Question about Euro-Pro Shark GI490 Iron
I have the Euro Shark Iron G1408Z 10. My steam button starting sticking when I would Iron with it. Then it just stuck, it's down and I can't won't come up. It is making it leak all over the place and I never had this trouble with it before. What can I do to fix this problem?
SOURCE: euro-pro EP1005 iron--iron heats -blower works-but no steam
You may not need a new iron, my wife's iron is doing the same thing. take the top of the ironing board off (you will need a torx t-20 security bit driver), under the tank is a connection that may have rusted out re-connet it and turn the iron on. Once it heats up, check the tank for leaks. The tank may need to be replace as well or try a 5-minute epoxy type glue on the leaks once it has cooled. If the tank leaks you will get not get enlugh pressure building up to get the steam.
Posted on Jan 05, 2010
SOURCE: shark iron-61468-10 steam button stuck on dowm
Pull the button up. You may have to coax it up; I pried it back to the up position with a needle. Grasp it firmly and pull it straight off (it is fitted in place by friction only). Below the button is a stem that operates the valve, gently full it back up with a pair of needle nose pliers (careful - the stem is plastic). Replace the button (align the stem into the hole on the bottom of the button. Cycle the button a few times with water in the reservoir. You should be back in the ironing business now! :) It seems like it sticks when the iron is left unused for a period of time; as if the valve sticks when dry. I'm going to leave water in it this time, although the instruction manual says not to.
Posted on Feb 07, 2010
  • 3 Answers
SOURCE: I need a user manual for my Shark iron Model No.
http://www.sharkclean.com/europro/europro1/manual/GI477-GI477R_REV_0907_NO_PROP_65.pdf
Posted on Feb 18, 2010
  • 104 Answers
SOURCE: How do I register a Shark Steam Iron on line
Follow the link to register you Shark Steam Iron
https://secure.prodregister.com/euro-pro/hhappliance/yqd_1.shtml
Posted on Jun 06, 2010
miket756
  • 2702 Answers
SOURCE: shark iron wont turn on
take it back to were you got it from i think the regulator has just packed up
Posted on Jun 20, 2010
Tip
How to release the stuck steam button in Shark iron-61468-10?
If the steam button is got stuck in the down position in your iron then follow this procedures to release the stuck button:--
1) First of all pull the button up. You may have to coax it up; you can pry it back to the up position with a needle. Grasp it firmly and pull it straight off (it is fitted in place by friction only).
2) Below the button is a stem that operates the valve, gently pull it back up with a pair of needle nose pliers (careful - the stem is made up of plastic material).
3) Then replace the button (align the stem into the hole on the bottom of the button to its exact position. Cycle the button a few times with water in the reservoir. You should be back in the ironing business now! :)
It seems like it sticks when the iron is left unused condition for a period of time; as if the valve gets stuck up when dry. leave water in it this time, although the instruction manual says not to. But leaving the water in it may not let it get dry.
This will help.good luck.
on Feb 28, 2010 | Irons
Shark iron-61468-10 steam button stuck on dowm position.thf cap on the water well not ckose.brought iron on 5-10-09 at walmart.how do I get it fixed?
Nov 17, 2009 | Euro-Pro Shark GI490 Iron
Steam Button Sticks in
vinegar the iron its calcified,it will clean out
Sep 30, 2009 | Euro-Pro Shark Rapido Electronic Iron -...
My shark iron get hot but it will not put out any steam none
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Sep 26, 2009 | Euro-Pro Shark GI490 Iron
Leaks water out all the time. Clothes wet or rust marked.
OMG, how frustrating to be ironing and water shoot out everywhere from this iron....So, to remedy it, I have turned off the steam, use it as a dry iron, and have a spray bottle handy to spray as I iron...love the feel of this iron, but hate the water everywhere...
Sep 02, 2009 | Euro-Pro Shark GI490 Iron
Stopped producing steam
Iron not heating up sufficiently to produce steam. Threw it out!
Jun 24, 2009 | Euro-Pro Shark GI490 Iron
Leeks water sometimes and steam does not always work
I would trash it. New ones are very inexpensive now at Walmart, 10-20 dollars.
Mar 16, 2009 | Euro-Pro Shark GI490 Iron
Euro-Pro Shark GI490 Iron Logo
108 people viewed this question
Top Euro-Pro Irons Experts
Gil Shultz
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
