Question about Singer 7444 Mechanical Sewing Machine
Cant pick up thread from bobbin - Singer 7444 Mechanical Sewing Machine
  • Singer Master
  • 7,365 Answers
Check your needle to see if it's damaged
Check the bobbin to see if it's warped
Check the bobbin to see if it's inserted in the bobbin case correctly
Check the bobbin case to see if it's inserted properly in the machine
Make sure there's no lint or loose thread in the bobbin area
If these suggestions don't work then it could be the timing is off just a little & it needs to be serviced
Posted on Oct 01, 2010
I cant get my bobbin to meet the needle thread
Be sure to install a brand new needle. Check that it is threaded correctly (top and bobbin).
If it still will not pick up the bobbin thread, it may have a timing issue, ie the needle is arriving at the bobbin at the wrong time in order to intercept the bobbin thread. You can search the internet for web sites and videos dealing with sewing machine timing or take it for service.
Oct 26, 2016 | Sewing Machines
My Ruby Viking will not pick up bobbin thread
Install a brand new needle. A bent/damaged needle sometimes will not pick up the bobbin thread.
Verify the machine is threaded correctly.
If it still will not pick up the bobbin thread, most likely it is a needle/hook timing issues. There are many web sites and videos online explaining sewing machine timing. Or take it for service.
Aug 19, 2016 | Sewing Machines
Won't pick up bobbin thread
Did you check the tension? Sometimes when doing lettering or other specialty stitches you would lesson the thread tension which affects the bobbin thread behavior; did you remember to increase it again before switching back to plain sewing? (Though I would still expect it to pick up the bobbin thread... if it's not picking up bobbin thread then I wonder how the loops are being left on the back side of the fabric; it's the tension of the bobbin thread that keeps the top thread from just pulling through. I'm adding this because maybe that's a clue?)
Sep 19, 2017 | Sewing Machines
I cant get upper thread to pick up bobbin thread
Are you holding the end of the top thread whilst trying to pickup the bobbin thread? Put a BRAND NEW needle in - it may look OK, buy the slightest bend will be an issue. Is it the CORRECT needle for you machine? - check your manual. Is the bobbin in the case correctly and feeding out the correct direction? ...... timing may be out Good luck!
Oct 18, 2013 | Sewing Machines
My brother pe150 embroidery machine does not pick up bottom thread and wont sew
try changing the needle
rethread the machine--use every thread guide
make sure the bobbin is not warped
make sure the bobbin is inserted correctly in the case
it's very possible that the timing of the machine is off & the machine would need to be checked at a sewing machine shop
Mar 20, 2012 | Brother Sewing Machines
I cant get my needle to pick up the bobbin thread
You can download a copy of your manual for free on www.singerco.com under customer support if you need to see the correct way to thread your machine. Hope this helps
Oct 01, 2010 | Singer 8280 Mechanical Sewing Machine
Singer 7444 Mechanical Sewing Machine Logo
179 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
