Question about Maytag Atlantis MAV6000 Top Load Washer
Spin cycles dont work, everything else works - Maytag Atlantis MAV6000 Top Load Washer
  • mrmoto70 Oct 04, 2010
    The pump is clean and still works on the other cycles. There is no noise coming from the pump itself,but on the spin cycle noise comes from back of the machine. I can't locate the speed control board on the inside bottom of the washer.
    yes it works
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check the water pump. Either the water pump bearing is bad or there are some tiny pieces of debris stuck in the water pump. It is located below the door latch assembly. Remove the front panel and check the drain pump which is attached with hoses. Remove its clamps and clean the drain pump. You can also remove the drain pump by unbolting it from the washer base. If still the issue persists, then check the motor speed control board which is located on inside of the bottom of the washer. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 02, 2010
  • Rylee Smith
    Rylee Smith Oct 04, 2010
    What about the lid switch? Have you checked that...
  • Rylee Smith
    The issue seems to be with spin bearings going bad and should be replaced. Please click on this link to download its repair manual if you want to repair it yourself. Please accept the solution if the issue is resolved or post a comment for further assistance.
The spin mode on my washing machine has stopped working
The is a spin clutch soliniod which gets water on it ,rusts it up over time until it becomes seized.Replace!
Jan 15, 2016 | Washing Machines
Adjitator won't work
if the adjitator and the spin cycles do not work the coupler between the motor and the transmission is at fault
May 23, 2010 | GE WJSR2070B Top Load Washer
When I start my LG WM2101HW washer, the spin light
sounds like a clitch under warrenty would call them out so you dont void warwrnty
Dec 06, 2009 | Washing Machines
I hae a Whirlpool LSR8233EQ1 Top loading washer.
If you can catch it running while in the spin cycle but not spinning ( put a butter knife or screwdriver in the lid switch hole ) and wiggle the timer knob . If it starts spinning during this process , the timer needs replaced . Sometimes though , when a washer does everything BUT spin and you hear the motor running , the transmission is the problem .
Aug 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Spin cycle is not working right,
This is a problem in your transmission. Not Good!
May 18, 2009 | Washing Machines
Operates correctly on all wash,rinse,soak cycles but does no spin
Check the door switch, if it's faulty the spin cycle will not work, but everything else will.
Apr 02, 2009 | Asko W6021 Front Load Washer
Fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Jun 27, 2008 | GE WHRE5260E Top Load Washer
Roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Mar 17, 2008 | Roper RAX4233PQ Top Load Washer
GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Apr 17, 2007 | GE WJSR2070B Top Load Washer
Bosch WFF 1800
There is no draining & this is why your spin does not work. There is only one belt. First siphon out the water from the machine via your front door. Clean out your outlet filter, check the tube from the tub to the filter. Luckily there shouldn't be a block in your outlet pump
Dec 07, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
