Question about Sharp Audio Players & Recorders
My sharp cd-ba 1700,has protect on screen.how do i remove.thanks
  • 4,234 Answers
The most common failure is of the internal Amp IC for these units. See the link below for a generic explanation of protect mode. I believe that the amp-pacs for these are still available and are in the $45 range.
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Posted on Oct 01, 2010
Sharp cd-bp1200w cd carriage will not open power is ok display ok . cds locked inside!
On my sharp CD-BA 1200 most cd's do not run. It is the problem that has recently occured. Kindly suggest solution.
Mar 14, 2010 | Sharp Multi-System Mini Component System...
How to set clock on Sharp XL 1700 stereo
When the system is off take the remote and press the clock function. After the system lights up press and hold the memory button on the remote. Then press preset up or down to change hour (cycle through 12 hours to change AM PM). Then press the memory button again to change to minutes and repeat.
Jul 30, 2009 | Sharp XL-1700 CD Shelf System
I tryed to have additonal speaker on my sharp cd-BA 150 player all sudden stop working and gave me an error message "PROTECT" so how do I fix that?
The output amp section for your system is not designed to run more than the speakers that come with it. By adding more, you presented too low an impedence load to the amp and overheated it. This occurred too quickly for the internal protection circuits to kick in to prevent damage to the outputs. This unit will now require that the outputs be replaced. These are not the easiest units to work on, so I would not suggest that you attempt this repair yourself. Expect a parts cost in the $35 range for this repair. Dan
Jun 09, 2009 | Sharp CD-BA150 Shelf System
How to connect sharp cd-ba 1700 to pc?
if your sistem got auxiliar option,you can connect your pc through the earphones output of the pc to the auxiliary inputs on the shelf sistem they are a cable named 3.5mm to rca outputs to fit that connection gfood luck
Feb 03, 2009 | Audio Players & Recorders
PROTECT mode
I have a Sharp cd-c2900 home stereo and a "protect" word came up on the lcd?? The stereo is not working now and olnly shows a "protect" word?? Can you please tell me if there is a reset button some where?? Thanks , "Joel" My Email address>> Jovelopa22002@yahoo.com
Jul 17, 2008 | Sharp CD-C2900 Shelf System
PROTECT on start up
The protect message indicates that the output amplifier section has a problem and the unit has shutdown to prevent further damage. This usually is caused by shorted transistors in the final output stage. In your case, the output amplifier is a single replaceable amp-pac (STK402-090S). This can be purchased from tritronicsinc.com using the Sharp part number: VHISTK4029S-1 at a cost of $63.32
Dan
Jul 12, 2008 | Audio Players & Recorders
My audio system says protect on display
Hi Jean,
Without a brand and a model, best that I can provide are generic possibilities:
1. unplug the unit from the mains for a couple of hours. This is supposedly to reset most systems; and/or
2. check the speaker wires and make sure none of any bare wires are touching each other.
If your concern has not been corrected after completion of the above procedures, pls post back brand and model.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 23, 2008 | Audio Players & Recorders
Sharp CD-BA300
An audio output IC may be defective. This set carries two output IC's.
Aug 14, 2007 | Sharp CD-BA300 CD Shelf System
561 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
