Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
We have a B & G 17 hp Turbo cooled Platinum I/C, Model # 311707 The deck belt broke yesterday and we nee a manuel to see how to put the new one on. Can you please e-mail me a NON PDF version or diagram? Thank you
ggb407
  • 4 Answers
SOURCE: I have a 20 HP craftsman tractor model 917.273011 and the v belt
The diagram should be in your manual, if not go to the sears website, click on parts, put in the model # and the diagram should come up.
Posted on Nov 20, 2008
  • 218 Answers
SOURCE: belt tenshoner diagram
Hi..my name is Keith..and you can find a parts diagram online at one of the lawn mower parts sites..and this is one of them..but there is others... www.outdoordistributers.com ...i hope this helps
Posted on Jul 10, 2009
  • 138 Answers
SOURCE: craftman 46in deck model#917-27201 how do you
there is a sticker on the deck that shows the routing for the belt - on a 46" deck, it's probably on the rear, center - or it could be on the underside of the left running board
Posted on Aug 17, 2009
SOURCE: I have a scotts turfmaster 12.5 hp riding tractor
The belt travels from eng. pulley directly to the transaxel pulley riding on the inside/center of the tractor side of the idler pulley. make sure the belt retainer is on the idler pulley.
Posted on Mar 16, 2010
huffman49
  • 235 Answers
SOURCE: We need the electrical diagram for a 17 HP
this is as close as i can find.. take a look and see if you can use this diagram...good luck. go to page numbers 34 and 35
http://www.hammerwall.com/Download_Manual/18200/
Posted on Apr 12, 2010
Need diagramof ground drive belt asembly
I just put a new one on mine. Your owner's manual has a diagram. Should be a diagram on the deck close to right rear wheel.
Aug 06, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a briggs & strat 17 hp ohv intec model 311707 on my craftsman lawn m. it was running then with a large puff of smoke it quit. now the starter runs it with no compresion, removed the s p (oi
does the engine when it is turning over sound normal? does the engine have any compression at all or is it just not as much? sounds like a burnt valve
Sep 07, 2012 | Measuring Tools & Sensors
Looking for a diagram for a cratsman turbo cool intek 17 hp mower drive belt
Without the model number I can't provide a direct link BUT if you go here:
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
and enter the model # you will find exploded views of the mower along with all parts info
May 19, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I change the madrel on a craftsman Lt 2000 42" 17 hp? The star bolt is worn down
remove the deck from the mower, take off the blade, take off the deck drive belt, take out the bolts which hold the mandrel to the deck. put new mandrel in, reverse the whole order. do yourself a favor and take lots of before pictures so you do not have to ask how to put the belts back on. mandrels can be obtained at small engine and mower repair shops. you may just want to replace all of them while you have it apart as they are all the same age and wear.
Mar 17, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42 inch deck mower. Model 917.277611 (2007). LT1000. 16.5hp Briggs & Stratton. Springs on cutter deck assembly broke. Had to re-assemble cutter deck. Re-attached springs and tension arms....
That model number des not show up as a good number on the http://www.searspartsdirect.com site. Are you sure you have the belts on correctly? If it has 2 belts on the deck & 1 is not installed correctly they work against each other. Safely make sure that each blade will turn by hand. did you take the blades off? If they are too long by just a fraction, they will hit ach other, but that usually makes quiet a noise. Get your book out & systematically go over everything you touched or changed. It sounds like something really simple you have overlooked. you can go to http://www.searspartsdirect.com & enter a good model number & view all of the parts diagrams. Sometimes they are a big help, & at other times they just confuse you more:). Let me know what you find!!
Aug 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Riding mower-starter relay clicks-no start even with jumpers.
The frame of the tractor is the same thing that starter grounds to,so yes ,put the ground any where on the frame or engine block to test the starter.An easier way to test everything is to cross over the large posts on the solenoid with a screwdriver and if it turns then the starter is not the problem.Then you will need to put power from the post on the solenoid that has the battery positive connected to it ,to the post on the solenoid that should come live with the key,if it starts then then you likely need an ignition switch if not you need the solenoid.
May 31, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
We need the electrical diagram for a 17 HP Craftsman 42" cut riding mower. Model-311707 Type-0321-E1
Apr 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Belt tenshoner diagram on the deck .Had to replace they were broken SN#042497A00B48 model #944607053 craftman turbo cool
Jul 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
101 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
