen size matches.
Jan 27, 2010 | Sony Office Equipment & Supplies
Laptop screen image is truncated on data projector display (Dell)
Had the same problem, tried a Factory Reset from the menu and it seems to have worked. Don't know what caused in in the first place
Nov 11, 2009 | Dell Office Equipment & Supplies
Nec projector vt 660
could be bad bulb is it setting in right is coler wheel freeley moving
Oct 06, 2008 | NEC VT47 Multimedia Projector
Cut off part of projected image
Hi-
Try changing the cables and try setting the resolution to 800x600 on the computer.
hope this helps
Aug 25, 2008 | Epson EMP-S3 Multimedia Projector
Blue stain on the image projected by my PLV-Z3
I had the exact same problem with my z3, Turnes out it was the blue filter.
I used the full service manual, and managed to fix mine using the diagrams, and troubleshooting section.
You can get the full service manual here.
http://yama.co.za/forum/index.php?topic=147.0
Apr 05, 2008 | Sanyo PLV-Z3 Multimedia Projector
Optoma MovieTime DV10 Multimedia Projector Logo
120 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
