Question about HP PSC 1610v All-in-One Printer
I am trying to scan something but it is telling me to install or run device software. I do not have that disc. Is there something else I ca do?
  • HP Master
  • 4,350 Answers
Go to HP.com and download the software. DO NOT USE plug and play, and follow the install directions exactly, from HP.
Posted on Oct 01, 2010
My lexmark x2670 prints copys but it will not scan a document ocr it scans but will not process it .,then tells me it needs a program that has been deleated or lost i am using vista 32bit noel
You will need to update the printer software installed on your computer to install the OCR scan software. The Lexmark OCR scan software is available only on the installation disc that came with your printer. Just re-insert the install disc into the computer hard drive and run the installation setup.
If you lost the disc, please contact Lexmark Technical Support Center for assistance.
Aug 10, 2011 | Lexmark X2670 All-In-One Printer
I am trying to scan a doc, but don't know how to set up the scanner. I am running MS office 2007 on XP- OS
Make sure the Lexmark OCR scan software (used for scanning documents for editing) is installed on your computer. The scan software is available only on the installation disc that came with your printer. No downloadable driver is available in the Lexmark website. Just insert the install disc into your hard drive to install the additional software on your computer.
Jul 27, 2011 | Lexmark X8350 InkJet Printer
I have a Lexmark 1200 . I use it also as a scanner. It works fine producing jpg documents. Is there a possibility to obtain pdf documents and how? Thanks Giorgio Zanini
You scan documents to PDF format. You will need to install the Lexmark OCR scan software to do that. The scan software is only available on the install disc that came with your printer. Insert the disc to your computer hard drive and run the software. After the installation is successful, try to scan your document. You will then have the option to save it as a PDF file.
If you don't have the disc, please contact Lexmark technical support for additional assistance.
Jun 18, 2011 | Lexmark X1270 All-In-One InkJet Printer
Windows 7 64bit, home network. Lexmark interpret s405 all in one.Trying to scan with windows fax and scan. can printer with no problem. windows fax and scan cannot find scanner. I look in device manager...
Try to re-insert the installation disc that came with your printer. Run the disc and make sure to install the Lexmark scan driver. If you have a firewall enabled, make sure to allow all access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
May 11, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I cant get it to stnc to my computer
If your device came with a disc, insert the disc into the CD/DVD drive and install any software needed for the device. Most devices come with the needed software already in the device and should automatically install when plugged in. Try to install any needed software onto the computer as this software contains the appropriate drivers and programs needed in order for your device to properly communicate with the computer. If you do not have a disc or software, check the manufacturer website for any software downloads. Check your user's manual it will tell you what to do in the troubleshooting section.
Jan 12, 2011 | Coby MP815 Digital Media Player
When I press "scan to" it tells me I need to install or run device software for feature. when I insert the disc it won't let me install it all the way.
Don't use the disc anymore....device should be using newer drivers these days. Go to the HP Support site, I'll give you the link below. Put in the device model number in the search box, it will show you your device, choose drivers/software, it will then ask you what operating system the computer is using....choose that from the drop down menu. It will then display all the drivers or software for that model and OS. Scroll down until you see the entire software package for that printer....knowing HP, it is going to be about 325 mb depending on the package, you need this package to be able to scan, fax etc, etc. Part of this package is HP's HP Solution Center which is a graphical interface that allows easy navigation through the different HP printer programs that are available. Download the package and then run the installer and follow the prompts as asked by the software.
http://welcome.hp.com/country/us/en/support_task.html
Jun 19, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Hi , Im running win7 ultimate, on an acer aspire x3200,\r\n every time i put a disc in , or try to burn files to a disc , it crashes explorer.exe, i have checked device manager and it tells me its working...
Yes, most likly. You can restore your pc to an eralier time to try and get around the bad registry information. Click START>PROGRAMS>ACCESSORIES>SYSTEM TOOLS> system restore. Also you can shout down and plugout your system, disconnect the malfunctioning drives and restart your system. The go to deivice manager and scan for hardware changes, shut down, reconnect drives and restart.
If that does not work you should also try to install burning software like nero etc and see if you have the same problem. Dont forget that your drives have internal software called firmware, you should make sure that a new release is available for you.
Hope this helps
Jun 21, 2010 | Acer Computers & Internet
When i try to scan, it says need to install or run device software for feature
if your printer came whith a disc make sure you install everything on the disc to your computer or if you have already done that if the disc had a scanning program try using that
May 16, 2010 | HP PSC 1610v All-in-One Printer
I want to scan with my lexmark x1270 computer. I am running vista. I could not use the disc issued at time of purchase as it was out of date. I downloaded the proper form from the lexmark web site. When...
You should contact Lexmark themselves. If the software was out of date when you purchased the hardware, they should be able to provide an updated disc to you, or at least help you access the OCR software you're trying to extract. Also, if you're scanning photos/pictures, you may just want to change where the images are being sent to.
Apr 01, 2008 | Lexmark Office Equipment & Supplies
HP PSC 1610v All-in-One Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
