Question about Jacuzzi Home
I have an Echo Series Z145 hot tub. The contoller heater light is blinking red continuously. I believe the way it blinks is a code to the problem. Do you know if it is the heater, hight limit switch, temp probe or thermostat?
  • 18 Answers
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Posted on Jan 05, 2008
hotuna
  • 288 Answers
SOURCE: heater won't come on when temp drops...must reset limit switch every time.
The limit switch is shutting off and you are having to press the re-set button, right? The limit switch, if I am understanding you correctly, is the thermal disc type, may be ok, but what is causing it to shut off? I would first, not put total faith in the serviceman (PG&E maybe) and replace the limit switch. Its only a few bucks,and easy to do. Then if its still the same problem, look into the venting pipe. As it may not be adequate for the heater. Espically if its new. These new wall furnaces are kind of touchy. It may be larger, BTU wise, and the vent pipe may need to be enlarged. If this is a big job, and a bit too impractical, check the vent pipe, make sure its in good conditon, no leaks ect. install a cO2 detector and by-pass the limit switch.
Posted on Jan 07, 2008
BUDDY08
  • 128 Answers
SOURCE: red light blinks after beep
I look all over the net but could't find anything, until i found a site that said they
could show me how to fix any problem with my ps3. At first i was not so
sure about ordering the manual but i did, whats $5 plus i used paypal, but
long story short i fix my ps3, i recomend this site www.gameme.20fr.com
i hope this help you like it help me.
Posted on Mar 15, 2008
SOURCE: Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
Posted on Jun 12, 2008
PartsCenter
  • 125 Answers
SOURCE: Rapid Heat Bath Heater - indicator light on but not heating water
Bathtub heaters will not produce the heat out a the jets like you would feel coming out of a return jet in a swimming pool.
Bathtub heaters will ONLY maintain whatever temperature water you put in there. they only heat 1-2 degrees an hour. that is for a 1500 watt heater. Many heaters today are only 650 watt or perhaps 700 watt.
Posted on Feb 24, 2009
I have a trane xl90 furnace that won't fire up. It runs through cycle and then the red light blinks. Ignitor is good but doesn't get red hot at all know.
look on the wiring diagram on the furnace blower door cover. it,ll show u the fault codes according the amount of blinks u are getting. trhat furnace is self diagnotic. ex2 quuick blink plus one slow blink mean code 21. look up 21 and it might say, igniter, so on so forth
Mar 17, 2016 | Heating & Cooling
Electrical ignitor on Kenmore Hot Water Heater Not Working
The water heater uses a thermocouple to generate a small voltage from the pilot light. This voltage is used to blink the led and allow the main gas jet to turn on. Either your thermocouple or the wiring from it has failed and needs to be replaced, or realigned if perhaps it moved out of position above the pilot light.
Mar 26, 2017 | Rheem 40 Gallon FVR NATGAS Low WATER...
Circuit braker keep popping
Sounds like the heating element has gone out again. Once you reset the circuit breaker and the tub turns on it will start to circulate the water. This usually runs like this for about 2 mins and then the tub will recognize it is cold and send power to the heater. If the element is back at that point it will blow the circuit breaker.
If this circuit breaker pops as soon as you turn it on then you most likely have a bad circuit board.
Rod
www.uspartscenter.com
Jan 30, 2013 | Jacuzzi Home
Sony 50inch tv red light blinking continuously
I will need the model number of your sont because different model numbers have different diagnosis codes.
Aug 02, 2012 | Televison & Video
On a 2001 saturn L series, 2.2 litre automatic. gas gauge doesn't work and the temp light blinks continuously while the temp gauge needle jumps continuously. i've checked the coolant levels,th
For car running hot and overheating issues, I suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Feb 12, 2012 | 2001 Saturn L-Series
TV works fine for about 3 minutes then the picture goes black and the red light on the front of the TV starts blinking. The sound works the entire time. If I shutdown the TV and wait a few minutes and...
The light is blinking a code. The code will be a series of blinks, a pause and the blinks again. Phone Sony service and give them this code. They will be able to advise you as to the problem.
Apr 03, 2010 | Sony KP-53HS30 53" Rear Projection...
Home Logo
336 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
