Question about Uniden DECT 6.0 Cordless Phone ID
I need owners manual for uniden DECT2080-5: how to set up handset/base, caller id, answering machine Thank you for your assistance. Can the manual be downloaded, also? Sherry
    Brigadier General:
  • 7,191 Answers
You can download and print the instruction manual in PDF format by clicking this link.
Adobe Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
The detailed step-by-step setup instructions are given in the manual.
Hope this helps. Thanks for using FixYa.
Posted on Oct 01, 2010
The Base says new cid:34. How do I get it back where it was. I tried to get a number that rang and it changed the settings
Julie,
Sounds like 34 is the # of calls that came in on the caller ID (CID) lis
To open the Caller ID list, press the little phone handset symbol (it looks like a big "C" then ID next to it) on the right side of the 4-way button (it toggles 4 ways, so press to the right side to get the Caller ID list).
The phone will show the number of new calls (or Caller ID records) and the total number of stored CID records. Use the "up" arrow and "down" arrow to scroll through the list.
It looks like you have the Uniden DECT 6.0 6035, so I attached the manual in case it helps.
You can set up the answering machine if the voicemail was deactivated by Lifeline (page 38 in manual shows how to set up answering machine). If 4 rings is not enough, you can change the # of rings (page 40) and to use the answering machine/voicemail, see page 42 in manual.
Uniden 6035 1 Owner Manual
Nov 03, 2015 | Uniden DECT 6.0 Cordless Phone ID
Need manual
If the manual didn't come along with the phone, it is easier to just look on google for 'Uniden DECT 1480-3 Black Cordless Phone w/ 3 handsets DECT 6.0, Answering Machine, Caller ID' and it should pop right up!!
Jul 07, 2015 | Uniden DECT 1480-3 Black Cordless Phone w/...
Base handset has interference.
If you still have a regular phone about, plug it inhere the base handset is connected and see if the symptoms remain. If they do, the problem is likely with your house wiring or the phone company. If no interference on the regular set, base handset may be defective. Try it at someone else's house.
Radio Shack (hurry :) has in-line filters that may clear up line noise.
All he best
Mar 06, 2015 | Uniden DECT2188 DECT 6.0 Expandable Corded...
THE BASE SET OF MY UNIDEN 1480-3 CORDLESS PHONE NO LONGER BEEPS WHEN I HAVE A NEW MESSAGE. CAN ANYONE HELP?
You can set or change the answering system options from any handset.
Open the menu and select Ans setup then select Message alert and activate it!
Beeps will be on!
Oct 05, 2014 | Uniden DECT 1480-3 Black Cordless Phone w/...
Why doesn't the LCD display doesn't work?
Does the LCD not work at all? or do you mean that it doesn't display Caller ID information? If the LCD is completely dead, you'll need to get the phone repaired. On the other hand, if it's just the Caller ID that's on the fritz, try this: unplug the base from the power socket; remove any batteries in both the base and the handset; wait one minute; plug the base back into the wall and replace all batteries. This will reset the Caller ID so it works again. (Depending on the phone you may or may not lose settings and memorized numbers.) If this doesn't help, the problem will require a professional repair.
Aug 06, 2014 | Uniden D3097 LOUD & CLEAR Cordless Phone -...
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Caller id
you must set the base time as well as the handset time
enter global setup menu then
time and date submenu
then vol. up / down for day
then hour
then minute pressind save each time
Jan 24, 2008 | Uniden TRU8885 Digital Answering Machine
No electrical outlet available for the base station (wall mounted)
most cordless phones need some access to 120 volt power to recharge the internal NiCad batteries. It wouldn't be cost effective to have on hand a bunch of charged batteries that you'd replace on a daily basis. they got to be charged up eventually.
Aug 23, 2007 | Uniden CEZAI998 Phone
Uniden DECT 6.0 Cordless Phone ID Logo
580 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
