Question about HP Office Equipment & Supplies
I have a HP Laser Jet 3050 all-in-one and one telephone line. How do I connect the printer so I can receive fax and have phone calls also?
  • HP Master
  • 4,737 Answers
First of all, install all the softwares, drivers and utilities that come with the CD. After they are installed, connect the telephone line and configure the fax from the computer, refer to this tutorial (click here).
And also on the printer (click here)
Actually, the complete guide to Fax Setup is mentioned on the Manual (Manual Page No.16) [click here to read/download the manual].
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 01, 2010
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
My home HP laser jet 3055 machine is not connecting
Hi:
Make sure that it is set to Auto Receive not Manual Receive. Also make sure the the telephone line cord is plugged into the Line jack not the Tel jack on the back of the fax machine.
Jul 19, 2012 | HP Deskjet 3050 Wireless All-in-One Inkjet...
How to scan a photo using hp 3050 laser jet
I'm running Windows7.
I click the start button.
I click All Programs
I look for and click Windows Fax and Scan
A window opens that is called Fax and Scan
I select new scan at the top. The PC connects with the scanner
Another window opens, and I select my printer scanner
And then I click Scan
This the easiest way that I have found to scan from my AIO
Jan 17, 2011 | HP LaserJet 3050 All-In-One Printer
Comm error 232
This is the common cause and solution: A communication failure has occurred between the two machines. On the other hand, the user at the remote machine may have pressed the Stop button. Alternatively: the power at the remote machine has been interrupted, or deliberately turned off causing the fax session to be interrupted.
Solution:
1. Re-attempt the fax reception at a different time when telephone line conditions have improved.
2. If the error persists, and error correction is in use for the fax session, disable ECM . (See Error 222)
Good luck
Jun 12, 2010 | HP LaserJet 3050 All-In-One Printer
HP 3050 Laser Jet: I can receive faxes but can not send fax? Help
Hello !
You need to reset fax settings first, go to the "Service" under the printers Main Menu and click on "Restore Defaults"
And then set the following settings under Fax Setup > Fax Receive Setup :
Answer Mode: Automatic
Rings to Answer: 2
Distictive Ring: All Rings
Now go to "All faxes" and change this settings:
Error correction : OFF
Fax Speed: Medium v.17
If you are using a digital line it would be a good idea installing a filter for the line
Hope this works
You can contact me on :
eliteprintersolutions@gmail.com
Jan 08, 2010 | HP LaserJet 3050 All-In-One Printer
Hp 3050 laser jet printer the fax page is black
The scanner in your FAX is nothing working -- i.e., "100%-black" or "100%-white", and so what is transmitted is what the scanner has scanned, improperly.
Dec 13, 2009 | HP LaserJet 3050 All-In-One Printer
Fax issue with HP Laserjet 3055
Hi. The fax-module in lj 3055 needs a 100% analog dial tone. You might get it working on a internet-phone-line, but HP garantees nothing because there are so many internet-phone-providers, and all of them operates with different specs and line-quality. You might try to lower the baud rate, turn off JBIG compession and error-correction. If the problem still remains, you need to replace your phone-line to a 100% analog line. Not any internet or ISDN/adapter-stuff. You should test your fax on any analog line at a friends house, just to make sure the fax i working anway.
Jul 27, 2009 | HP LaserJet 3050 Printer
I have 2 telephone lines 23481629 & 23480095. i get faxtone on 23481629 & no fax tone on 23480095
The HP 3050 laser multifunction is not set to handle 2 incoming fax lines. If you need that then you have to add a line switcher such as one from Command communications CS3500
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 13, 2009 | HP LaserJet 3050 All-In-One Printer
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
fax using monitor dialing
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 07, 2008 | HP Officejet 4215v All-in-One Printer
193 people viewed this question
Seeker5211
Seeker5211
