Question about Kitchen Appliances - Others
I can hardly remove or replace a new bulb because the tines(?) won't slip in. is there anything i can do to make it easier?
  • 490 Answers
There is a small tube of electrical lubricant available at the hardware or electrical supply shop, this may help a bit. The pin-type bulbs are a regular pain to swap. Remember you must not handle the bulbs with your fingers as the skin oils cause early blowout.
Farmerbear at FixYa.com
Posted on Oct 02, 2010
Tines
Either clutch is bad or teeth are striped in bottom gear box. remove tines run engine and see if you can feel movment in lower gear box, if yes the gears are gone. If no remove engine to expose clutch.
May 20, 2013 | Ardisam Inc Earthquake Mini Cultivator
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
Removing low beam bulb on 05 subaruoutback
Whether they become damaged in an accident or simply burn out over time, your Subaru Outback's headlights may eventually need to be replaced. Fortunately, once you've purchased the right replacement bulb for your model year, performing the repair yourself is relatively easy. These instructions only apply to Outback models made after 2000.
  1. Undo the clips on the air intake ducts using a screwdriver and remove the duct from the engine compartment (driver's side bulb removal only.)
  2. 2
    Loosen the secured clip on the washer tank with a screwdriver and slide the tank horizontally to allow easier access to the headlight assembly (passenger's side bulb removal only.)
  3. 3
    Turn the bulb cover counterclockwise and remove it from the assembly.
  4. 4
    Disconnect the headlight electrical connector and undo the assembly retaining spring.
  5. 5
    Pull the old bulb directly out of the socket and replace it with the new one. Press the retaining spring back into place and reattach the electrical connector.
  6. 6
    Replace the bulb cover, and then turn on the engine. Test the new headlight to make sure it works before replacing the air intake duct or the washer tank and closing the hood.
    Replacing the High-Beam Bulbs
  1. 1
    Undo the clips on the air intake ducts using a screwdriver and remove the duct from the engine compartment ( drivers side bulb removal only.)
  2. 2
  3. 3
  4. 4
    Turn the headlight bulb counterclockwise and pull it out of the socket.
  5. 5
    Reinstall the new bulb, replace the retaining spring and reconnect the electrical connector.
  6. 6
Sep 14, 2012 | Cars & Trucks
Husqvarna 700DRT won't change gears
hello, you need parts or a whole new trans,and try and not het any more rocks,,
Feb 11, 2012 | Garden
Own an older (1990's) American Yard Products model WER500 Weedeater rear tine rotortiller. The engine runs great but when I engage to til, the tines won't turn. The belt is fine and pulleys turn...
Yes, there are shear pins on the tines and on the wheels. Can you check to see if the belt actually moves when the pulleys turn?
May 13, 2011 | Garden
The oil seal where the tiller attachment fastens to the tiller is leaking how do i remove the seal
IF THIS IS A WALK BEHIND TILLER OR FRONT TINE TILLER. THERE SHOULD BE PINS OR BOLTS HOLDING THE TINES ON THE DRIVE SHAFT REMOVE THESE AND PULL THE TINES OFF THE TILLER. THEY MAY GIVE YOU A HARD TIME GETTING THEM OFF SO DON'T GIVE UP. ONCE YOU GET THE TINES OFF YOU SHOULD SEE THE SEALS YOU CAN POP THE OLD ONES OUT WITH A SCREW DRIVER CLEAN OUT THE SOCKETS WHERE THE NEW SEALS WILL GO REPLACE THE NEW SEALS GENTLY WITH A SMALL HAMMER TAPPING THEM IN EVENLY AND TRY NOT TO BEND THE SEAL
Feb 05, 2011 | Garden
Tines rotate slow when I try to till.
The clutch is non adjustable if the clutch fails you will have drive all the time or it slips. if the tines spin at the same speed with the engine at low and high speed the clutch might be slipping, the common cause for this is the gear box is partly siezed due to no grease being pumped into it, most ppl dont even know about this untill its too late. you have to remove the LH side tines to get to the screw.
Jul 01, 2010 | Honda 25cc 4-cycle Mini Tiller
Can you give me the steps to change the headlight bulb
You might have to jiggle the headlight while doing this, dust and rock particles get wedged in the tracks making it hard to slip out.
Oct 29, 2009 | 2005 Volkswagen New Beetle
Replace tine shaft oil seals - Junior model
on my pony the disc came off when i removed all of my tine shafts. then i pulled the old seals out an drove the new ones in
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Belt seems to be slipping
good evening. I would suggest checking the tine bearings as well alignment. I had (have) a 2003 mtd rear tine which blew the entire bearing box for the second time. The times should have little to no flex when push or pulled. Fortunately, MTD came good for the first rebuild even though my warranty had expired...they covered the parts and labour was all mine. If the tines seem properly working, possibly try out this website to get the 100% correct belt....hope this helps.
http://www.milacalawn.com/parts.asp
Apr 17, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Kitchen Appliances - Others Logo
81 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
