Question about Whirlpool GS6NBEXR Side by Side Refrigerator
No frost whirlpool mod ED22MM will qiit cooling on both sides after setting for 30 min will start cooling and freezing
  • 3 Answers
SOURCE: whirlpool side by side ice maker freezes up. can't get ice out of
Can you give more details?
If the ice chute is frosting up, chute door is not sealing, air , with moisture, is getting in and freezing. An ice cube getting trapped by the door will cause this also. Either case, replace door and delay mechanism.
Posted on May 01, 2009
Greg20
  • 149 Answers
SOURCE: My Whirlpool side by side is having issues.
Hmmmm, chunks? Are the doors properly aligned? Closing completely? dispenser chute door closed? if so may have frosted the airway to the refrigerator and blocked it. I would totally defrost it and check again.
Posted on Jun 11, 2009
  • 363 Answers
SOURCE: whirlpool freezer not freezing
The fan speed can be deceptive. That is why this problem is so hard to diagnose, when the fan starts to wear out the motor spins but not with enough force to circulate air thru the freezer and rrefrigerator. If you have the ability to swap out the fan motor then it should only cost you the price of the motor and components. Approx. $125.00 if you have the make and model you can go to appliancefactoryparts.com or appliancefactorypro.com to obtain motor and components, But if you have to get serviceman to replace fan it will cost you an hours labor also.
Posted on Jul 28, 2009
SOURCE: hotpoint refrigerator freezer(top) mod
Hi, fan may have stuck, but you could have a defrost problem, check defrost heater, thermodisc(defrost thermostat) and defrost timer. or excessive moisture, if your days are hot, or if you put hot foods in ref. could result in excessive ice build up. you can manually defrost it, by unpluging ref. for couple of hrs, until all ice melted. then restart. you make get excessive water on floor. be prepared.
Posted on Aug 02, 2009
SOURCE: whirlpool conquest model side-by-side
You need to replace the compressor start relay/overload. It's on the left side of the compressor. You should be able to remove it from the compressor by hand but you may have to use a flat head screwdriver to pop it loose. When you get it off you can shake it and if it rattles inside it's definitely bad. I bought one for my fridge online for $48. Hope this helps.
Posted on Sep 10, 2010
Maytag dual cool
Frost buildup in freezer is an indication that there may be air being drawn into either the fresh food section door seal or the freezer door seal. Your model has a 61005543 Air Damper
That may also be either defective or stuck in the open position due to frost buildup. You are just going to have a look behind the rear wall of freezer to see what is going on. Unplug first before servicing. If you would like me to upload a Service Manual please let me know, John Tripp Appliance 911
Contact Me Here
Mar 09, 2014 | Refrigerators
Whirlpool Mod ET18LKXHWo o Fridge not freezing,
Your defrost timer located inside the control panel is bad OR the defrost thermostat located on a freezer coil is bad.
Get down low and look up at the bottom of the control panel.
You will see a small round hole. Onside the hole is the defrost timer advance knob.
Use a flat blade screwdriver and SLOWLY turh the slotted knod clockwise until the refrigerator clicks off.
Wait a few minutes then open the freezer door and listen for a sizzling sound from the freezer compartment.
If you do hear a sizzling sound that would be the defrost heater melting ice.
If you do not hear a sizzling sound,unplug the refrigerator and remove the rear freezer panel to expose the cooling coil.
Clipped to the coil will be the defrost thermostat. It will need replacing.
If you do hear the sizzling sound the defrost timer will need replacing.
Jul 20, 2010 | Whirlpool Refrigerators
Whirlpool Side by Side: Freezer freezes refrig doesn't cool.
check for a blockage. There is only one cooling section, divided by airflow for freezer / fridge.
Perhaps something sticky is in the vents, or the freezer section has poor airflow, resulting in ice formation.
Unplug the unit for several hours, clean out vents, and make sure freezer section has good airflow from the vents.
Aug 30, 2009 | Whirlpool GS6NBEXR Side by Side...
Refrigerator will not cool . the freezer is freezing but it seems to be building up frost.
You have an auto-defrost issue. Cooling the fridg side comes from the freezer side. If you see frost on the inside back of the freezer side, it's clogging the cooling vent to the fridge side. You need to have the defrost parts replaced. Parts cost less than $50. Installation is around $250.
Jul 13, 2009 | Whirlpool ED2FHEXN Side by Side...
My Whirlpool side by side is having issues. The refrigerator is not cooling although I have set the settings to 5 (coolest). My freezer is over freezing with big chunks of ice every where. What is the...
Jun 11, 2009 | Whirlpool ED2FHEXN Side by Side...
Freezer stoped cooling
Check the relay on the compressor. It sounds like the relay is not kicking on the Compressor like it shorted out. You can check it with a multi meter, it should be 110 volts or more if there is less or if you see a burn mark replace it. They are about 30 dollars at a local appliance shop
Apr 17, 2009 | Whirlpool GD5SHAX Side by Side...
When heat is running the a/c coils freeze over with frost can you tell me the problem
The outdoor coils getting some frost on them is normal. However the system should periodically (every 30-90 mins of run time) go into "defrost" mode. Essentially it reverts back to cooling and shuts off the outdoor fan. This heats the coil outside to melt the frost. You may see some steam at this time also. Again normal. If this is not happening or not happening often enough the coil will ice up. Inside the outdoor unit is the defrost board. There is usually a pin setting for either 30-45-60 or 90 minutes. Make sure you kill the power to the unit before sticking your hands in there. Check to see what setting your is on and lower it one peg. If it's been colder and/or more humid you may need to cycle sooner. Good luck I hope this works for you. Please don't forget to give me a Fixya rating.
Feb 23, 2009 | Heating & Cooling
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
97 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
