Question about Lindhaus Activa 30-38 Bagged Upright Vacuum
I have a linhaus activa 30 about a month old will run about 10 minutes and quit then i have to turn off and back on and it works agsin please help
Purchased a Hoover air stick pro.? It was told that it will the the job as a vacuum cleaner but it didn't it kept blocking up every few minutes.
the fact is that it is an air stick and not a full on vacuum cleaner
it is meant to replace a dust mop or broom and is designed for a quick clean
The company has every right to refuse to exchange it simply because you want a better product and you have used it for 12 months
IT runs for 20 minutes on normal vacuum operation and for 6 minutes on high speed or boost program
If you want another vacuum cleaner , sell the one you have on e- bay or gumtree and then get a different unit
Feb 06, 2018 | Hoover Vacuums
Why does lindhause Activa 30 hose on vacuum comes off
My hose comes off as well. It gets 'unscrewed' over time using it. Simply screw it back in counterclockwise...
Sep 01, 2014 | Lindhaus Activa 30-38 Bagged Upright...
My irobot (Roomba)is only working for 10 mins then
It should take about 6 hrs to charge. I had the same problem and reset the charging circuit. 1) Charge it until the green light comes on. 2) Unplug and pull battery out. 3) hold down the power on button 15-30 seconds. 4.) Put the battery back in, plug in the charger (direct - not through the dock) and charge for 72 hrs. Then, run at Max clean until the "I'm dead" tune plays.
May 12, 2010 | iRobot 4150 Roomba Vacuum
Hoover U5780-900 Windtunnel a month 1/2 old just started stopping when it is running and wont turn back on for a few hours why?
The motor has a thermal protection sensor on it. So your motor may be going bad, it is pulling to many amps for some reason, could be a clog somewhere or a bad bearing in the motor.
Feb 21, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
Flair motor shorting out?
There's a thermal cut-off when the unit has overheated. Mine does this quite often and I remedy it by emptying the canister and making sure the filter is clean, especially of lint and things that prevent good air flow.
Jul 07, 2008 | Hoover S2220 Flair Bagless Upright Vacuum
Convertable?
It is a vacuum, you would have to consult where you purchased it, they should know what you add to it.
Mar 16, 2008 | Lindhaus Activa 30-38 Bagged Upright...
Help
I had the same kind of problem with my model 400 today...after starting it and having it go in a circle for 30 seconds or so it would finally run into something and then back up a few inches, turn, then go forward a few inches, then back up a few inches, turn, then go forward a few inches, etc., etc.. I tried cleaning off the four pairs of sensors under the bumper and blowing out various things underneath (by mouth since I didn't have any canned compressed air). It didn't really help. It then occurred to me that I had a leaf blower! I put the Roomba upside down on the grass, put the leaf blower on high, and blew at it from all directions and up close. More dust came out than I thought would. It has been running normally now for the last 45 minutes.
Mar 12, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Lindhaus Activa 30 EOS Version
Check the inlet by the brush roll for a clog, also check your hose for a clog. Usually when there is a clog, it is sensing an overfull bag and will shut down to protect the motor. If there are no clogs, then there could be a problem with the circuit board or motor.
Jan 01, 2008 | Lindhaus Activa 30-38 Bagged Upright...
Lindhaus Activa 30-38 Bagged Upright Vacuum Logo
29 people viewed this question
Top Lindhaus Vacuums Experts
vince
ray gallant
Are you a Lindhaus Vacuum Expert? Answer questions, earn points and help others
