Question about Linksys Wireless-G Range Expander (WRE54G)
Range expander how to reset my range expander? i always have reset it.
  • xcatlkd Dec 17, 2008
    I know how to reset (clearly marked on side of expander) but I would like to know how to fix the problem of having to reset it, almost daily! It is getting somewhat frustrating. There are many devices on the network (3 that access through the WRE54G, others through the main router) could this be causing these problems??
  • Chris Lower
    Chris Lower May 11, 2010
    Do you need to know how to reset it or why you have to reset it? Thanks
  • 611 Answers
Back side reset button is there pull out the power cable and put in on that time u have press the reset button on same time. eithere you go the page of linksys configuration there one opiton is there reset or the default settings.
Posted on Jun 03, 2008
Dear I did everything mentioned above but still light is red
Hi Friend, In this case I would recommend you to please reset the range expander once again and connect the range expander with the ethernet cable once again. Match the settings of the router to the range expander I mean while configuring the range expander, the wireless network name and the wireless key should be same and the channel should be same and the security type should be same.
If it still doesn't work then I would recommend you to please try to change the channel to 1 or 9 or 11
Dec 08, 2010 | Linksys Wireless-G Range Expander (WRE54G)
Tip
Before you start configuring the WRE54G you need to consider the following...
Before you start configuring the WRE54G you need to consider the following factors:
1. Make sure that there are no wireless security enabled on the router like WEP and wireless MAC filtering. If you have them enabled try to disable them first. Check if there is a wireless computer that is currently working on your network.
2. Make sure that the SSID broadcast is enabled.
3. Then Hit the Automatic Configuration button on the WRE54G for about 3-5 secs.
The wireless computer should be connected to the SSID of the Range expander.
The range expander doesn’t have any DHCP server. The IP address that will be assigned to the computer will be 0.0.0.0 or the Auto-configuration IP 169.254.xxx.xxx.
Assign a static IP address on the wireless card. IP address should be 192.168.1.5, Subnet Mask 255.255.255.0, Default gateway 192.168.1.1
To assign static IP address on your machine you follow the steps below:
Windows 9 xs and ME:
Go to Start > Settings > Control Panel > Network > Highlight the TCP/IP of the Wireless LAN card you’re using > Properties
Under IP Address TAB:
Specify an IP address: 192.168.1.5
Subnet Mask: 255.255.255.0
Click the GATEWAY TAB:
Under New Gateway: Enter 192.168.1.1 then click on Add.
Then Hit Ok All the way out… hit yes if it’ll ask you to restart
Windows XP and 2000
Go to Start > Control Panel > Network Connections > Right Click Local Area Network Connection that you are using > Properties > Internet Protocol TCP/IP > Properties > Use the following IP address:
IP Address: 192.168.1.5
Default Gateway: 192.168.1.1
Then click ok all the way out.
Try to ping the Range expander. Go to start and then run type CMD for Win XP/2000, COMMAND for Win ME and below. On the black screen that will pop-up type PING 192.168.1.240 (Default IP address of the Range expander.
If the ping test was successful then you can access the setup page of the Range expander. If not, try to reset the Range expander for 10 seconds and then power cycle it.
To reset the range expander, follow the steps below:
Hold down the reset button for 10 seconds then unplug power while holding down reset...plug it back in after 5 seconds then wait for 10 more seconds before releasing the reset button.
To access the setup page of the expander, Open your Internet Explorer and please go to http://192.168.1.240
If will prompt a username and password box, leave the username blank password is admin.
On the setup screen of the expander, you can set the same exact settings on your router. SSID, Channel, WEP settings should be the same on the router and you need to specify the WLAN MAC Address of your router to the space provided for the WLAN MAC address on the setup page of the Range Expander.
Once you applied the settings, the lights on the expander should be both blue.
You can now set your IP address back to obtain an IP automatically and Obtain DNS address automatically.
Range expander should be working after performing the troubleshooting steps above.
If you have an Ethernet port on the WRE54G, try to connect the range expander directly to your computer with static IP address then ping the WRE54G. Make sure that you are not running any firewall and Internet security in your computer. If you were able to ping the 192.168.1.240 try to access it through the Internet Explorer and configure it from the there. Follow the steps that I gave to you to configure the wireless settings of the range expander.
Make sure that you have checked all the wireless security settings on your router. Make sure that you have those disabled. Try to set static IP address in your computer and try to ping the 192.168.1.240 and see if you can get a reply.
To set static IP follow the steps below:
Windows 9x and ME:
Specify an IP address: 192.168.1.10
Windows XP and 2000
IP Address: 192.168.1.10
Then Hit Ok All the way out.
on Mar 08, 2010 | Computers & Internet
Tip
Configuring WRE54G to a wireless router
Windows XP and 2000
Windows 9x and ME:
Windows XP and 2000
on Feb 07, 2010 | Linksys Wireless-G Range Expander (WRE54G)
Can't login 192.168.1.1 or 192.168.1.240 Above are the gateways of Linksys Range Expander WRE54G but can't login. Please advise.
