Question about Umax Astra 2000U Flatbed Scanner
Astra 20000U lost the power supply where to get replacement transformer?
If you can see the voltage and amp requirements either on the machine near where it would plug in or a manual then I have picked up the transformer at radio shack and they have a set of different ends to plug in on the DC side
Posted on Oct 01, 2010
  • jeanne_62473 Jul 15, 2014
    there is no pandigital.net anymore so now where can we buy the sheaths?
I HAVE LOST THE POWER ADAPTER, CAN YOU SUPPLY A NEW ONE?
this one will work. http://www.buy.com/prod/belkin-12v-dc-power-adapter-20w-belkin-12v-dc-power-adapter-20w/q/loc/101/10296195.html
Mar 30, 2011 | Umax Astra 1220U Flatbed Scanner
I have a Behringer xenyx 802 audio mixer and have lost the power supply. I tried to buy a replacement, but cannot find any in stock. I'm very resourceful and thought I'd make one. The spec sheet calls for...
No, you can't just jump the pins together. The power supply in the mixer needs two separate 18-volt AC inputs because it makes two supply voltages, +15 and -15 volts.
The external supply is just a potted 36-volt transformer with a center-tapped secondary. I bought an open-box Behringer (not your model, but similar) that was missing its supply, and found this transformer which works fine. (I actually did find a couple of sources for a replacement Behringer supply, but it cost more than I paid for the mixer!) Just connect the three output leads to the appropriate places on the mixer's PC board. In mine, I removed the original input connector and soldered a pigtail with a 3-pin connector from Radio Shack to the PC lands, then attached the matching plug to the transformer leads. You'll also need to provide an enclosure of some kind to prevent contact with the line voltage input to the transformer and to protect the thing if you carry it around.
Mar 29, 2011 | Audio Players & Recorders
I lost the power supply to my EZ1600-S while moving house. I need to know the output voltage of the external power supply so that I can replace it
There should be some hint of power output on the transformer or power requirement on the device. Please give a look on the device. I understand you cannot look at the transformer, it is lost.
http://www.gigafast.com/products/product_pdf/EZ1600-S.pdf
It appears the company that manufactured your device is out of business. If you cant find the power requirement, its time to replace your device.
Linksys makes a nice 16 port switch for under $100.00
Oct 20, 2009 | GigaFast Ethernet EZ1600 (ez1600-s)...
Need power supply for UMAX Astra e5420 acanner
From a quick search I found this power supply, from Umax.com,
http://umax.com/scanners/index.jsp?cate=Scanners%3A+Accessories&skunum=68300055-0000
Jun 03, 2009 | Umax Astra 3450 Flatbed Scanner
I have lost the power supply for my Umax astra 2200 scanner. Could you tell me what it needs so I can try and replace?
It needs a 12VDC 0.75A or 12VDC 1.0A Center + Positive power adapter. The lower amp will work as will the 1.0A. You can find it for sale at $12 on the Umax site or just use any adapter that has the same specs printed on it.
Apr 01, 2009 | Umax Astra 2200 Flatbed Scanner
Power adapter for Astra 2100U
The Voltage and Current/Amperage draw should be printed on a tag on the scanner itself. The scanner isn't worth replacing the power supply in my opinion as you could probably replace the scanner for a little more than what a power supply will cost.
Mar 29, 2008 | Umax Astra 2100U Flatbed Scanner
Umax Astra 2000U Flatbed Scanner Logo
Top Umax Office Equipment & Supplies Experts
Ricky Ostrom
Ricky Ostrom
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
