Question about Garden
I'm looking for the wiring diagram for a Hickey Sidewinder winch
This is what I found on the sidewinder
Posted on Oct 22, 2010
Is there a free wiring diagram that show what wire to connect my new winch to
Red is POSITIVE.
Connect to + terminal of battery.
Your winch should be equipped with a fuse.
Do not connect to any of your wiring except battery side of solenoid PROVIDED wire is same gauge or bigger (thickness) than winch wire.
Connect Black to frame or negative battery terminal.
Jan 20, 2016 | Suzuki 2009 KingQuad 450 AXi 4X4 Limited
How do i rewire a warn 12v 8000lb winch
There are lots of links on the internet to wiring diagrams; just make sure they match the winch you have
warn 8000 lb winch wiring diagram Google Search
Feb 01, 2015 | Cars & Trucks
What is the wiring diagram for winch remote
Ramsey website shows Badger wiring diagram for solenoid hookup etc but not plug. Shouldn't take a good DIY mech or auto electrician too long to work out which wire goes where especially if they loosen the socket it plugs into which should reveal which wires go to where on the solenoid block. Basically that's all they do, there's a supply side, a ground wire and all the hand control does is switch the supply to the solenoid for forward and reverse. From memory there's only 4 wires? Supply to hand control,1 wire to one sol, 1 wire to other sol, 1 ground wire. Supply could be red, ground is usually black, fwd / rev will be 2 other colours. Look at the socket to see match up?
Jul 20, 2014 | 115101: Ramsey Badger Series Winches
Winch diagram
Trakker are part of Keeper Corp who are part of Hampton Products International. If you trawl the web under Keeper Corp you come up with lots of pages of their winches. They seem to be common extra's on ATV's and boat trailers. Find the nearest service agent and see what the parts setup is like. My guess they are all Chinese / Taiwanese made and there is little chance of parts other than wire and solenoid pack. You may be lucky?
Jul 19, 2014 | KT2500 12 Volt 2,500 lb Utility Winch
I need a winch wiring diagram
The third wire should be the extra ground wire and is usually grounded to the metal body of the device.
Jan 08, 2014 | chicago electric power tools 1500 Lb....
Need a wiring diagram for my superwinch S4000 for my quad
try (860) 928-7787 first you need to make sure a 60 ampere alternator and battery with 440cca capasity are there-this is a min. requirment as far as install call above number i hope this helps a little
Nov 26, 2013 | S4000 Winch: 1440200 Trailer, Towing &...
Electrical diagram for 8000lb champion winch
Winches are out in the worst weather so before I looked at a wiring diagram I would be checking the condition of all the terminals for clean and tight. Next check the charge rate and condition of the battery driving the winch even having a load test done on that battery to see if all the cells are ok as when the solenoid clicks but no more the results are the same as a bad battery in the car.
Jul 22, 2013 | Champion International Champion 8000lb...
Wire diagram for 9' ATV Rocker Winch Handle Bar Mount Remote Control Thu to the winch
Here's the owner's manual - it includes wiring & installation information:
http://mediacdn.shopatron.com/media/mfg/4377/media_document/4398/10991.pdf
If you're looking for information that is not provided in the manual, you should contact Superwinch directly:
In the USA:
Superwinch, Inc.
Winch Drive
Putnam, CT 06260
U.S.A.
Tel: (860) 928-7787
Fax: (860) 963-0811
e-mail: info@superwinch.com
Elsewhere:
Superwinch, Inc.
Unit D, Union Mine Road
Pitts Cleave Ind Est
Tavistock, Devon
PL19 OPW England
Tel: 44 (0) 1822 619222
Fax: 44 (0) 1822 615204
e-mail: sales@superwinch.net
I hope this helps & good luck!
Jan 13, 2012 | Superwinch 1120210 Atv Lt2000 Series Winch
Wiring up super winch
I am wiring a Superwinch 4500 to my Yamaha Rhino.
Problem the two red wires go to the key switch.
Do they just splice into the 12 wire ?
Sep 25, 2009 | Electric Superwinch LP8500 Series Utility...
Garden Logo
305 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