Leave the router on. Press the reset button in on the back for 30 secs. Then unplug and press in again for 30secs. This will reset all settings to default and 192.168.1.1 will be the router IP. THe range expander needs to be reconfigured with the original disc. This can be found at www.linksys.com The expanders are offten tricky, mine kept changing the 3rd octet to 2. I.E 192.168.2.1 Might test that to see :)
Dec 02, 2010 | Computers & Internet
I have a netgear wireless router with WPA security. and i bought a WRE54G . I cannot configure the expander as you know netgear IP is 192.168.0.1 and lynksys expander is 192.168.1.240. when i open...
Try to reset WRE54G
Resetting the Range Expander to Factory Default
The range expander can be set to factory default by pressing the Reset button of the range expander for 20 seconds.
NOTE: The default IP address of a range expander is 192.168.1.240.
After resetting the range expander to factory default and you're still unable to access the web-based setup page, make sure that your computer's proxy settings are disabled. For instructions, click here. To disable the proxy settings using a Mac computer, click here.
NOTE: If all the steps above failed, try to disable any security software on your computer before accessing the range expander's web-based setup page. Click here to learn how to disable your computer's firewall.
If you are using a Wireless-G Range Expander (WRE54G v2 or v3) and you can't access the web-based setup page, perform the following steps:
Checking Physical Connections
Make sure that the computer is connected to the range expander's LAN or Ethernet Port. If the range expander is properly connected, check the LEDs on the network adapter. For instructions, follow the steps below:
Checking LEDs on the Network Adapter
Make sure that the LED light of the computer's network adapter is lit or blinking. After checking the LEDs on the network adapter, assign the computer a static IP address.
NOTE: If the network adapter's LED is not lit, try using a different cable to further isolate the problem..
Assigning the Computer a Static IP Address
For instructions on how to assign a static IP address on your computer, click here. After assigning a static IP address, check the computer's connectivity to the range expander.
Checking the Computer's Connectivity to the Range Expander
For instructions on how to check the connectivity of your computer to the range expander, click here. If you're still experiencing difficulty accessing the web-based setup page, reset the range expander.
For instructions on how to restore the range expander to factory default, click here.
If you're still having difficulty accessing the web-based setup page, make sure that your browser's proxy settings are disabled.
If you're using a Wireless-G Range Expander (WRE54G v1), you need to do the following:
For instructions on how to assign a static IP address on the computers' wireless network connection, click here.
Connecting Wirelessly to your Range Expander
NOTE: In this example we used WUSB54GS V1.0 (Wireless-G USB Network Adapter).
If you're using a Mac computer, click here for instructions on how to connect to a wireless network using the AirPort card.
Step 1:
Run the Linksys Wireless Network Monitor by double-clicking this icon 3719-001.jpg at the bottom-right corner of your screen.
4146-005.pngStep 2:
Click Site Survey then select the SSID of your wireless range expander and click Connect.
NOTE: The default SSID of the range expander is in this format linksysRxxxxxx.
4146-007.pngChecking the Computer's Connectivity to the Range Expander
NOTE: If you're using Windows 98 or Windows ME, click here.
If you're using a Mac computer, click here.
Windows 2000/XP
Step 1:
Click Start, then click Run.
Step 2:
When the Run window appears, in the Open field type "cmd", then click OK.
3984-003.pngStep 3:
When the MS DOS Prompt appears, type "ping 192.168.1.240" then press [Enter].
Step 4:
See if you're getting 4 replies, Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Nov 08, 2010 | Linksys Wireless-G Range Expander (WRE54G)
Cannot access Wireless-G Range Expander (WRE54G) from my PC using the IP address 192.168.1.240. I have tried to reset the expander multiple times and still not able to access.
If you're connected to the expander then go start-run type "cmd" and hit enter, then in the black box that opens up type "ipconfig" and hit enter, the line that says default gateway will be the IP address of the expander.
Otherwise there should have been a cd with it that has a utility that scans the network looking for it, I know netgear do one but I'm not sure about Linksys. Let me know how you get on.
Oct 29, 2010 | Linksys Wireless-G Range Expander (WRE54G)
I have an Airplus Wireless Range Expander how do I find the IP?
just press and hold the reset button till the lights on the front blink to go back to the factory defults.
factory IP address is 192.168.0.30
type that in your browser address bar after you reset the G710
Nov 05, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
Forgot password for my netgear range expander
Reset it and reconfigure it. You need to know the configuration of your wireless router to make your range expander work again. Can you still connect to the Internet without the range expander?
Sep 12, 2009 | NetGear RangeMax WPN824 Wireless Router...
Can't connect to the internet after range expander set up
Ok, what you need to do is reset your Linksy wireless connector box, hold button for 30sec. After, you need to try to connent it to your phone and or computer. Try to see if you have a connection.
Jan 11, 2009 | Linksys Wireless-G Range Expander (WRE54G)
Ok so I have a wireless adapter and I recently lost the password for it I was wondering if you had anyway to reset it or find it. I know it was just a bunch of letters and numbers nothing I set up.
The password you are referring might be WEP or WPA which assigned by your router. So you need to reset your router not the Wireless adapter. After you reset the router's Network Key (WPA/WEP)
You can reset your Range extender too; Press the Reset button on the back of the Range Expander for about ten seconds. This will reset the unit to its
default settings
Good Luck
Nov 10, 2008 | Linksys Wireless-G Range Expander (WRE54G)
Linksys Wireless-G Range Expander (WRE54G) Logo
573 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
