I HAVE A CANON PC 745 COPY MACHINE AND IT WONT PRINT IT MAKES A FUNNY SOUND AND THERE IS NO PAPER JAM AS THE LIGHT INDICATES WHERE CAN I TAKE IT IN FOR REPAIR
  • 320 Answers
I would try this first clean the pick wheels with contact cleaner to insure they are gripping the paper if this dont do it. uninstall the unit and reinstall
Posted on Oct 04, 2010
My CanonPC940 won't grab paper and push it through to print-also makes a a loud "grinding" noise. How can I fix this?
Sounds like a tire may have slid off of a wheel. Yes they have wheels. Also paper soaks up water like a sponge always keep your paper in the wrapper it comes in and the top side of the paper is where the seam is. Make sure you put the paper in so that the top side is the side going through the machine. I do how ever believe you have a wheel or gear out of place.
Oct 15, 2015 | Canon Office Equipment & Supplies
Paper jam always.
Helo have you tried to check on the driving gears it but try to call your technician to check on it otherwise you may spoil your printer
Jun 16, 2017 | HP PSC 1610 All-In-One InkJet Printer
I have a Canon PC 980 B&W copier. When I try to print, the "P" (no paper) light comes on, even thoug the paper tray is full.n
YOur problem is likely worn feed rubber. It is an old machine. Has it ever been serviced?
Did this happen after a paper jam?
Try this: UNPLUG the copier Take out the paper tray. Prepare a dry cloth that is dampened with WD 40. Open the door on the right side of the coper. You should see 1 large, gray or black rubber roller. Gently wipe the roller with the WD 40 cloth, slowly turning the roller. It only turns 1 way, towards the exit direction of the paper from the copier.
Let the WD 40 soak in, about 10 minutes. Put the paper tray back in, plug the copier back in and try to make a copy. If it makes a copy, the feed roller needs replaced, If it doesn't make a copy, check the top sheet of paper in the tray. If you see skid marks, you definitely need a feed roller. No, they are not easy to change.
As long as the roller feeds, go for it. When it starts slipping then you'll have to do something about that feed roller.
Jan 24, 2011 | Canon PC-980 Color Copier
My PC 745 comes up with an error code of a paper jam but I cannot find any jammed paper. Any suggestions.
completely remove the paper cassette and look for A SMALL PIECE OF PAPER stuck inside the machine in the paper path. Also use a flashlight to check for tiny bits of paper in the exit section of the machine where the fuser (hot) rollers are.
Dec 16, 2010 | Canon PC-940 Black and White Copier
Copier is Canon PC 720 Copier turns on, but makes
You said you unplugged your copier, did you unplug it for 10 to 15 minutes before plugging it back in, plug it into a differed
outlet that you know works and plug it directly into a wall outlet instead of a power strip. Check to see if your copier reaches stand-by mode then make a test sheet.
If this does not work then you have probably have an internal processing component which requires attention.
Apr 02, 2017 | Koutech Systems PC720 (IO-PC720) (IOPC720)...
Canon PC-745 stopped working.. paper jam light
Sooner whole in трее there is what that subject , can broken part or scrap of the paper. Open and see attentively, in that place, where paper sticks. I for its work so much took out stranger a subject(
Sep 05, 2009 | Canon Office Equipment & Supplies
Canon PC 745 error ''8'' plus zigzag. What does it mean?
try to see if there is any paper in the way out of maxine (fixing unit ) or on the right side of the machine you have paper jam thats the signal zigzag
Dec 27, 2008 | Office Equipment & Supplies
Won't intialize
To clear paper jam issue :
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000400/000095/faq000495_003.html?reg=us&c=us&lang=en&prod=mfc420cn_us
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
If the error continues to appear, the machine may have a mechanical problem.
If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Sep 29, 2008 | Brother MFC 420CN All-In-One InkJet...
PAPER JAM LIGHT ON DO NOT COPY
make sure that there is no sensor out of place or there maybe a small piece of paper blocking one of them.
open the machine and check along the paper path
Jun 07, 2008 | Canon PC-940 Black and White Copier
CANON PC920
POSSIBLE BAD EXPOSURE LAMP, SOUNDS FUNNY BUT THIS MODEL WILL SEND JAM CODE WITH BAD EXPOSURE LAMP. CHECK TO SEE IF LIGHT IS IN PREHEAT MODE. ALSO THE EXIT PAPER SWITCH GETS BROKEN OFF ON THIS MODEL...
Nov 29, 2007 | Office Equipment & Supplies
107 people viewed this question
jasbo
jasbo
