Question about Gateway GT5622 PC Desktop
The computer was in use when the display cut out. The monitor is fine and the computer turns on but has no display on the monitor
  • 4,340 Answers
I presume that you tried the monitor on another system to verify function. Try restart after 2 min power down and disconnect and try again, then take another "known good" monitor and try that. If both monitors give no image, video output is suspect. Many motherboards have the video output as part of the board itself, cost prohibitive to replace motherboard.
Sometimes you can plug in a PCI video card and bypass system video.
Posted on Oct 01, 2010
Gateway gt5678 is hooked up, I turn it on, turn on the screen and it says no display then cuts off what else can I. Do
Does the computer appear to be on still? No display would indicate either a loose monitor cable, a bad monitor or a failed video card. If you can borrow another monitor try it on the computer to see if you get the same result.
Nov 11, 2014 | Computers & Internet
Monitor cutting out
Follow steps in sequence:
1. Turn Off Monitor by pressing power button on LCD
2. Shut down computer
3. Unplug power cable from LCD, Once power cable is unplugged from LCD, press and hold down the power button on LCD for 15 seconds
4. Unplug the power cable from the back of Desktop Computer and Hold down the power button on desktop computer for 15 seconds
5. Plug the power cables back into the LCD and Desktop Computer
6. Power on computer and then power on LCD, it should work
Oct 06, 2008 | Samtron Computers & Internet
Last night I cut my computer off and it froze on the shutting down screen so I held down the power button and it cut off. Now when I cut it on the light on the monitor is orange. It's Gateway 817GM. Help?
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Jun 27, 2014 | Computers & Internet
Plug in the monitor and it comes on momentarily but then cuts out to blank screen.I got this given to me and am just trying to see if Ican use it with my hp system thanks.
Hi. If the display goes out after displaying the Power On Self-Test (POS) and the power indicator turns amber, it means that the display resolution of your computer is higher than what SyncMaster 192S can handle.
If you still have the monitor that you were using before, connect that one and change screen resolution to 800x600 and 60 Hertz. Turn off your computer then change monitor/LCD and turn on your computer. You may change screen resolution to optimize display on your SyncMaster 193S.
Let me know if you need help changing screen resolution or if you don't have the original monitor that you were using on your HP.
Aug 18, 2010 | Samsung SyncMaster 193S
No display everything turns on windows loads but no display
We can further isolate the issue by connecting an external monitor to the notebook. If the display is fine with the external monitor, this clearly indicates that the issue is related to the LCD screen. Otherwise, it is due to the some other internal hardware.
You may follow these steps to connect the notebook to an external monitor.
1. Turn Off Computer.
2. Connect the monitor cable from the monitor to the monitor port on
the rear of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
* Switching the display to the external monitor
Press FN + F4 to toggle the display between the Notebook display and
External monitor.
May 14, 2010 | HP Pavilion DV9620US Notebook
When i cut on my monitor it goes out after a few seconds.The power is still on but it goes blank. Also when its on, the whole screen is a pink tint.my video card is fine i have duel monitors.but my wide...
tried self test on monitor unplug the data cable from the tower and turn on the monitor only ans see if the problem persist then u need to change the monitor if it works fine uninstall the video drivers and reinstall it or try onboard display if possible
Aug 17, 2009 | Proview PL19Wb Monitor
Screen goes blank right after power up
Same symptom with mine. Turned out it was NOT the monitor, but the stand-alone power supply. Once the display fully powered on, the supply would cut out, apparently unable to drive current needed. I stole 12V from the computer's power supply and have no problems. Your display is fine.
May 28, 2009 | X2Gen MW22U Monitor
Monitor cuts off
Hi...there,
In power saving mode to preventing futher damaged to the monitor. It's seems you got a busted backlight inverter. Need to replaced a new one or repaired it... Happy Holidays!
Nov 11, 2008 | LG Flatron L1750S 17" LCD Monitor
Going to Sleep Displayed
I turned on my computer and the monitor displayed this message on the screen "going to sleep no input received". I checked the power cord and unplugged it, nothing. No lights are flashing or beeping sounds. The CPU is working just fine, anyone have any idea what to do
Aug 02, 2008 | HP vs19 (Silver) 19" LCD Monitor
Viewsonic VA2012w Wont go into standby with computer.
turns out it may be a heating problem. cut a few extra vent holes in it and seems to be fine.
Sep 08, 2007 | ViewSonic VA2012WB Monitor
Gateway GT5622 PC Desktop Logo
100 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
