Question about Nintendo Mario & Luigi: Partners in Time for DS for DS
I can`t save! It says "save failed, press A or X".
    Master:
  • 473 Answers
Issue with your Memory Pack... Check if is Full, Or Memory Defect, Change Memory Pack
Posted on Oct 01, 2010
My ASUS Z99E laptop cannot access winXP
Try to access the BIOS "F2" Key, Go to the BOOT Section, set the 1st Boot device to DVD / CD Rom. Press "F10" Save and Exit. If it fails again, re-enter the BIOS. Then make sure the drive is set to IDE and not ACHI. press "F10" save and exit the BIOS. If that fails then select in the BIOS Load Setup Defaults, and re-select the boot device to DVD/ CD Rom.
If all fails, you have to open the side or bottom cover to remove the HDD - Hard Disk Drive, Connect it to a Stand alone pc via the SATA Cable or External Device (Works as USB) then you can either do an emergencey back-up, Format the drive through windows.
Hope it helps
Mar 23, 2014 | ASUS Z99E COMPATIBLE LAPTOP LCD SCREEN 141...
Dell V715w wont receive faxes
To receive a fax automatically:
  1. On the printer control panel, press the Setup setup_icon%281%29.jpg button, then use the menu to select Fax Setup, Ringing and Answering, and then Auto Answer.
  2. Select On and then press OK to save the settings.
  3. Select Pick Up On and set the number of rings, then press OK to save the settings.
To receive a fax manually:
  2. Select Off and then press OK to save the settings.
  3. When the telephone rings and you hear fax tones when you pick up the handset, press the Start button on the printer or *9* on the telephone attached to the printer.
Oct 25, 2011 | Dell All-in-One Multifunctional (v715w)...
Our Genicom Tally printer fails to keep settings. The model type is 6312. What could be the problem?
There may be a number of reasons for the 6312 failing to keep your settings, the first thing to identify would be that you have changed the settings on the printer and then saved these settings. If you do not save the settings to a menu / configuration they will be lost if the printer is powered off or receives a reset command.
Once you have made your settings changes, the settings can be saved in the following way;
Ensure the pritner is OFFLINE
Press Menu
Press Up Arrow until display shows Config Menu
Press Enter
Press Up Arrow until display shows Configurations
Press Enter
Press Up Arrow until display shows Save
Press Enter
Press Up Arrow until the Config Number Or Name appears that you want to save the settings to (Default is Confg 1)
Press Enter
Press Clear, to return to Offline mode.
If you save your settings you can then print a configuration report to see the values that have been saved, this can be done in the following way;
With the printer OFFLINE
Press the Menu key
Press any Arrow key until display shows Config Menu.
Press the Enter key.
Press any Arrow key until display shows Printer.
Press any Arrow key until display shows Report.
Press any Arrow key until display shows All Configs.
Press the Enter key and the configurations will be printed.
This should show your saved settings, try powerign th epritner off and back on again and again print the Congfig report to check the settings are retained.
If you find the settings appear to change when you print to the printer this will be caused by your print job, escape commands in the print job will take presidence over the printer menu settings.
You would need to check the host computer system to see what might be causing the problem; chack page size, fonts, ensure the correct printer driver is used etc on the system.
Jan 26, 2010 | TallyGenicom 6312 Matrix Printer
Call failed error for outgoing & incoming calls
Press call logs-Press menu-click on Options-General Options-Restrict My Identity(It should be never)-save and ok.For text message your message center no has been changed so call your service provider and ask for message center no and update in your device.To update Press menu-select options-SMS-Service center-change the no and save it.After saving do the hard reboot.
Jul 16, 2009 | RIM BlackBerry Pearl 8100
PM800-8237-6A7L2B0DC-00 WARNING! CPU has been changed or CPU Ratio changed fail. Please re-enter CPU Setting in the CMOS setup and remember to save before quit! press F10 and Y for save. Re-start, and the...
If you have correctly set the CPU in the BIOS, and saved the settings and still get the error, the CPU is not compatible with your system.
Most likely you have not set the BIOS right or have not saved it.
Jul 02, 2009 | Computers & Internet
Fails to connect during receipt of fax
You may have to decrease the transmission speed and turn off the ECM using the steps given below:
1. From the control panel, press Fax Mode.
2. Press "Menu."
3. Press "Up" or "Down" repeatedly until "Send Setup" appears.
4. Press "Select."
5. Press "Up" or "Down" repeatedly until "Max Speed" appears.
6. Press "Select."
7. Press "Up" or "Down" to select a "9600 bps."
8. Press "Select" to save the setting.
9. Press "Up" or "Down" repeatedly until "Send Setup" appears.
10. Press "Select."
11. Press "Up" or "Down" repeatedly until "Error correction" appears.
12. Press "Select."
13. Press "Up" or "Down" repeatedly until "OFF" appears.
14. Press "Select" to save the setting.
Apr 21, 2009 | Lexmark X7350 All-In-One InkJet Printer
Whenever i restart it says over clkocking failed.help
System was configured to run at a higher-than-rated speed. Just press the delete key when instructed to enter BIOS setup. It will probably reset to its default timing arrangements. Then press F10 to save the settings and exit the BIOS setup.
Apr 10, 2009 | Computers & Internet
Fails to save
my game airport tycoon 3 fails to save program if it save and i go back to it when i press to laod saved games , the screen goes blank and sends me back to windows
Jan 16, 2009 | Global Star Software Airport Tycoon 3 for...
Failed creating file
I had to re-do the project, this time using Standard Quality rather than High Quality, and it completed creating the file(s) and writing the DVD.
Bernie
Mar 26, 2008 | Panasonic Palmcorder SDR-H18 Camcorder
Nintendo Mario & Luigi: Partners in Time for DS for DS Logo
141 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
