Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
What screws need to be removed so I can take the doors off? Top screws, or bottom? How many?
  • 316 Answers
Top screws
Posted on Oct 01, 2010
How do I change the door from one side to the other on my Zanussi ZNB 38 NDX?
The door comes off a set of hinges. You may have to remove the front fascia at the top, and access the screws holding the top hinge on to the frame. Unscrew these and remove the door by lifting off the bottom hinge. With the door off you will be able to remove the screws holding the bottom hinge. If you are lucky, they will reverse fit to the other side as they are. If not, use what was the top hinge as the new bottom hinge, fit the door and use the bottom hinge as the new top hinge.
Jun 09, 2012 | Zanussi Refrigerators
Tip
How to Reverse Your Refrigerator Door (Most units)
1. Remove the toe grille.
2. Remove top hinge cover if available. Trace around the hinge with a soft lead pencil. This makes the re-installation easier. Remove top hinge and lift door off the center hinge pin, and set the door aside.
3. Unscrew the center hinge pin using an adjustable wrench and save for reassembly. Ensure that the plastic washer stays on hinge pin.
4. Lift the refrigerator door off of the bottom hinge and set aside.
5. Remove center hinge and shim by removing inside screw and loosening two outside screws enough to allow hinge and shim to slide out. Tighten screws.
6. Loosen two outside screws on opposite side of refrigerator, remove inside screw and install center hinge.
7. Remove two screws on bottom hinge with 3/8" socket wrench.
8. Install bottom hinge on opposite side with the two screws removed from Step 7.
9. Unscrew the bottom hinge pin using adjustable wrench. Move hinge pin to other hold in hinge and tighten with adjustable wrench.
10. Reverse door handles.
11. Move freezer and refrigerator door stops to opposite side. Before starting screws, use an awl to puncture the foam.
12. Position refrigerator door onto bottom hinge pin and screw center hinge pin through center hinge into the top of the door. Close refrigerator door to help align hinge hole.
13. Tighten center hinge pin with adjustable wrench.
14. Remove cabinet and hinge hold plugs and move to opposite side.
15. Lower freezer door onto center hinge pin (if you have a separate freezer door).
16. Close freezer door. Have an assistant lift up on opposite side of the door while tightening screws to install top hinge.
17. Flip top grille and reinstall.
18. Plug in electrical power cord and turn refrigerator temperature control to center position. Adjust setting as needed.
on Oct 19, 2011 | Frigidaire Refrigerators
I have whirlpool A CLASS fridge how do i reverse the door
  • I cannot confirm weather your fridge had reversible doors as you listed no model but the standard for fridges that can reverse the door swing are changed by doing this -
  1. You will see little plastic covers on the opposite side where the hinges and handles are currently located now.
  2. There are some little clips that hinge the screws on the top and bottom of each handle.
  3. Remove these little covers with a small flathead screwdriver.
  4. Now remove the screws holding the freezer and refrigerator handles on.
  5. Now pop the screw hole covers on the side of the frig/freezer you will using.
  6. Now place and fasten with screws the handles on the other side of the frig/freezer door.
  7. Now remove the top freezer hinge first by removing the 3 screws on top.
  8. Now pull up on the hinge (save the spacer).
  9. Now pull up on the freezer door.
  10. Now remove the screws on the middle hinge.
  11. Now pull up and remove the middle hinge while holding the frig door steady (save the spacer).
  12. Now pull up on the frig door and set to the side.
  13. Now remove the screws on the bottom hinge (save the spacer).
  14. Now put the screw hole covers you removed from the other side in the screw hole exposed from the screws you just removed.
  • The switch
  1. Start with the bottom hinge and place it on the opposite side (don't forget the spacer).
  2. Place the frig door on the bottom hinge and the place the middle hinge in the hole at the top of the frig door.
  3. Fasten the middle hinge.
  4. Place freezer door on the middle hinge.
  5. Put the freezer door in it's natural position to make putting the top hinge on possible.
  6. Screw the top hinge in.
  7. Job complete.
Regards, Tony
Apr 30, 2011 | Whirlpool Refrigerators
How do i change the hinge on thhe refrigerator door? Thanks for your help!
Unplug the refrigerator and remove all food and utility bins from the doors. With the door open, remove the grille from the bottom of the refrigerator. Close the door.
Step 2
Remove the cover from the top hinge with the putty knife. Remove the three screws underneath, then remove the hinge. Take off the freezer door.
Step 3
Remove the three screws from the center hinge, then remove the hinge. Take off the refrigerator door.
Step 4
Remove the two screws from the bottom hinge, then remove the hinge. Replace with the new hinge and insert the two screws.
Step 5
Seat the refrigerator door on the bottom hinge and close the door. Fasten the new center hinge with the three old screws.
