Question about LG DLG7188 Gas Dryer
My dryer will not heat. does this have anything to do with the moisture sensor. Where is this sensor located ?
  • 489 Answers
No, the moisture sensor only senses the wetness of the clothes and the computer determines how long it will take to dry the clothes. The no heat situation is one of 3 problems. No gas situation, high limit switch has tripped or motor contact switches broken. You will need a professional LG technician to diagnose the problem for you.
Good luck
Posted on Oct 04, 2010
  • 1tach Jun 19, 2011
    SORRY IS THIS WEBSITE A HELP FOR DY OR THIS OR JUST TO TELL ME TO GET A PROFESIOL TECH FOR SEATS OR LG?????
    I sounds like thenonly thing that youy recomend is get a PROFESIONAL.... If I have the money to have fix why would I go to this type of website??????????????????
  • Richard Lew Jun 20, 2011
    If you try to diagnose the problem, you can check the hi limit switch to see if it has tripped. There are two of them located on the combustion chamber. You will need a ohm meter to check for continuity. If they are fine, then go to the gas valve and make sure that both solenoid valve controls are good with the ohm meter. If the valve is fine, then go to the centrifugal switch on the motor. Press the centrifugal switch inside the motor windings to close the switch and check both the upper and lower wire of the harness connection with the ohm meter to see if the centrifugal switch is good. Check the ignitor to make sure it hasn't failed with the ohm meter. One of those parts will be the problem and the ohm meter will tell you which one. I hope this helps.
    Good luck
Roper model red4640yq1 heats in auto mode but not on timed dry
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Feb 26, 2016 | Roper Dryers
Will broken moisture sensor cause dryer not to heat
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Aug 18, 2014 | Maytag Dryers
Electric dyer stops mid cycle Whirlpool
It could be the lint screen needs cleaning, and not just removal of lint, but washing with warm water and a soft brush to remove fabric softener / static cling sheets that can build up and without being obvious, clog the screen. If there is not adequate air flow and the dryer is over heating it may shut itself off as a safety precaution.
Also, i'm not sure about this model, but many dryers have moisture sensors. These can become ineffective do to fabric softener sheets build up that coats the sensors. Check the owners manual and locate the sensor. It is just two metal contacts inside the dryer. Clean them with warm water and a nylon scrub pad, like you would use to wash dishes, but not steel wool or anything too abrasive.
Apr 12, 2014 | Dryers
Where is the sensor located on a lg tromm elect dryer
The moisture sensor is located in front grill area inside the dryer. If you look inside the drum where the filter screen mesh is, you will find 2 curved metal bars. Those are your moisture sensors.
Hope this helps.
Nov 06, 2011 | LG DLE5977 Electric Dryer
I have a Whirlpool LGN2000PW gas dryer. The dryer will heat up when it is first started and get warm, but after a few minutes it cools right back down. We removed all the duct work in the basement leading...
if it still quits heating after a minute or so then its either a weak cycling thermostat or moisture sensor thermistor,both located on the blower housing, or the moisture sensor bars located near the door opening on the dryer,or it could be a high limit thermostat thats bad on the burner tube itself
Oct 14, 2010 | Dryers
DRYER WILL START TO HEAT THEN WILL QUIT. MOISTURE LIGHT WILL NOT SHOW ?
your moisture sensor has gone its located just below the door somewhere near the lint filter check with multimeter but make sure its moist
Jun 24, 2009 | Dryers
Gas dryer continues to run on the Auto cycle.
try to get the manual for the dryer you got and locate the moisture sensor if this sensor is bad what happen is that the automatic timer thinks that the clothes still wet and continues to dry once the sensor detects no moisture then it shut off the dryer normally is located behind the dryer on the exit line of the air duct and tested for conductivity and see if is good or not
Mar 27, 2009 | Amana DLG330RAW Gas Dryer
Dryer runs but wont auto shut off
On auto dry cycles, the cycle is controlled by moisture sensing bars located on either the rear or front bulkhead, ( visible inside dryer ) if the moisture sensor bars are shorted together (normally by wet clothing) the dryer will continue to run. If the dryer continues to run when the clothes are plenty dry, check and see if there is anything stuck between the sensor bars, (sometimes a metal sequin will cause this) or see if they are damaged. If not, you may have a problem with a timer contact, if the timer advances and stops moving at the same spot each time, I would suspect the timer. If this is an EvenHeat dryer, examine the control board located to the right of the timer in the control panel, for any burned components. Hope this helps.
Sep 15, 2008 | Kenmore 73952 Gas Dryer
Moisture Sensor Location
It could be the sensor. However, check the exhaust vent for restrictions first. you can test the moisture sensor Damp Dry Test 1. Set the following Timer- DAMP DRY Fabric Care/Temperature switch- COTTON HIGH Wrinkle Guard switch- OFF Signal switch- LOUD Door- must be closed 2. Press the PUSH TO START switch. After approximately 16 seconds, the Timer will start to advance to the OFF position, and the ?End of Cycle? signal will sound. If one or more of these functions do not occur, proceed to the Factory Test. Factory Test The Factory Test allows factory/service personnel to test and verify all inputs to the Even Heat control. The basic operation of this test is to notify the operator with an audible beep every time the status of an input to the control changes state. Activating the Test Mode 1. Set the following configuration: Door- must be open Fabric Care/Temperature switch- AIR FLUFF Signal switch- LOUD Timer- TIMED DRY OR AUTO MOISTURE SESING PLUS selection 2. Turn the Wrinkle Guard switch from OFF to ON three times within a five second period. A single beep will sound to indicate that the factory test mode is activated. NOTE: If any of these initial conditions are not satisfied, the control will not enter the test mode. Test Mode Functionality When the control is in the Factory Test mode, every input change of state will result in a beep (with the exception of the Signal switch). This includes: Door switch Moisture Sensor (short/open Sensor will result in a beep) NOTE: A moistened finger or damp cloth may also be used. Fabric Care/ Temperature switch Wrinkle Guard switch Push to Start (PTS) switch (with the door switch closed) Timer (any cam input change will result in a beep) NOTE: Timer will advance during test. If any of the inputs do not result in a beep, proceed to the following component tests If the dryer shuts off too soon when set to the AUTO MOISTURE SENSING PLUS cycle, check the following: -HARNESS/CONNECTION -MOISTURE SENSOR -THERMISTOR -EVEN HEAT CONTROL Procedure: 1. Test the Moisture Sensor by following the procedure outlined in ?Factory Test?, beginning on page 3. If the Moisture sensor fails the ?Factory Test? (does not produce a beep sound), check the Moisture Sensor. a. If there is continuity to Ground for Yellow/Red (Y/R) wire with no load, look for a short in the Sensor or Y/R wire. Verify harness connections both at the Sensor and the Even Heat control. b. If the Sensor and Y/R wire are good, replace the Even Heat control. 2. If Factory Test passed, verify thermistor by performing test procedures outlined in ?Thermistor Test? 3. If problem persists after replacing Moisture Sensor and thermistor
Aug 27, 2007 | Kenmore 62972 Electric Dryer
Open Questions:
LG DLG7188 Gas Dryer Logo
180 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
