Volume on surround sound speakers not working. Sound coming out of speakers but volume when turned to maximum is very low. Please help.
  • Anonymous Jun 17, 2008
    I got the same problem here :( the maximum volume i can get is 18 :(
  • hustler6996 Sep 11, 2008
    same here volume works in surround but is very quiet, HELP!
  • 95 Answers
Most receivers you can adjust the different chanel levels. If you refer to the manual on adjusting chanel volumes in surround sound mode.
Posted on May 26, 2008
NR626 - no sound
If none of your speakers gives any sound, perhaps you pressed the mute button on the remote control?
Make sure you have a source selected, that will give sound. Choose a low volume, before switching anything. You can destroy your speakers, when switching on with full volume.
If some speakers work, and only the surround does not work. check if you have surround sound as input. If you only feed 2 channels you can't expect to hear more than 2 channels.
Jul 01, 2014 | Onkyo TX-NR626
Tv's sound is not coming through but the tv's sound test is working
Go into the sound menu and make sure the speakers are set to the TV , or the audio system you are using.
If they are turned on , then reset the systems sound settings to clear any previous settings .
The preset volume may be set too low and you are using your surround systems volume controle?
try turning up the volume on the set manualy... ?
Sep 29, 2011 | Samsung 40IN LCD 1920X1080 30001 400UX2...
I have a yamaha "htr-5630"
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING. The errant switch or control that you eventually find and flip will suddenly release the amp's full power and you'll destroy your speakers. If a signal isn't audible at 1/2 volume, for all intents and purposes it's not there.
Look for a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Mar 07, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
My logitech x240 surround powers on but no sound comes out....what could be the problem??
If you have an extra headset around, plug it into the same place the speakers are plugged into, if it works, your speakers are bad (or check to make sure the power light is on on them and that their volume knob is turned up).
If you still do not get sound, click on your little volume/speaker icon by your clock, then click 'mixer' at the bottom of it (Windows 7 hopefully?). Make sure the different volume controls are turned up because sometimes one low one will affect the entire system.
(If Windows XP, right-click the speaker, then 'Open Volume Control'. Adjust until you hear sound.)
Dec 08, 2010 | Computers & Internet
The volume of my speaker is so low, i cant barely hear it, i cant see anything wrong with it, i checked the AC in, i checked the jack for any short circuit still iget a very low volume out of the speaker...
look on the lower right corner of your screen. there should be a volume icon down there. it looks like a speaker. click that and see if it is set up or down low. if it is low turn it up then it should work. this controls the amount of sound coming out of the sound card on your computer.
Jun 27, 2010 | Creative Labs : Creative Inspire 2900 2.1...
JVC Surround Sound System
The problem on your sub is your speaker is faulty the end of the speaker coil is burnt so at a certain volume it`s makes a short .I hope that would solve your problem:)
Dec 29, 2007 | JVC SP-PW100 Subwoofer
Speakers playing low
open the disc tray and press setup and the speaker volume option will activate and also turn off the night mode for louder sound
Dec 15, 2007 | Philips HTS3440/37 System
FLM 3232 television low volume
I hooked my tv up and there is no sound coming from the tv. I do not have surround sound just the tv. How do I make it work I need volume please
Oct 15, 2007 | Polaroid FLM-3232 Television
The click will be a relay to protect the main amp overloading. In many ways you are driving the amp to hard, unless there is a fault on the main amp which means it can't take the full load that it should handle. One cause of this for example would be a speaker that is either the wrong ohms, or of a lower wattage than what the amp can put out. Or in some cases a faulty speaker, or if the wiring is not good shorts when the speaker shakes when a very loud noise comes from it.
Things to check:
1 That no speaker is lower ohms than the amp.
2 That no speaker is lower in watts (RMS) than the amps total output for that channel it is on. Remember not all surround amps have the same volume on each channel.
It is of course possible to use smaller wattage speakers. But if you have an amp that can output say 200w. Connecting an 80w speaker to it would really limit the amount the volume control could be raised to.
3 Each speaker is working right. Plus all connections are neat with NO possibility of shorting.
If all of these are good then you have a fault on the main power amp. Probably one or more of the output device(s)
May 09, 2017 | JVC SP-PW100 Subwoofer
Harman Kardon Elegant 2.1 speakers problem
'Sounds' like you have overwhelmed the cone and split it or a solder joint has come adrift Don't know about repair or replacement -Check makers website.
May 13, 2007 | Harman Kardon HK695 Computer Speakers
308 people viewed this question
 Grubhead
Grubhead
