I bought a Hunter light kit (model 28568) and it came with no instructions. I need to know how to install it in a Hunter ceiling fan (CP9110)?
docjohn174
  • 943 Answers
SOURCE: I have just purchased a
hi thanks for the question the white wire is common the red & black are live join the red & black with a wire nut now you have really 2 wires thanks the appliance doc
Posted on Sep 27, 2008
meBNme
  • 334 Answers
SOURCE: HI, We have a Hunter
you probably have a loose/broken wire.
This sometimes happens where the fans wires are wire nuted to the homes wiring in the junction box.
What exactly do you mena when you say the fan "clicks"?
You hear a click when you pull the switch?
or it makes a continuose clicking noise when you have turned it on, but does not turn?
Posted on Dec 06, 2008
clyde2j2
  • 137 Answers
SOURCE: Light not working-hunter ceiling fan need part number 85112-01?
"Google" ----"replacement parts for ceiling fans"
there are dozens of sites that may be of help.
Posted on Mar 02, 2009
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
SOURCE: light turns on by its self
When this happens, providing it isn't a neighbor playing tricks, on you. It is nearly always the Receiver, front end glitching, and it makes the unit think, it is receiving a signal. You need to replace your controller box, if possible. Try a "Reset" remove power to the Controller, leave off for a bit, reconnect power, if that doesn't clear it, then go with the bad controller. Sometimes it can be interference.
Posted on Apr 03, 2010
Looking for light fixture for hunter ceiling fan model # 25434
I can't find that fan anywhere in my old catalogs. If you have a center plug in the switchcup, you can put almost any light kit on it. If you have two screws on bottom switchcup, you need a hunter light kit.
Aug 13, 2015 | Hunter Dryers
I need a light kit for hunter fan model #23530
  1. Hunter Fan - Accessories
    www.hunterfan.com/Accessories
    Need more control? We have many universal remotes and wall control options for yourfan and light ... Customize your lighting. Add a new light kit or change the lighting hardware on your fan. Complete light kits. Need lighting parts? Glass and ...‎Complete Light Fixtures - ‎Controls - ‎Glass/shades
Jul 09, 2015 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan 22450 no reverse switch manual says there is.
The reverse switch usually is in the lamp housing directly under the motor. With a vaulted ceiling installation, you would need to use a ladder to get access to the switch
Jan 04, 2013 | Hunter 52" Ceiling Fan With Light And...
Instruction for a hunter remote model 27157
this is the hunter technical support--1-888-830-1326 just ask for support. then you should be able to order the instruction manual.
Nov 26, 2011 | Hunter 52" Ceiling Fan With Light And...
I have a Hunter ceiling fan Model 23262-530 which has a minature light fixture base. I need more light. Is there a standard base with higher wattage lights that I can put in this fan Thanks, bill...
Bill, Hunter makes many different light kits that will fit just about all of their fans. You can find them at home centers like Lowe's and Home Depot. Also, I believe that Harbor Breeze Light Kits are interchangeable with the Hunter Light kits. You'll find those there, too.
Hope this helped you. Please let me know. Thanks.
Jun 13, 2011 | Hunter Heating & Cooling
I have removed the light fixture on my hunter vista iron model 20538. It looks like there should be some sort of a cap that goes on the bottom of the switch fixture. do you know how I might locate one?
There is usually a blank cover that comes with tyhe fan when new, but when installing a light kit they usually get trashed ,, Try any bnuilding supply store that stocks the Hunter fans ,, bring the part for the light fixture so you can get the exact size and mounting screw araingement as the old kit .
Aug 15, 2009 | Hunter 20537 / 20538 The Vista Iron...
Check/add oil to a hunter ceiling fan
If you are asking for instructions on checking and possibly adding oil to a Hunter Original fan. Here are instructions:
Check oil level immediately after filling the reservoir. To check oil, bend an ordinary pipe cleaner into a 1/2" long hook and dip it into the oil reservoir.
If oil touches the end of the pipe cleaner, the fan has ample oil. If it does not touch, add SAE 10 non-detergent oil slowly until it touches the pipe cleaner.
-Hunter Original fans rarely/ never need oil unless they were relocated or tipped. ...Or if the fan was improperly installed.
-Hunter sells an oil refill / oil level check kit with good instructions. They also sell a relocation kit that includes the same kit plus all mounting hardware needed.
Good Luck!
Apr 26, 2009 | Hunter 23852 Classic Original Ceiling Fan
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
