Question about Haier Refrigerators
I have a Haier wine cooler, Model HVFM20A. It recently stopped working. When plugged in, the motor does not start. After a period of time, it arcs near the motor (possibly a thermal cutout??) It's about 5 years old with no prior problems. Any help is appreciated.
SOURCE: haier wine cooler
Hold + and - keys down together until LED blinds (about 4 or 5 seconds), Then press + or - key to lower or raise temp. Once you've reached the desired temp press the set key.
Posted on Mar 18, 2008
SOURCE: HAIER WINE COOLER HVW18bss I
IS THERE A THERMOSTAT YOU CAN JUMP OUT WITH A SMALL PIECE OF WIRE?IF THAT DOES NOT WORK A THINK YOU HAVE A LEAK SOMEWHERE,CHECK ALL THE PIPE CONNECTIONS TO SEE IF YOU SEE ANY OIL,LET ME KNOW-MIKE
Posted on Sep 21, 2008
SOURCE: Haier Wine Cooler won't cycle on and off automatically
Hey all,
For those of you who have problems with one or both or your zones not cooling on the HVTB18DABB or similar wine cooler/cellar, the problem lies the Peltier-style thermoelectric cooling module. The original part is "TEC1-12706" and information on it can be found on google. Finding this or a similar part on ebay can be done by searching for "thermoelectric cooler". If the exact TEC1-12706 part cannot be found, then any similar part that's 40mm x 40mm in size, and 51 to 69 watts should do fine. For $25 I was able to get 3 modules...one to replace the bad zone I had, and then I'll have 2 spares in case the other zone, or this new one, ever go bad again.
To replace the part you must remove the back panel from your Wine cellar. You will see 2 big fans attached to two large heat sinks. (If a heat sink on the back does not feel warm to the touch, the the other side is obviously not cooling, which means that zone is broken.) Remove the screws from the fan and the heat sink of the zone that is not cooling, and while holding the heat sink, pull the whole cooling assembly for that zone out. Dont be alarmed if you feel some insulating foam separating as you pull it out, its a tight fit so that is to be expected. Once you have the cooling assembly out of the fridge, take it apart and you will see the square ceramic cooling module inside. (REMEMBER which way the module was oriented before you remove it, so you know how to put the new one in.) Clip the red and black wires near the module and remove it from the assembly. DON'T wipe away any of the white thermal grease left behind on the heat sinks. If you have any extra thermal grease handy (available at Best Buy, or online at sites like newegg), apply an extra pea-sized dab to both sides of the new module. Put the assembly back together and splice the wires from the new module to the loose wires left behind going into the back of the Wine cellar. Mount everything back in place as before, close up the back, and youre done!
This is really a lot easier to do than it sounds, especially if you're comfortable doing this sort of thing...a few pictures would explain much better if anyone wants to illustrate.
These are actually great units, so I hope this helps somebody fix theirs!
Posted on Sep 24, 2008
  • 85 Answers
SOURCE: Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Posted on Mar 02, 2009
localwonder
  • 6784 Answers
SOURCE: Need user manual for Emerson Wine Cooler FR23RD
HI. i couldn't find the FR23RD but, i have been told that this manual covers your model. It basically covers FR24SL threw FR24RD. Your model is also covered in this edition. Click to review your manual.
Please rate and god bless.
Posted on Mar 22, 2009
MODEL #HAW18ABB
www.haier.com/us/servicesupport/overview
Jun 11, 2014 | Haier HVTS18DABB Wine Cooler
Have a Haier 18-bottle wine cooler. In 3 occasions since I bought it I'v needed to unplug it. Every single time I plug it back it will not work. 1rst & 2nd time, fans stopped working, they sounded...
I don't know. It might just be really old? If you bought it like in 2000-2005, it might just be old. You probebly just need to get a new one. Don't feel bad. :3
Dec 16, 2013 | Haier HVW18BSS Wine Cooler
My Haier Wine Cooler HVFM30A the compressor or motor over heated and stop working. Can I replace it?
A new compressor for that unit from Sears parts direct costs $206.
The unit itself is worth around $233 and is no longer in production.
After you pay someone to replace the compressor you'll have spent way more than it is worth.
Your best bet is to get a new wine cooler.
TickMagnet
Aug 20, 2011 | Haier HVFM30A Wine Cooler
Wine temp on Haier wine cooler BC112G went to LL, opened up and some champagnes frozen, other wines very cold, condensation all over door, how do you fix this error?
The error is likely caused by a bad temperature sensor. The control board may still be Okay.
Replacing both of them is recommended.
Check this link for parts: http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/BC112G.aspx
Dec 31, 2010 | Haier BC112G Wine Cooler
Haier HVTB18DaBB Wine Cooler has stopped working. It was working yesterday and today it isn't.
check if it still has power, if it does check the back of the cooler to see if the fans have stopped running, you might need new fans.
Oct 03, 2010 | Haier HVTS18DABB Wine Cooler
Motor in wine frige is noisy???why
That motor is an evaporator fan motor. That noise occurs when the bushes in the motor start to wear. The motor is not in effect repairable but has to be replaced. Normally a 9 watt evaporator fan motor is installed into those wine coolers.
Aug 31, 2010 | Haier BC112G Wine Cooler
My Haier wine cooler (Model BC112G) has stopped working. Prior to it stopping, the pipes in the lower back became caked with ice. Any ideas what might have broken...and how/if it can be fixed?
let the thing totally defrost (24hrs)with the door open then switch it back on as a first step,the ice on the pipes stops the gas from turning from a liquid to a gas...thats how it cools..
Jun 03, 2010 | Haier BC112G Wine Cooler
We got a Haier 42 wine cooler. The motor doesn't run.
This is something you can not fix yourself. Remember it might cost as much as a new wine cooler to repair. As for free estimate on repait. That way if it cost to much your not out anything. Rus
Jun 17, 2009 | Haier BC112G Wine Cooler
Haier Wine Cooler motor died
Yes, those motors shoudl be pretty standard stock items at any local appliance parts supply house found in the yellow pages.
You might also try lookinmg under "motors and controls" in the yellow pages. If you get it locally like that then you can physically compatre the old one with the new one to make sure it is indeed the same part.
Thats better than an online link with just pictures.
Jan 27, 2009 | Haier BC112G Wine Cooler
Motor never stops.Inside temperature too cold
it has to be the thermostat,solution,replace stat.have the new one ready,as you take out the old one,and its hard to go wrong if you take your time,good,Luck eire!ps. motor won't stop unless stat cuts out!!
Dec 15, 2007 | Haier HVF042 Wine Cooler
Refrigerators Logo
208 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
