Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
MY wega 42inch wont turn on...the little green light flashes like five time as if it where to turn on but never does...and then it turns red and flash six times pauses and then again the red light flashes and it keeps flashing red
  • 95 Answers
Six blinks indicates a faulty power supply. often caused by open thermistor located at under lamp assembly or beside it. Or a defective regulator on power supply section.. Check the thermistor and replace if found defective.. Or contact the nearest Sony service center at your area.
Posted on Oct 21, 2010
Red flashing light
  1. Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Jul 17, 2013 | Sony Televison & Video
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Red flashing after tv turn on for KDS-R60XBR1
How many times does the red light flash before it pauses and then starts again? This is important info as it helps to diagnose your problem.
Mar 20, 2013 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Wega kdf50we655 replaced bulb lights flashes green five times then goes red what's the issue?
the 5 blinks is indicating the lamp driver (ballast) has failed. You can get the replacement ballast for your model at the top of the following page
http://tvcircuitboards.com/sony_projection__dlp_circuit_boards
They can also assist with installation information,
Jan 02, 2013 | LG RU-52SZ51D 52" Rear Projection...
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
60 inch sony wega tv
Green flashing is normal. Red flashes are error codes. Count the error flashes.
3x - Lamp cover position or cover detect switch bad.
4x - One or more fans failed RPM test
5x - Lamp power supply/ballast failure
6x - Thermal fuse failed (usually)
Oct 16, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony trinitron wont turn on.
these sets have a flyback problem, the cure is usually replacement.
If you are unable to replace one, then you will require a technition.
Thanks Guy9
Jun 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony WEGA LCD TV Model KFE50A10 wont turn on
It turns out that the number of red lights flashing, relates to a partiuclar error problem. My TV was flashing 4 red lights, pausing , then flashing again etc etc. This particular error meant that one of the five fans within the TV box had stopped funtioning. So the TV has gone to the repairman today. I was advised by an operator at the SONY STYLE CENTRE that such a repair would be considered as a genuine fault and that SONY would pick up the tab. I live in hope
Apr 01, 2008 | Televison & Video
ON/OFF button (red - off and on - green) flashing all the time
it is important to count the number of red flashes, if it is 5 then the lamp ballast board has failed, (part #1-468-798-14) if it is 4 then the optical block fan (# 178706511) is probably to blame, if it is 6 then the thermal fuse has gone bad..(# a1137954a)
Nov 28, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
310 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
