Question about Sanyo Vizon LCD-15A2 Television
How to auto program a sanyo vizion lcd tv without remote? There are no menu or settings buttons on exterior of the tv.
jerryg50
  • 1667 Answers
SOURCE: lost my remote control
You require the original factory remote to have the menus. The link below is the source of where you can order a remote.
http://us.sanyo.com/entertainment/remotes/
Jerry G.
Posted on May 17, 2008
  • 3 Answers
SOURCE: Sanyo lcd 32" vizion integrated hdtv
I have this tv as well with the same problem. From the research I've done, one of the 16 ccfl's(backlight bulbs) goes bad and they all will not come on then. I have not been able to find a replacement ccfl for this particular tv. The ccfl size if 3mm x 711mm. I have a feeling the scope of this problem is very large with this particular tv and this forum represents the tip of the iceberg. Sanyo unfortunately makes a piece of junk and we have that piece of junk sitting in our homes with no good solution other than to say, dont waste your money on another Sanyo tv.
Posted on Jul 22, 2008
im a tv repair guy in lex, ky in i fixed mine it had the sam problem it was bad inverter board go to www.shopjimmy.com and get it there good people and it will fix it. the backlight will light for a split sec and go back out its the inverter board trust me
Posted on Feb 01, 2009
SOURCE: Can not change channel on my Sanyo LCD TV
I have not solved it but, when I play the dvd player it seems to make everything else work....
Posted on Feb 15, 2009
  • 8457 Answers
SOURCE: Sanyo lcd tv blinking
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Apr 02, 2010
How to access the menu on sanyo dp26648 without remote
You can't without the remote. to buy one go here www.remotes.com or try eBay.
Nov 29, 2016 | Sanyo DP26648 LCD TV
I have a Sanyo Flatscreen, the original remote was lost. Now when I turn on the TV the picture is to big to fit. HOW do I adjust it without the remote?
use the menu button on the side of the tv
that brings up the screen menu
using the channel and volume buttons move around until you find aspect ratio
find the one that fits the screen and press the menu button to save and exit
it could be a pixel setting so find pixel settings while the menu is on the scree and adjust to the correct pixel setting
there are plenty of remotes for tv units on e-bay
all you have to do is select one that is for sanyo led/lcd tv's and read the details to see it it works your model tv
Oct 01, 2016 | Sanyo Televison & Video
Sanyo tv ds25030 how to program chanals 48-96
Your TV must be set in cable mode for channels higher than 69, and your cable provider must allow those channels to be received without a cable box. Menu, Channels, switch air to cable, run auto scan. If it receiving those channels unencrypted, it will find those channels.
Mar 10, 2015 | Sanyo Televison & Video
HOW TO PROGRAM A SANYO DP32649 TV WITHOUT REMOTE OR MENU BUTTON
You may have a manual MENU button on the side of the TV that can give you navigation through the MENU windows on your screen. Check the TV or manual.
Jun 01, 2014 | Sanyo DP26649 26 in. TV
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
Got a Sanyo DS25320 and using a universal remote. The screen is blue and says Video and when I hit menu it only gives me the option of auto/ manual/ game or language, can not get to the other selections....
The tv universal remotes are having very limited options in functions and tv universal remotes are only work correctly are like buttons power on/off volume up/down and channels up/down.Menu button and a Video setting option modes functions setting are another story all together.These two functions Menu button and Video setting modes funtions will not work correctly in any tv universal remotes.Because these Menu and Video setting modes are belong into the internal setting of the tv itself.It will only work correctly with the tv original remote only.Try website like Remotes.com to buy the tv original remote to use.
Sep 15, 2011 | Sanyo AVM-3259S TV
Programming my remote control (which is a dish network remote control) to operate my 42" sanyo LCD
In order to program the remote to a TV set, hold the clear "TV" button in the upper left hand corner four four seconds or until all four of the mode buttons light. Next press in one of the three digit codes below followed by pound (#) Remote codes: 590, 683, 720, 591, 543, 593, 813, 542, 533, 652, 726, 611, 500, 503, 627, 661, 956, 591, 694, 666, 252 After trying each code press the volume and power buttons, if they control your TV set be sure to press the "SAT" button.
Daniel Busa
DISH Network
Customer Service
Aug 28, 2011 | Sanyo 42 in. LCD TV
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
To perform Auto Program again
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Dec 18, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sanyo ds 27510 tv no remote want to setup my tv with an antennea,wont switch from video 2
If it has a MENU button, press it and use the volume up and down to manipulate the choices, press menu again when you get to channel setup. you want AIR if using off air or Cable for cable. Next screen should say start and press menu again, the channels will start to cycle. If htat doesnt do it, you have a new model than the one I just did tonight. OneForall remotes will probably not have the setup button you need to autoprogram. Best bet is to find a Sanyo made universal remote or other Sanyo remote on Ebay as alot of the buttons are proprietary to manufacturer. Some TV's are useless without their own remote if not on a external tuner (cable SAT or digital)
May 13, 2009 | Sanyo DS27510 27" TV
Programming my directv remote to operate this tv, codes dont work
I just programmed mine by using my direct tv remote...
Go to MENU on the direct tv remote
Then highlight HELP & SETTING and press SELECT.
Press SELECT on Remote in the left menu.
Simply follow the onscreen instructions to program your remote. IT IS IMPORTANT TO MAKE SURE YOU HOLD ON AND SEE THE GREEN LIGHT ON THE DIRECT TV REMOTE FLASH TWICE, otherwise it won't work....which is what I think is happening in your case. Good luck.
Apr 22, 2009 | Sanyo DP42848 LCD TV
Televison & Video Logo
654 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
