We have just bought a maxi 310 beer cooler and have no instructions and want to put on a lager tap and a strongbow tap? Can you help?
4 Suggested Answers
tborn6
  • 700 Answers
SOURCE: I have a BeverageAire keg
two things to check first at what pressure is the regulator set too? should be i thaink about 4 pounds. also what is the temperature inside of the cooler could the lines be some what frozen?
Posted on Jan 30, 2009
  • 11800 Answers
SOURCE: I'm thinking of purchasing this model wine cooler
Here you can find an exploded parts diagram
http://c.searspartsdirect.com/lis_png/PLDM/50034601-00001.png
As you can see there are no refrigerant lines on the top. What is not represented there are the wires to and from the bulb and the control board - you will need to remove them to have a look where are they going then drill the holes around them. Close to the front , on the left side is probably the safest place: the wiring for the bulb and the compressor goes to the bottom left corner and the wiring to the temperature sensor goes to the right front..
Posted on Jul 26, 2011
  • 488 Answers
SOURCE: BEER COOLER ICE PROBLEM
three possible issues : 1st - it gets too cold (need to adjust thermostat; 2nd - drain line clogged (need to clear it somehow); 3rd - low on freon (might have small leak of gas). Hope thats helps.
Posted on Mar 01, 2015
Top 10 lagers
Martens Damburger Extra Strong Lager (from Belgium) is 12.2 ABV
(rocket fuel...)
Jul 26, 2013 | Wine & Spirits
What temperature should beer be at for drinking?
Each style of beer has a certain guideline for suggested drinking temperatures. Here are a few:
- Wheat beer and pale lager= 45-50F
- Pale ales and amber/dark lagers= 50-55F
- Dark ales, porters, stouts= 55-60F
- Fruit beers= 40-50F
Feb 03, 2013 | Wine & Spirits
Does the type of glass you use for draught beer matter in regards to the style of beer?
According to beer manufacturers, yes. This is especially true for wheat beers. Most wheat beer glasses are specifically designed to tall to help trap yeast sediment at the bottom of the glass so that it does not blend with the rest of the beer while you are drinking it.
What is a pilsner?
Pilsners were originally brewed in the Czech Republic. They are a lager style beer brewed with a lot of hops. If you would like to know more about pilsners please visit the site below.
http://beer.about.com/od/lager/p/PilsnerStyle.htm
In terms of beer, what is a lager?
A lager is a type of beer that is brewed at cool temperatures and creating using bottom fermenting yeasts. The most popular lagers are light in color and are generally highly carbonated.
What is the difference between an ale and a lager?
ale is brewed with ale yeast, lager is brewed with lager yeast.
I have a BeverageAire keg cooler. I just put in a new CO2 cartridge and keg. The beer is not tapping...barely dripping from the tap
Jan 30, 2009 | Refrigerators
First, dont overstock your beer, good circulation is key. Make sure your condenser coils are clean. Find a happy setting with the help of a thermometer to cool between 35 - 42 degrees. To defrost I put big zipl-loc bags of ice on top of beer. Turn temperature all the way up (the compressor will cut off but the fan will keep running) for a few hours. When the ice is thick i put HOT water in a squirt bottle and spray sections in the ice. Play around with that and see if it works. Hopefully you don't have a bad condenser. Good luck!
Jan 31, 2008 | True TD-95-38-LT Beverage Cooler
Danby Beer Keg dispenser fridge.
Draught (or Draft) beer is almost always un-pasteurized and therefore is more fragile. It should be consumed after being "tapped", and is generally truer to the flavors of the ingredients as pasteurization exposes the beer to heat and changes the flavor profile. Always use brewery approved beer line if you want to have foam free fresh tasting beer. Serving it through a plastic tube from the hardware or discount store or the plain vinyl tubing in your beer tap system you will wind up with a foamy, off tasting beer. Real draught beer is not pasteurized. It must be kept refrigerated between 35F. and 44F. A beer will become wild, turn sour and cloudy in a day or two. Below 44F. a keg of draught beer should last 20-30 days before it loses it's fresh brewery taste and aroma. Craft beers (micro brews) tend to have a shorter shelf life and you should contact the brewery for their recommendations. Why does my beer foam up? The 3 most often causes of beer foaming up are: The temperature of the beer keg The balance of the draught beer system pressures The cleanliness of the draught beer system I would suggest that you clean or replace the beer transport tube...
Aug 11, 2007 | Danby DKC645BLS Compact Beverage Cooler
Heating & Cooling Logo
209 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
