Question about Carrier Heating & Cooling
The inside fan is working but the ourtside unit is not working...
  • 384 Answers
Dear sir
please check first your air con setting its should be on cool mode and temperature 18 degree celcius if its only on fan mode then out door unit will not work secondary try to find any visualy problem in out door unit it can be an electrical short circuit and any wire burn and many more problem.and also any wire remove from its electric source .ot,s up to you to repair by yourself and take help to a technician.
hope answer the question
please vote!
Posted on Oct 01, 2010
AlvinInside unit fan works; outside unit does not come on. Inside unit showed H5 code once. How do I proceed?
H is most likely for heat pump, meaning error 5 on outdoor unit. My guess would be low pressure since your power to the indoor unit most likely comes from the outdoor unit. Check manual for codes or research model number error codes.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 03, 2016 | Fedders Heating & Cooling
2001 Honda Passport/Isuzu Rodeo a/c not getting cold, fan in grill not turning, there is plenty of freon and inside controls/fan working fine. Is there a fuse for the other fan?
Yes there is a fuse for the other fan, generally inside the engine bay as apposed to inside the vehicle. I would think it is more likely to be the clutch on your compressor unit that is not engaging when you press the AC button. In this case the fuse on the AC button is responsible and this is also found inside the engine bay. Check either of these fuses and you should get the AC working. If not then there may be insufficient pressure in your AC system or your compressor unit needs changing out.
Mar 13, 2013 | 2001 Isuzu Rodeo
External Compressor is working but unit inside not working. Sharp airconditioner. Filters cleaned.
Check the circuit breakers for the indoor fan. If you have power to the fan then you might have a bad capacitor or bad fan motor. Make the power is off and see if the fan rotates freely by hand. You can use a multimeter to check the capacitor and the fan motor. If it is not any of these you can look at the fan relay to see if it is working.
Apr 30, 2010 | Sharp Heating & Cooling
Can i run the fan on my inside unit if the outside unit is not working
You should be able to run the fan on the inside unit if the outside one isn't working. If you're worried, turn off the circuit breaker for the outside unit. If you don't know why the outside unit isn't working, check the circuit breaker at the breaker panel, check the breaker inside the box that electrically connects to the outside unit, and check the outside unit for a reset button.
Oct 15, 2009 | Heating & Cooling
Outside unit kicks on but inside fan sometime works and sometimes won't and i have replaced thermostat to get to work i have to turn the fan to on and back to auto several times and finally the fan inside...
Goodman air handlers (inside unit) fan have a delay timer that turn on the fan ,sometimes up to 3 minutes after the outside unit is on,this makes the a/c more efficiency.
Sep 19, 2009 | Goodman CKL36AR36 Air Conditioner
The kneading paddle won't turn and something internally seems to
http://www.fixya.com/support/p101012-toastmaster_1183n_bread_maker
Sep 11, 2009 | Toastmaster 1183N Bread Maker
A/c fan not working=thermostat is working(central a/c system)a/c
The fan on the outside unit is powered from it's 240 volt source. Check that the breaker for the outside unit is not tripped. Also, a contactor is inside the outer unit that starts the fan - it may be faulty.
Jul 26, 2008 | Friedrich QuietMaster Electronic SS12J30D...
Heating & Cooling Logo
20 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
