Question about GE DCSR483EA Electric Dryer
I closed the dryer door and there was a flash (like a big spark behind the dryer and now the dryer doesn't turn on
  • GE Master
  • 7,482 Answers
Sounds like your Motor went to fault and grounded out.
To check your motor:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 01, 2010
Why won't dryer start?
The door switch frequently fails on clothes dryers. You can check it by manually holding the tab tight to the panel and attempt to start the dryer. There should be a distinct click of a switch behind the panel when you depress the tab.
If dryer works when manually depressing tab but not when door is closed slightly bend the tab out to futher increase the travel of the tab when the door closes.
No click likely bad switch!
Replacement requires qualified technician. Part is inexpensive and readily available.
Feb 28, 2016 | Whirlpool Dryers
Control panel turns on but dryer won't start. Start/pause button flashing as usual, but just beeps twice when pushed.
That generally means the door is open. Assuming you have the door closed I would investigate the switch that tells the dryer the door is open. It may be bad.
Jul 10, 2014 | GE Profile DPVH880EJMG Electric Dryer
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
Dryer has power - we can hear the timer ticking and the light comes on when the door is opened, but when we push the start button nothing happens model # leq9558ko 8 yrs old electric
does the light close when the door is closed??? poosible that the door switch has gone bad. or a bad thermal fuse behind the unit is also a common culprit of this.. its a white thermostat on back of unit behind the panel (-----------------------) approx this long ad white,,
Oct 13, 2010 | Whirlpool LEQ9858P Electric Dryer
I have hotpoint wma62 and door lock light flashes, machine will not start as door will not lock any clues ???
Hiya,
yes, i can help..
Firstly, lets start simple. Have you noticed the door lever/handle has got "floppy"? or loose? or easy to squeeze?
This is the most common reason, what happens is there are 2 bits of spring steel behind the handle, these either break or become weak, to test this theory, close the door, put your finger between the handle and the door and push the handle towards the glass, if this works then you need a new spring/handle.
Please let me know,
Please rate my help.
Regards
Sussex engineer.
Oct 22, 2009 | Hotpoint Aquarius WD640 Front Load...
Start/stop light flashing Dryer will not start
the flashing light indicates that the door is not closing
it may be closed by the door switch is not operating properly telling the control it is closed
Oct 13, 2009 | Miele T8005 Tumble Dryer
The light burned out last week and now the dryer won't turn on
Some dryers that have an interior light that is controled by the door switch, check the light to see if it's burned out, if it's not your door switch may be bad, when you open the door the door switch allows the interior light to come on, when you close the door the door switch shuts the light off, a bad door switch will not allow your dryer to start.
Feb 28, 2009 | Whirlpool LER4634J Electric Dryer
Our 2-year old Frigidair dryer, Model # GLER341A was working fine-I removed the dry clothes, put in the next load, turned it on and it sounded like a load of chains was in it.. When I opened the door...
could be rear drum bearing. possible heat element broke and is rubbing on back of drum those light you say you saw was probably your heat element arcking on the metal in other words sparking
Jan 12, 2009 | Frigidaire GLER341A Electric Dryer
3 beeps and lights flash when I push the start button
The door is not compltely closing. Make sure to push it in hard around the clasp areas. If yours has a light, the light should turn off and on as you open and close the door.
Sep 10, 2008 | Frigidaire FEQ1442ES Electric Dryer
Ge Madallion dryer is blowing fuses every time i turn it on it flashes a big spark out of the back and blows the fuse
you have a shorted componet, or wiring issue, loose wire burnt wire grounded heating element
Apr 18, 2008 | Dryers
GE DCSR483EA Electric Dryer Logo
71 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
