Question about Canon ImageClass MF6540 Copier
DEFAULT PASSWORD CANON MF6540 - Canon ImageClass MF6540 Copier
How do i get canon imageclass mf 6540 to scan
Such printers with scanners built into them are know as Multi Function Printers. It is possible you have downloaded a 'printer only' or generic printer driver software.
Here are the links to the 3 bits of software you require:
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0100242106EN.htm
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0200155901EN.htm
3 (only for 64 bit windows 8)
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0100114601EN.htm
3 (only 32 bit Windows 8)
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0100114501EN.htm
May 05, 2014 | Canon ImageClass MF6540 Copier
I have a cannon image class MF6540. When I try and print I get an error "out of paper". I have plently of paper. I am able to copy but not print.
I assume you are trying to print from your computer.
The driver for this unit will give you an out of paper message almost any time it won't print for any reason.
If the unit copies, but does not print from your computer, then it is a communication issue. Perhaps uninstall/reinstall the driver?
Mar 24, 2014 | Canon ImageClass MF6540 Copier
Service manual mf6540 canon
hello friend, you can find the canon mf6540 service manual in below link:
Canon imageClass mf6540 service manual:
http://goo.gl/kW6ZF5
thanks
Apr 22, 2012 | Canon ImageClass MF6540 Copier
My Canon MF6540 is only pulling paper about 3/4 of way through when I am trying to scan/copy. There is no paper jam, and I have cleaned the machine. What could be wrong?
Does machine eports some eror like paper jam or similar o e001, ...
Check the paper sensor flapper on fixing unit, or clean all rollers with alcohol or water
Jan 29, 2010 | Canon ImageClass MF6540 Copier
Canon ImageClass MF6540 scans but has error light
use your computer go to command promt and do ping to copier machine ip add, see there is any reply .If there is reply ,your machine is connected to your p.c.then use the printer driver do a test print.
Aug 19, 2009 | Canon ImageClass MF6540 Copier
Canon ImageClass MF6540 Copier Logo
325 people viewed this question
old marine
old marine
