Question about kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower Engine Motor ()
Kawaski 9 HP K series mower engine. When trying to start won't stay running.
  • kawasaki Master
  • 7,482 Answers
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to seat the jet screws.
But before you seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 01, 2010
Why won't my Briggs & Stratton 190 cc engine stay running?
probably a carb problem if it will start but not carry on running, possibly dirt in the float bowl
Jun 10, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
Brand new Briggs & Stratton lawn mower Model 90000 E series won't start.
trry a shot of starting fliud see if it wont start then make sure your getting a spark to
Jun 13, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
May 17, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Won't stay running
Check the gas cap vent. A partial vacuum in the tank will cause these symptoms.
Sep 06, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Won't run and try use starting fluid that engine
did u make sure your jets r set in the carb or are your vacum lines hooked up right.
Jul 06, 2009 | Garden
kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower Engine Motor () Logo
379 people viewed this question
Top kawasaki Garden Experts
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
dannydoesita
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
