Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Compressor runs, but blower won't. System off, fan switch on, blower won't run. Short red and green on back of thermostat starts compressor. Whatever, blower won't run. Can hear relay click on PCB, but blower won't start.
  • 382 Answers
Dear sir
check pcb board or that cable which one caring electricity till blower check auxiliary relay who is responsible to make active supply for blower it can be faulty you can check by a electrical teaster when your hear sound of active of relay then you check blower electric connection there is electricity or not if there is electricity and blower won,t run it,s mean blower motor /capacitor is faulty if there is no supply for motor blower then it,s mean PCB bord is faulty and it,s need to repair replace.it,s up to you to repair by your self or take help to a technician .
thank you
hope answer the question
please vote!
Posted on Oct 01, 2010
Testimonial: "Thank you for your well thought out answer. I think you are right. Too deep for me. Waiting for AC tech now."
2002 4 ton Bryant air conditioner shuts off, fan still runs but not cooling is problem in the controls in the attic or in the AC unit or both?
With a non heat pump it is a simple 24 volt AC control circuit. In the attic there is a relay that is actuated via the fan control wire directly from the thermostat. On the thermostat there is an auto/man switch that controls the fan. Manual the fan runs all the time. Auto fan turns on and off with the outside compressor.
If the system is not calling for cool and the fan continues to run the fan relay is sticking. common problem. Sometimes after running for several days the relay will stop sticking if not, replace relay.
If the system is calling for cool and the compressor stops I would still expect the fan to run until thermostat tells the A/C to off. Some compressor units include a safety switch or high-pressure cut-out switch A blocked internal valve bad control board or external fan in outside unit defective no air flow in outside unit.
High pressure cut out not good,
Suggest turning temp max cool and observe. If acceptable cool and the compressor runs without interruption all is good, except for the blower in the attic. Safely check relay in attic blower circuit.
Hope this helps.
Jun 28, 2017 | Bryant Heating & Cooling
I installed a run capacitor for my blower motor on my RUUD ac model UGPH10EBRJR. now it runs all the time. I even disconnected my thermostat and it kept running. is it my thermostat? or something else
An open limit switch may make the fan run all the time. Try disconnecting the Green wire @ the furnace...if that does the trick, then either the thermostat fan relay is stuck, or there is a short between the Red & Green wires somewhere in the thermostat wire.
Jan 18, 2015 | Ruud Heating & Cooling
Replaced Thermostat and now Blower Motor will not run
Sounds like a set up issue on the tstat. You say this is a packaged unit, inside the machine you should find where the tstat wires hook up. Typically red is power yellow is compressor orange is reversing valve white is emergency heat green is blower. Put red and green together, test blower. Then red green and yellow, make sure blower works again. If blower runs both ways it's either the tstat wire or tstat itself. Make sure you are landing wires on dedicated heat pump terminals, make sure in settings you are set up for heat pump with back up electric heat and TSTAT CONTROLS THE FAN. Good Luck. Also if there is a switch on the tstat for gas or electric on the back you want electric.
May 12, 2017 | Heating & Cooling
Power up unit and thermostat, circuit board and gas valve smokes. checked transformer and its output is 24vac. this happened after a thunderstorm. blower works manually from furnace but not @ thermostat....
You have a short circuit, which is obviously dangerous. Your blower motor is controlled via a 24VAC control circuit, but is 120VAC. The circuit board and gas valve are probably history, but it needs to be troubleshot to determine the scope of the damage.If you remove T stat you will see several colored wires. The red and green wire when touched together should cause your fan blower to run. If that works when you bypass t stat the t stat is gone. The red to white will open your gas valve on your heater. The red to the yellow or blue will start your AC compressor or condenser fan motor. Be careful with the yellow and blue wires as one is actually a neutral and one goes to the AC contractor on your condenser unit contractor. Hope this helps!
Aug 02, 2011 | Heating & Cooling
Model TWEO36C140A1 blower will come on if I throw the breaker switch...but thermostat doesn't seem to be in sync. Fan will run in "on" position and once blower is running, in auto. ...
If no relay I'm assuming this is an x13 motor. Try swapping speed taps 4 and 5. It's possible the winding is over heating. Tough one to diagnose without being there. With power off take pic of tstat wiring and remove all wires. Be sure to spread wires apart to prevent blowing fuse. Turn power back on. Red and white together should bring on heat and fan. Red green and yellow should bring on fan and compressor. Try this several times each way making sure the blower comes to a complete stop every time. If everything seems to work by bypassing tstat you likely have a bad stat. Provided swapping your speed taps was unsuccessful. Good Luck!!
May 06, 2017 | Heating & Cooling
I have no air conditioning at all. The thermostat was stuck on "wait" to protect the compressor. Once wait was gone it tried to cool again and nothing. Light on furnace is flashing like a heat call and...
remove cover on your stat using a small wire not touching the ends jump red-power to yellow compressor should start red to green fan should come on im assuming the installer used the most common wire configurations these test can also be peformed at the inside the furnace remember 24volts is present sounds like your thermostat is bad easy to determine using the test i mentioned good luck
Aug 20, 2010 | Heating & Cooling
RVP 8000 A/C just experienced slight power surge. Compressor on.
I'm leaning toward sticky relay as well, but if you want to confirm it's not thermostat, remove thermostat from wall, and temporarily disconnect the yellow wire from thermostat (compressor) when/if, it happens again. If compressor stays running, I'd say relay for sure.
Just for future reference , Gray wire from thermostat is low fan, green wire is high fan, yellow is compressor, blue is ground. ( For cooling side) The red is 12 v + to furnace and white is negative to furnace.(heat side)
Jun 10, 2010 | Coleman Mach 15 Air Conditioner
Blower cuts off when compressor comes on. Blower
Try the fan"on/auto"function switch at the thermostat when the compressor is on.Set fan to on.Does blower run?
Mar 19, 2010 | Coleman Heating & Cooling
I have a 4 wire thermostat - Red, White, and 2 Green. I had originally marked each wire by matching with the old wired thermostat. I had some AC work done, today. The tech took off my markings. Now, the...
First make sure he didn't accidentally push the fan button to "on" instead of "automatic". If he did, switch it back to automatic and it will soon go off when the compressor stops running.
If that doesn't do it, and you're certain the red and white are properly wired, then go ahead and switch the greens. But I'd turn the breaker off first.
Sirwriter
May 15, 2009 | Hunter Fan Company 5/1/1 Programmable...
Compressor will not start.
Usually short cycling means that High side pressure is getting to high (due to not working condenser fan, or dirty condenser coil), or low side pressure is getting too low (might have low level of freon or restriction in sealed system). low side would drop dramatically if indoor blower is not running, so if air is not circulating thru evaporator coil, coil will freeze up and low side would be much lower then normal. Here is video how I found issue with package AC not coming on. Thermostat call for cool, but condenser would not come on, indoor blower runs ok.
Nov 02, 2008 | Ruud UAMB Air Conditioner
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
547 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
