Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
Error 0x61011beb is on my HP office jet 6500, how do i fix?
faxman789
  • 297 Answers
SOURCE: HP office jet 6210 scanner failure error
have you tried to reset the printer?
(Take the power cord off hold # 3and then turn the printer on.)
That is an initial position problem
Parts are no longer available for this model from HP...
Posted on Jan 17, 2009
moderator
  • 6 Answers
SOURCE: hp 6500 office jet refill
to refill 920:
1. If you have the plastic cap that covers the 9 mm. hole where you can see the sponge, then tape this cap to the cartidge with scotch tape. If not, use some duct/masking tape to cover the round hole.
2. Use the dry hypodermic needle to find the hole that will be found at the very center of the 920 label. With the needle, pierce the label.
3. Fill the hypodermic needle with 4 cc of ink.
4. Insert the needle 2-3 cm. into the hole made in step 2. Draw out 1 cc of air, then slowly force the 4 cc of ink into the sponge. Use toilet tissue to absorb any ink that might have escaped.
5. Let the catridge stand overnight (if possible) so as to allow the ink to evenly saturate the sponge. If not, insert it into your printer immediately.
Note: If you are going to refill catridges, be certain not to allow the sponge to dry completely. Thus, you might want to do step one immediately and to enclose it in a sealed sandwich bag upon removing an empty catridge from your printer even if you are not going to fill it immediately.
www.catherinecollege.net
Posted on Aug 12, 2009
  • 78 Answers
SOURCE: Officejet 6500 error code 0x61011beb
General error 0x610000F6 actually is a Carriage Jam issue
Click Here for troubleshooting.
Posted on Nov 11, 2009
Semi-Driver
  • 434 Answers
SOURCE: Officejet 6500 error code 0x61011beb when
Your OfficeJet 6500 may need resetting. With the printer power on:
1) Disconnect the USB cable from your computer
2) Remove the ink cartridges
3) Unplug the power cord. Wait for at least 1 minute. Plug the unit back in (press the power button if necessary)
4) Wait for the "Insert Cartridges" message. Reinstall the cartridges
5) Close the product doors
6) If you receive a recalibration message, allow the printer to complete this task
7) Reconnect the USB cable
8) Try your print job again
If problems still exist, your product may need servicing by an authorised HP technician.
Posted on Dec 20, 2009
SOURCE: hp 920 xl ink cartridge filling instructions anyone have them
I used the drill method in the video. Took a while to get it printing again but so far, so good. THe low ink light went out so the pritner thinks the cartridge ink level went up as it did.
Will post again if it breaks.
Dr Bill
Posted on Aug 14, 2010
MY OFFICEJET 6500 appear 0X61011beb problem , according to FAQ still fail, i just change INK, why HP printer so weak itis my second HP PRINTER, HOW TO SOLVE IT ASAP?
My printer is giving error and not general to prepare.
I call her, she ai ta general error appears she preparing and never more.
How can I solve this problem?
Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
0x61011beb ink system failure on my HP officejet 6500. I have gone through all the troubleshooting steps = not fixed. Makes a clicking sound when it reaches the r-hand side. It is still under warranty, but...
1. Plug it directly into the wall, rather than into a UPS
2. Verify that the unit is switched on. Disconnect the USB/Ethernet cable from the All-in-One and also disconnect power cable from All-in-One and also from wall outlet.
3. Wait 30 seconds.
4. Plug in the power cable to All-in-One and also to wall outlet.
5. Check for the functionality.
I still had the error message, so they said to reset the printer to factory default settings:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
If those two steps do not resolve the problem then its is hardware related and can't be solved here.
Mar 23, 2011 | HP Officejet 6500 Wireless All-in-One...
Put in new ink HP office Jet 6500 and error comes up "Yhe print head appears to be missing or broken.
Lift the lid and Remove the offending printhead (K/Y or C/M)
With a q-tip moistened (not dripping) with bottled water, clean the CONTACTS only on the head, and in the printer.
"pound 6" the printer (click here for the procedure or paste this link in your browser address box http://www.fixya.com/support/r8534283-hp_all_in_one_printer_acting_up )
Reinsert the head when it complains it's missing.
The printer will whir and click and gyrate for some period...be patient.
If that doesn't fix the problem, you may need a new head. These are available where you buy your ink.
Mar 17, 2011 | HP Officejet 6500 Wireless All-in-One...
I had to have work done on my computer. Then, when I tried to use the printer, it would not turn on, i received an error message that said I should rerun the set up program. HOwever, I can not find the CD....
Go to www.hp.com click on the download support tab, enter your printer model ... Office Jet 6500 ... when you get to the nuts and bolts of it, select your OS and download your driver software. I suggest you save it to the desktop so it will be easy to find.
I just got drivers for my Desk-jet less than 30 minutes ago ... this is the process I used.
Thank yo for your interest in FixYa.com
Feb 17, 2011 | HP Office Equipment & Supplies
I've just got HP Photosmart Premium c310a printer and when i start it up it shows the error! (0x61011beb) hope u can help. THNX
Hi
I've just got HP Photosmart Premium c310a printer and when i start it up it shows the error! (0x61011beb) hope u can help. Thanks
Feb 10, 2011 | Office Equipment & Supplies
Officejet 6500 error code 0x61011beb when attempting to install new printer. How to fix?
Dec 20, 2009 | HP Officejet 6500 Wireless All-in-One...
Nov 11, 2009 | HP Officejet 6500 Wireless All-in-One...
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
285 people viewed this question
Seeker5211
Seeker5211
