Question about Kenneth Cole Watches
September 30 day month need to change date to friday october 1st
    Genius:
  • 1,970 Answers
Mcdevito75 here, Press MODE and see display flashing, presss mode until you get to date, then press set, once done press mode again for steady display.
Posted on Oct 01, 2010
How do I change the month on an MK 5629?
At the end of a month with less than 31 days you must manually advance the date.
Aug 30, 2014 | Watches
I have a TAG Aquaracer Automatic. Should it not compensate automatically for months with only 30 days, such as September, November, April and June? At the end of September, the date changed from 30, to...
Your watch is a mechanical type for which there is no way of making it skip days. I have the same operation on my watch which although it has some electronic circuitry, variable month lengths is not one of the things it can compensate for.
Electronic watches can do this because they have flexible software which can be programmed to "remember" the length of the month.
Oct 04, 2010 | Watches
Pulsar watch, how do you set the day of the week and month?
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
Jul 08, 2010 | Seiko Watches
GB743 CHANGE DATE
mcdevito75 here, Your Bulova watch should have a 2 position crown (winder), carefully lift the crown to it"s first position, this should allow you to change the DAY, once done pull crown out to set the time, keep turning the hans till you get the right DATE (number) now set the correct time and your done.
Jul 01, 2010 | Bulova Watch
How do I change the date on 30-day months without changing the day?
In most cases the winder has 2 positions, mcdevito 75 here, pull the stem out very carefully to it's first position, this should allow you to change the DATE (number) by turning the stem eithe toward you or away, once you get the Date, pull the stem out to it"s 2 nd position and turn the hands until you get the correct day. mcdevito 75
May 20, 2010 | Swiss Army Wenger Sportedge Bracelet Watch
How do i adjust the date on my classic watch?? pull the pin and rotate cw or ccw no changes.i have an indigo classic watch. does date need to be adjusted every 30 day months? thanks
You have to adjust the date every February (28 or 29 days), April, June, September and November (each 30 days). Self adjusting calendars are called Perpetual Calendars and this feature is quite expensive, especially in mechanical watches. Your watch has calendar ring with 31 days printed on and the simple calendar mechanism which is changing dates from 1 to 31 inclusive,day after day, so, when the 30-day month is ending and there is no 31st date to follow, your calendar is showing 31st anyway,instead of 1st of the next month. This is when you have to adjust date. Now about the date adjusting. If you pull out crown gently, you will notice there are two clicks (positions), not just one. So the first click, when crown is not pulled out fully, is exactly for day/date adjustment. If you pull the crown further out, watch is in hand adjustment mode. Try it carefully and you will find out the right position.
Rate me, please.
Jan 12, 2010 | Timex 5B841 Wristwatch
Can't set the date or the day
the date was on the31st of in a 30 day month, I advanced the hands of the watch till it advanced the day to the 1st of next month it usually advances to the next day about 1:00 am, and date both the date and the day will advance together
Sep 30, 2009 | Bulova Watch
Changing date...
When your winding the month over prop it so that its not quite all the way turned around or just turned around this works for me. Hope it works.
May 06, 2009 | Seiko SKA245 Wrist Watch
Setting the date on my rolex president day/date watch
if all else fales, you are probably in need of a service.
Jan 01, 2009 | Rolex Day-Date President 118238 Wristwatch
Watches Logo
Top Kenneth Cole Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