Step 6
Seat the freezer door on the center hinge and close the door. Fasten the top hinge and replace the top hinge cover.
Step 7
Replace the base grille, and plug the refrigerator back in.
Good luck in solving the problem with the solutions provided....
Aug 03, 2010 | Sanyo SR-4910M Compact Refrigerator
How do i get the top off to replace a belt.
You don't need to remove the top.
Open the door, find 2 screws holding the door hinges, remove screws; remove the screws on the opposite side of the door opening from the hinges. With the door open or removed, pull the front panel forward. the top of the front panel will separate from the case and you'll be able to remove it lifting it off the bottom. You'll see several screws with hex heads on each side of the case, which were behind the front panel. Those hold the top and support for the drum. Remove serws. Enjoy! ;)))
Jul 15, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do iremove the doors on my conquest
Remove the hinge cover at the top for both doors . Remove the bottom kick plate from the fridge . On the freezer door , follow the white tubing at the bottom about 6" to a connector . Remove the hose from the connector . Unplug the receptical at the top of the freezer door and remove the 3 screws from the top hinge . Lift the door upwards , pulling the bottom tube thru the bottom hinge . For refrig door , just remove the 3 screws holding the top hinge and lift door off bottom hinge . Hope this was helpful .
Aug 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Access to replace door switch
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out so you can replace the door switch and actuator assembly:
Jan 04, 2009 | Dryers
Need to replace door gasket
Remove the top cover by removing the 2 screws in the back.
Remove the dispenser drawer completely.
Remove the 2 screws on front of the panel where the dispenser drawer was removed.
Remove the screw on the right side behind the front panel.
Disconnect the wire harness behind the panel.
Starting on the dispenser side with your finger, pry forward the top of the control panel until it unsnaps.  Continue this all the way to the right and remove the control panel.
Go to the bottom filter door and remove the door.  Unscrew the one screw below the filter cap.  Remove the plastic insert covering around the filter cap.
Locate a small screw at the very bottom of the frame just below the filter cap and remove.  Sometimes there may be 2 but usually there is only one.
Open the door and locate the spring clamp usually located at the bottom of the door seal.  Remove the spring clamp.  This will loosen the front of the door gasket for removal from the frame.
On the right of the door gasket is the door latch assembly.  Unscrew the 2 screws and set the latch hanging by the wire harness.
Remove the 4 or 5 top screws holding the front panel assembly.  Once they are removed, the front panel will lift up and out.
NOTE!!!  THIS JOB REQUIRES 2 SPECIAL TOOLS FROM LG TO REMOVE THE SPRING CLAMPS ESPECIALLY THE REAR CLAMP.  THE SPRINGS ARE SET VERY TIGHT SO IT IS NOT EASY TO REASSEMBLY WITHOUT THE SPECIAL TOOLS.
Sep 23, 2008 | LG WM1814CW Front Load Washer
I NEED TO REMOVE THE DOORS
Removing doors can be tricky... if you need to reinstall them.
First remove the plastic cover top door if it's an over under. Usually the screws are 5/16 there are 3 screws usually. Remove 2 screws loosen up the third. swing the bracket out of the way. Reinstall the screws you removed, this keeps interior screw plate in place and does not allow it to shift. Remove the 3rd screw , Remove the bracket reinstall the 3rd screw.
lift up and remove the door rememder washer locations.
Is there a washer on top of the middle bracket? Do not loose this or get it confussed with the bottom washer on the bottom bracket. Next there should be 2 screws on the middle braclet.
Remove one, loosen the other swing the bracket around. Install the removed screw. Remove the second screw. Remove the bracket, reinstall the screw. Lift bottom door up remove.
Now do the same to the bottom bracket. Or do not remove the bottom bracket if you don't have to. hope thisd helps.
Jun 01, 2008 | KitchenAid Refrigerators
Remove Outer Glass Of Oven Door
On my Zanussi ZDF 866 it goes like this:-
Rest the door with its top edge on your work surface. Once the bottom two screws are removed, pull the outer glass away from the bottom edge of the door just enough so that the brackets fixed to the outer glass (into which those two screws went) clear the bottom edge of the door. Then pull the outer glass up towards you parallel to the door (there are now screws hoplding the top edge on this model).
It may need one side to be pulled and then the other to release it from the metal slot at the bottom.
I would recommend great care with this given that a) your door may be different, b) it could be held more tightly and c) you are dealing with glass. Recommend taking all precautions including eye protection and suitable gloves. Proceed slowly and carefully (this did not need much force on my door). If you're not sure at any stage, choose discretion and either give up or pay someone to do the job to avoid paying for a new glass or hurting yourself.
Hope this may help someone.
Jan 25, 2008 | Ovens
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
