Question about Western Digital (WDXB1200BBRNN) 120 GB Hard Drive
Plug in my external hard drive and nothing happens
  • 8 Answers
SOURCE: SimpleTech hard drive not found by my computer
You might need to initialize the drive.
Right click on “My Computer” or “Computer” on Vista.
Select “Manage”
On the next screen select “Disk Management”
In the lower middle section you should be able to find your drive.
It will show up as Disk 1 or Disk 2….depending on how many drives you have in your computer.
If you click on the area that says Disk # you should get and option to “initialize drive”.
Also to the right it should show the allocation information for the drive. If it says “unallocated” then the drive needs to be partitioned.
Right click on the white box next to the drive listing.
Select the option “New Partition”
This will bring up the partition wizard and you will need to step through this process.
Select a primary partition.
On the next screen accept the maximum size it will provide.
On the next screen you assign a drive letter.
On the next screen you will do the format and accept the default settings.
The formatting will start and will be busy until it is complete.
You can monitor this from the disk management window.
Posted on Jun 05, 2008
likwidstate
  • 17 Answers
SOURCE: External hard drive
Try these steps: - Right-click on "My Computer" - Click "Manage" - Click on the "Disk Management" icon in the left column (Under the "Storage" category" - If your disk appears on the right-hand side, then try to right-click on it and create a partition. The issue may just be that, since the disk is not partitioned/formatted, a drive letter has not been assigned, which would cause it to not show up in the "My Computer" list Good luck!
Posted on Oct 07, 2007
cheap to fix
  • 404 Answers
SOURCE: I have a brand new Mac. I plugged in my LaCie
go to applications, utility folder, disk utility
then format the drive in any other way besides
dos.
Posted on Jul 24, 2009
lock123
  • 6831 Answers
SOURCE: how to use hitachi simpletouch external 320gb hard
Hello
If the HHD gets power and you can feel the drive spinning, you can try these steps and see if your problem is solved. Go to:
control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your drive in the schematic below. Right click on it and choose the option to change drive letter or paths. Now just assign a new drive letter to the drive, restart your computer and it should work fine.
If you cannot see any power light flickering or feel movement on the drive when you power it up, then there is a other problem. Hope this can help you.
Best regards
Andrea
Posted on Nov 03, 2009
reggierippin
SOURCE: how do I use my simpletech external hard drive. I
I have a 500GB and a 1TB. Both drives if they work at all, is because you have to apply the power after usb is connected. The 500MB still good but the 1TB took a big dump.
Posted on Jan 01, 2010
I cannot put files on my external hard drive
just plug your hard drive in another noze of usb...
if u have loose connection in usb then it will happen. try to copy small size of data
Sep 01, 2012 | Western Digital My Book Essential 1TB...
I plugged the wrong power supply (my laptop) into my Simpletech drive and couldn't figure out why just the power indicator flashed but nothing else happened. When I plugged in the right power supply...
It is worth a try. The circuit board of the SATA to USB interface inside the drive casing is definitely fried, but the drive itself could still be alive & usable.
Jul 12, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Computre not reconizing my my book HDD 1TB usb 2.0 but it does power up but when you try to plug the usb cord in nothing happens on the computre it dont even show up under devicer manager
Try an new USB cord. If nothing happens, then most like scenario is the controller card went out on the case housing the hard drive. Easy way to test is open the case, remove the hard drive and conect it to your pc or take it to a repair shop to hac=ve the hard drive tested. Usually, shops won't chare for this. If hard drive is good, pick you up a new external hard drive case.$20 or less online.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817392032
Nov 30, 2010 | Western Digital My Book Essential 1TB...
How do I use my simpletech external hard drive. I
Dec 31, 2009 | SimpleTech 1TB External USB 2.0 Hard Drive...
Simpletech Signature Mini not recognized
Dear,
Please check this drive with another new cord to connect it with PC.
Regards,
Rakesh Kumar
Network Support Engineer
Apr 01, 2009 | SimpleTech Signature Mini 160GB External...
My external hard drive won't turn on
Ok, this just happened to me, my western digital my book studio external drive was not booting up, i could hear the disk spinning, but it would then cut out and the light on the drive was never turning on. i called Western Digital customer support and found out that the proper way to connect a drive is to plug in the power cable FIRST then the data cable. Also, with the My Book Studio Edition you should never have to press the power button, the drive just turns on when you plug it in. Hope this helps somebody...
Feb 18, 2009 | Western Digital 500GB My Book Pro-External...
RE: my external hardrive
Check cmos to see if usb ports are enabled? If Windos 2000 you need a usb driver disk.
Feb 28, 2008 | Maxtor OneTouch II external hard drive...
Western Digital (WDXB1200BBRNN) 120 GB Hard Drive Logo
1,031 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
