Question about Royal 160MX Shredder
I have paper jamed in my shredder, I can't reverse or forward. How can I clear the jam?
    Genius:
  • 1,218 Answers
You may have to take it apart to clear it by hand...remove the bin, remove th screws from underneath inside the cabinet and take the cutting head off the cabinet. Turn it over and remove the screws, turn it bak over and take the top off to see the insides.
Posted on Oct 07, 2010
Does not auto shut-off anymore?
Automatic feed switch jamed with paper. reverse and forward several times may help. Otherwise turn it over and pull paper out of the bottoms to clear the switch jam.
Apr 06, 2015 | Cross Executive EPS-1501X Shredder
How do you clear a paper jam
Typically the best way to clear a paper jam in a paper shredder is to run it in reverse then forward repeating this as many times as necessary to remove the jam (sort of the same as rocking a car back & forward to get it out of a mud or snow rut). If that doesn't work then the only option is to take the shredder apart and clear it that way!
Good Luck!
Rich Lilja
Mar 16, 2015 | Office Equipment & Supplies
My shredder will run in reverse but not auto/forward. It is completely cleared of jams. Any suggestions
There should be a little leaf switch directly in the middle of where you feed in the papers to be shreadded. It could be jammed or simply bad.
Dec 16, 2014 | Shredder Office Equipment & Supplies
Dynex shredder only works in reverse
If your shredder is jamed with paper, the centre of your machine has a switch which is plastic. If there is paper under this switch it will prevent it from being pushed downward, it will not shred paper, it will only work in reverse. Unplug your machine and clear the paper jam so the little plastic switch will be able to go down and it should work. Hope this works for you.
Sep 23, 2014 | Dynex - 10-Sheet Crosscut Paper Shredder
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Paper has wrapped around the cutting blades and is packed in tight. How do I clean this?
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse. Pull on the jammed pieces as the shredder shifts between directions.
    • 3 Run the shredder in reverse continuously once the paper jam is cleared. Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Office Equipment & Supplies
The shredder was paper jammed
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds.
Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled.
Follow instructions to oil your shredder;
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three time.
Regards.
Apr 20, 2011 | Geha Primo 1400 Shredder
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
Shredder works but when I got it jammed I switch to reverse and cleared paper, now it only goes in reverse and cannot get it to go forward and shred again. Both positions on the switch only go forward
Try cleaning the "eyes" in the middle where you put the paper in...they may be dusty/dirty....if that dosnt fix it you may have pooched the pcb inside...contact Royal at 1-800-524-0799 for Parts assistance.
Nov 17, 2010 | Royal 15MX Shredder
I have a large amount of paper jamed in the shredder. Nothing will force it out. Can I take the shredder apart to get the paper out.
You would be better to use a can of WD40 to soak the paper to soften it then try a reverse drive
Stripping down the machine is an option however you are still faced with getting the paper residue out of the cutters
WD40 or any of the oil based sprays will give you a better chance of clearing the jam
Jan 24, 2010 | Aurora Electronics AS662C Shredder
Royal 160MX Shredder Logo
444 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
