Question about Health & Beauty
I HAVE A NEW SHOPRIDER SCOOTIE 4 WHEELS . I CHARGE THE BATTERY AND HAS A BEEPING NOISE . IT WONT RUN AT ALL. LOOKING AT THE BATTERY POWER LIGHT AND IT DRAINS FAST
  • 692 Answers
Rickie If you count the number of beeps (4 beeps pause 4 beeps etc) this could tell you what error you are having. If it justs beeps with no pattern and your battery lights run down very fast then I think the batteries are one problem. Also check your charger to make sure that you are getting the correct voltage to your Batteries. You might want to ask a tech to check out the charger Hope this helps you
Posted on Oct 01, 2010
How do i turn off the beeping that occurs when i go in reverse
the reveerse beeper is a saftey feature to let others know to look out for you coming not to be disabled .
Apr 28, 2014 | Shoprider SCOOTIE Scootie Jr Scooter
How do i turn off the terrible beeping that goes off when my scooter goes backwards.
It has a purpose and that is, warning anyone behind you. Better to put up with that, than be confronted with an insurance claim.
Apr 26, 2014 | Shoprider Scootie Jr
How do I turn off the beeping that happens when i use my scooter in reverse?
Hi, it 's normally a small buzzer locate near the controller , in bedded within the wiring loom, look for the circular shape within the plastic selves...
Regards
Rob
www.gewizrepairs.co.uk
I don't know how to remove old batteries to install new batteries in Shoprider Scootie TE-787NA power scooter. I can't lift them up after I remove batteries cover. I can't find it in manual.
Not familiar with that make and model, but we often find that batteries just plain get stuck due to gunk on the battery pan. If you do not see a strap or hold down or anything, try wiggling them to see if that frees them up.
Mar 29, 2014 | Shoprider Scootie TE-787NA - Power Scooter...
When the ignition key is turned on it makes a beeping noise and will not engage
hi, that can be because the throttle lever and pot has moved off centre slightly...you need to make sure the cross head located on the bottom of the pot , a metal stem that the throttle lever fix to is dead centre to you when sitting on the scooter...
Regards
Rob
Mar 05, 2014 | Shoprider Scootie
I installed new batteries and scooter still doesn't run,why?
Check the wiring from the controller to the motor, disconnect the wire ad clean the connections with a contact cleaner or WD40 , and make sure the scooter not in freewheel mode.
Regards
Dec 14, 2012 | Shoprider Scootie
How do you test the batteries and how do you remove the batteries for the Shoprider Scootie?
Bill With a voltmeter you can check the voltage of the batteries through the charger port on the battery pack. Set the voltmeter to 200 volts dc and plug the leads into the two outter holes of the charger port. You will be reading the voltage of the batteries and after a full charge they should read 25-27 volts. The batteries are in the case under the seat. remove the case from the scooter and turn it over there are numerous screws to unscrew to seperate the case and get access to the batteries. Remove the cables from the batteries and also the heat sensors from the batteries. Make sure you reattach the heat sensors to the batteries when you relace them with new batteries. Now you won't be able to do a load test on the batteries in the case but you can get them checked once you remove them from the case. It has been my experience that these smaller batteries do good if they last you a year. If less than that you might have a weak battery and you will need to replace both batteries with new ones. Hope this helps you
Nov 13, 2010 | Shoprider Scootie
Service center for shoprider scootie near Bloomington In
Please go to Shoprider.com and click on the tab for provider locator. When the window opens click on ceritified technician locator. When the window opens put in your zip code and put in the search radius. This will give you technicians who are cerfied with Shoprider scooters closest to your home. Hope this helps.
Nov 05, 2010 | Shoprider Scootie
My shoprider scootie does not show whats left on the battery and the horn does not work. Any suggestions what the problem may be? Thank you
hi, ok, but does the scooter work besides the horn and battery indicator not working ?
If the scooter works okay then the problem is within the tiller control panel , that is the panel on the handlebars, Now it could be a loose wire so carefully take it apart and check to see whether there are any loose wires.
Regards
GeWiz
Jan 12, 2010 | Shoprider Scootie 4 Wheel Compact Travel...
Health & Beauty Logo
231 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
