Question about Toshiba 1370 Black and White Copier
Hi, On my toshiba 1370 copier, an LED flashing light started flashing on the LED panel on top and it stopped copying. It's red with two stacked circles (one little circle on top of the other) and an up triangle/down triangle next to the two circles. What does this signify? Thanks, Sid Sanders
    Sniper:
  • 66 Answers
This simply means that your copier thinks it is jammed. Look for any bits of paper in the machine. If no paper is found clean any sensors that you see.
Posted on Oct 01, 2010
TOSHIBA 1370 WILL NOT COPY. PUT IN NEW INK CARTRIGE, CLEANED CHARGER a AND b WHATS NEXT?
f white copies appear on your toshiba impression.
replace the corona wires main loading and transfer, do not forget to check the development unit if turevelador is too old replace
Feb 24, 2015 | Toshiba 1370 Black and White Copier
Dell photo 966 streaked copies
Turn off the printer and open its front cover.
Press and hold the "Continue" button. While holding it down, turn the printer on. The power LED light will now start flashing. Once it stops flashing, release the "Continue" button and close the front cover.
Press the "Cancel" button four times in a row.
Press and hold the "Continue" button. The front panel lights will now start flashing. When they stop, release the button.
Turn the printer off and then turn it on again
Mercedes Custom Parts
Jun 06, 2012 | Dell Photo 966 All In One Print Copy Fax
Paper jam indicator
Your back side of your printer might be loose
Apr 16, 2010 | Toshiba 1370 Black and White Copier
Second icon on the right flashing red
This is likely a paper jam error. Have you made sure to remove any paper that may be stuck inside the copier?
Mar 05, 2010 | Toshiba 1370 Black and White Copier
I have a toshiba 1370 copier....the repair wrench is flashing and won't let me continue, how do i get the wrench to stop blinking?
switch on the machine, holding down 0 & 8 buttons, type in 89, press the green button, enter a 0, press green button again to accept the new value. switch off & then just switch back on as normal.
good luck.
Nov 13, 2009 | Toshiba 1370 Black and White Copier
Toshiba 1360
You should be able to retrieve a code for a malfunction by pressing down the clear/stop and 8 keys. then let me know what you get, and we will go from there.
Oct 22, 2007 | Toshiba 1360 Black and White Copier
Red "wrench" indicator always on
Press the clear and the 8 button at the same time . This will give you a error code. I will guess that you have a "C7". If you still want to fix let me know error code.
Oct 25, 2006 | Toshiba 1370 Black and White Copier
Flashes paperjame sign but there is no paper jame!
the problem is same sensor no work in the good way or ther is problem in the fusing unit or ther is problem in the feed unit
Jul 24, 2006 | Toshiba 1370 Black and White Copier
Toshiba 1370 Black and White Copier Logo
221 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
