Question about Kenmore Refrigerators
The inside lights on my Kenmore, french door, refridgerator will not go off. They actually melted the dome cover and started warming the milk that sits below.
    President:
  • 1,891 Answers
Kenmore / some of these are L G built and there is a recall on this problem. ck with sears . it is a fire problem .. and the unit cannot keep cold properly if light is staying on .. hope this helps mm ..
Posted on Oct 01, 2010
Light parts are over heated and melted. warming up air inside of refrigator.
See if the lights are going out when you shut the door. Push the door switch in to see if light goes out.
Feb 18, 2011 | LG LFX25960ST Stainless Steel French Door...
My GE Fridge is not getting cold
if the freezer is still o.k. then replace the control board located in the lower rear of the unit
Dec 24, 2009 | General Electric Profile PFSF5PJX Bottom...
Our kenmore refrigerator/freezer went warm. We
It could be one of several problems -
1) Failed compressor relay
2) Failed compressor
3) Failed component in the defrost system
4) Bad door gaskets
5) Failed door light switch
Questions to answer -
1) Was the compressor (large black domed item with three tubes (one stubbed) at the bottom back of the frig.) warm or hot?
2) Was the condenser fan running?
3) Was there thick ice buildup inside the louvers of the back wall of the freezer?
4) Was the fan running inside the freezer?
5) Look up my "Tips and Tricks" article on testing your door gaskets.
6) Open the door slightly and look inside as best you can. Is the light on or off? Continue to open the door until you see the light go on to confirm the light switch is working.
Your response will give us an idea where to look to find the problem.
Dec 13, 2009 | Cars & Trucks
Light bulbs staying on and melting plastic
Hi, I've seen quite a few of these unit's either with the "kenmore" badge or the actual maker, LG/Samsung. The problem either lyes in the door switch being faulty, or the relay on the main control board at the back. If your's has reached the point of melting all the interface control, light cover and housing, that's unfortunate. The new light socket's and deflector comes with the rework kit which includes a limit/cut-out bi-metal wired into light assembly to insure it win't re-occur. The bi-metal will shut the light off if it stick's "on". The main board should also be replaced. I'd suggest you consider hiring a pro appliance tech. You may also consider contacting Sears to inquire about any possible warranty. Hope that help's. Please take a second and rate the info provided to you here at fixya. Thank you and good luck. Macmarkus :)
Dec 07, 2009 | Kenmore 77554 / 77543 Bottom Freezer...
Kenmore Elite 795.7724 - Refrigerator Light Stays on
There is a factory update for this problem. You need a new control board and light parts.
Aug 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have Kenmore Elite Trio, kept smelling hot plastic, checked to see if door was left open, but it wasn't the light was actually not turning off. It melted the plastic light part that covers the light...
It appears your door switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question((()))
Jul 14, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
HAVE AN LG FRIDGE MODEL LRFC22750. THE LIGHT
EFFECTIVE FROM(SERIAL NO.) from 704MR***** to 801MR***** Subject Lamp Cover Melting Improvement (LG 3D Basic) / 2nd No. Loc No. Before Change After Change Note K-Code Remark Part No DESC./SPEC. Part No DESC./SPEC. 1 501A 6871JK1011A PCB Assembly,Main /
6871JK1011D PCB Assembly,Main /
WINNER1 DISPENSER ENERGY STAR '08 C 3 Change Relay SPEC. 2 503F 3111JJ1001X Case Assembly,Display /
WINNER1 BASIC BRAND ABQ33905315 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 3 503F ABQ33905304 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 4 409B 6912JK2002C Lamp,Incandescent /
60W 120VAC 0.40A 480LM - WHITE 6912JK2002E Lamp,Incandescent /
C 3 60W to 40W
Jun 12, 2009 | LG 22 Cu. Ft. French Door Refrigerator,...
Amana 8 yr old side-by-side refridgerator/freezer
sound like you said a sealed system problem if compressor is running check the black coil under ref by the fan and see if it is warm if not you have lost freon just trash it then if it is see if fan in freezer is running if so pull back cover in freezer and see if coil starts to freeze if you have a ice block on coil then it is a defrost problem good luck
Dec 04, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
54 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
