Question about Maytag Dishwashers
My maytag is about 2 years old, we recently can't get the residual water after the wash to drain, so there is always water sitting in the bottom of it, it runs, cleans but wont drain all the water. what should i do?
  • 4,349 Answers
WEll, look for restricted screens on all pump intakes, and look for kinked drain hose. Some water MUST remain in the bottom, but usually not enough to see.
Posted on Oct 01, 2010
I have a maytag quiet series 300, dishes dont get clean on top rack and sometimes it doesnt drain. do i need to clean some trap or drain?
Check the screen area around the sump right below the lower spray arm if it is built up with lime deposit then the wash pump is starving for water and cannot pump water to the upper spray arm this would also starve water to the drain pump.
Mar 06, 2014 | Dishwashers
The fabric softner cup will not drain
I don't know the solution to this either. Both my Whirlpool, front load washers: old one (15years old) and new one (2 months), the softner itself is always drained into the wash and residual water is there at the end of each wash.
Dec 20, 2010 | Samsung WF337AAL Front Load Washer
Water on freezer bottom. I have a Maytag refrigerator, side by side, Model MZD2768GEW, seven years old. Recently I have found about 1/3 cup of frozen water on the freezer bottom. It is not comming from...
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 18, 2010 | Maytag Freezers
Water trapped below the barrel
It is normal to have residual water in the drain lines and drain pump following a wash cycle. This is the low point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket, and the washer is properly draining during the wash and rinse cycles, you have nothing to worry about.
If you have any questions, please post back and let me know. I hope this is helpful to you.
Apr 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Foul smell coming from Maytag Quiet Series 300
Hello jscott,
It is typical nowdays for most dishwashers not to drain all water out of the bottom tub (Even where you cant see) due to siphon design and energy efficiency. Try using about a liter of vinegar and throw it on the bottom tub of the dishwasher. Let it run through a full cycle and see how that works. Has worked for me
Sep 07, 2009 | Dishwashers
Washer less than a year old. Top loading. Will
Have you moved recently, or moved the washer for any reason?
Two things can usually cause that.
First, Some part of the drain hose must always be higher than the highest possible water level in the machine. Remember that water flows downhill. If all the hose is lower then the highest possible water level the machine can never fill since water will drain out hose. So, raise the hose higher than the flat top of the washer and try again.
2A, Inserting the drain hose too far into the house drain. or 2B, sealing out ALL air in the drain line by using a hose too tight in the drain pipe or taping the drain pipe tightly with the drain hose in it can both create a vacuum in the drain line which will actually **** out all the water in the tub. This can be tested by pulling the drain all the way out and aiming it into the tub as you try it. Good Luck.
Aug 23, 2009 | Maytag Washing Machines
MACHINE WILL NOT DRAIN COMPLETELY THEREFORE IT SMELLS
No washing machine drains completely , there is always residual water in the hoses and heater sump
If the machine smells do a couple of hot washes with no clothes in but add a good dose of soda crystals dissolved in hot water.
Pour this mix into the drum before you start the wash
Try going back to old fashioned soap powders for a few washes , these contain some bleach and soda which kill of the fats left inside your machine by the normal 40 & 60 degree washes
Jun 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
Water after spin cycle
remember ,,the tub has a balance ring on top..and that filled with water,,,if your getting water at bottom make sure your drain hose is at proper height,,,+theres always water between the pump and the drain hose no unit can drain 100 per,,
Nov 05, 2008 | Kenmore 24902 Top Load Washer
Dishwashers Logo
234 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
