Question about Exercise & Fitness
I OWNER A PRO-FORM PERSONAL TRAINER TREADMILL. IT JUST STOPPED ON ME. I TOOK THE COVER OFF AND THE MOTOR WAS VERY HOT. MY DIGITAL DISPLAY ALSO WENT OFF AS WELL. I UNPLUGGED THE TREADMILL AND LET IT COOL OFF FOR A FEW HOUR. NOW THE MOTOR COMES ON(HIGH) AS SOON AS I CUT THE POWER ON (WITHOUT THE KEY IN THE TREADMILL). WHEN I INSERT THE KEY INTO THE TREADMILL MY DIGITAL DISPLAY LIGHTS UP BUT E2 IS DISPLAYED WHERE MY SPEED SHOULD BE READ.
mattofilms
  • 110 Answers
SOURCE: Looking for a copy of the owner's manual for the Pro-form XP542E
Yes pdf file is free to view / download.
http://www.iconservice.com/cgi-bin/ncommerce3/ExecMacro/proform/manuals.d2w/report?lan=DUTCH&match=exact&name=295253
Posted on Jul 03, 2009
SOURCE: I have a Sears Pro Form 730si. The treadmill
I believe E4 on ths 730si means that the speed of the motor the sensor is detecting is greater than the set speed. E2 would be the opposite. I believe there is a way to calibrate the speed. Look at the smaller motor controller board.
Posted on Aug 21, 2009
SOURCE: E2 error codes shows on my Pro Form 730 si treadmill
Did you find a solution for this issue? I have a similar situation
Posted on Oct 14, 2009
maxtreadmill
  • 832 Answers
SOURCE: describe how to unfold a treadmill, pro form ex
Hold the upper end of the treadmill with your right hand on the back end of the unit. Using your left hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock knob. Note: You may need to push the handrail to the side slightly. 2. Move in front of the back end and hold the treadmill firmly with both hands, and lower the treadmill to the floor. CAUTION: To decrease the possibility of injury, bend your legs and keep your back straight
Posted on May 31, 2010
maxtreadmill
  • 832 Answers
SOURCE: E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Posted on Jun 27, 2010
My landice L7 pro Trainer is not working when you press the start button the motor jolts a little the L5 shows is the display screen
It needs a lower board, does your machine have a life time warranty? Part should be covered just not the labor.
Apr 02, 2015 | Landice Exercise & Fitness
Tt30 is stuck at 3% incline and will not speed up or slow down. It also beeps continually and displays SB for about 5 seconds when first turned on. I tried the recalibration procedure and it does not...
please RUN the software calibration for easy diagnostic and fix it.
go to HOOD cover motor, and follow the steps, or ready your owner manual
God bless you
Oct 15, 2013 | FreeMotion Tt30 Incline Trainer
How to test motor bearings on pro form 550s treadmill?
please see my personal TIPS and fix it. However see the video .God bless you
Nov 26, 2012 | Treadmill Doctor Proform 5.2 Treadmill...
Treadmill pro-form 705 not starting
All that I can think of is to check that the motor is getting power.
Sep 19, 2012 | Proform Pro - Form Treadmill 705 CST
Error L5
Dear Sir:
This error appear when the elevation motor is not working.
You must Run the software calibration for easy diagnose and troubleshooting.
If you can not run the s. calibration see my personal TIPS. for trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Mar 08, 2012 | Landice L 9 Club Pro Sports Trainer...
I hae a Pro Form 540 Iteracive Trainer treadmill. When the key is inserted, the treadmill cuts on but the control panel doesn't seem to work when you touch start. I waited and cut it off and went...
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful."
Aug 08, 2011 | Sport & Outdoor - Others
Pro form 835qt stops working after a few min. Took off cover and it smells very hot in the control section. What looks like a transformer seems to be putting out the most heat. any ideas?
that part is on the incline motor if that is hot and you are not inclining then something is wrong with the incline motor or the controller board
Mar 10, 2011 | Proform Exercise & Fitness
Motor has stopped - probably due to buildup of pet hair and dust unit still getting electrical feed because control panel still works is there a reset button?
1 step
clean motor area
2 check motor brushes
3check fuses on motor controller
there is no reset button
if console reads SP5 it is speed sensor -brush or motor controller check one by one
if you are in nyc area call 347 515 8670
Nov 20, 2010 | Landice Pro Sport Trainer Treadmill
Pro Form C525. Then incline motor works with a
The repair for this is usually a new elevation motor. However if elevation isn't a big issue for for you, you can disconnect the elevation motor and use treadmill like that. The elevation motor doesn't go out that often. You should check with a local repair person. They may have a used one laying around. I usually keep one on hand to test with.
Nov 17, 2009 | Proform Exercise & Fitness
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
