Question about Schlage ND96PDEU-OME ND96EUOME612 Satin Bronze D Levers-Series Omega Omega
How do I remove a door knob when there are no visible screws
  • 4,348 Answers
There are several types of methods used, look for anything like a small wire, or the like and push it, and release. Also the round plate releases and you can see screws and retainers, on the inside side of the lock,
Posted on Oct 01, 2010
How can I tighten a kwickset door knob with no visible screws?
There is a screw - there are two sides to every knob!
Aug 26, 2017 | Hardware & Accessories
How do I remove this doorknob? It has no visible screws, and no tabs or set screws to remove the knob itself.
Look for a pin or slot on the side for an insert to pop the cover hiding the screws.
Mar 31, 2015 | Locks & Locksmithing
How do I change a cifial door knob and dead bolt that has no visible screws
The screws are most likely under a decorative cap. look at the edges of the lock you should see a small indentation], if you find one use a flat blade screw driver to pop it off. Screws will be under cap.
Aug 10, 2014 | Cifial Techno Knob Techno 622.100.620 -...
Remove stuck screw
If the screw head is stripped you will have to replace the knob and screw. Try holding the screw head and turn the handle is its a single knob. Otherwise use a hacksaw or dremel tool and cut about 3/8" away from the door surface, once you cut through you can use a small punch to push the screw through the door then pliers to pull it out. Alternately you could use a dremel tool and carefully grind the head of the screw down until you can brake the head off and pull the handle and screw out through the front.
Jun 19, 2014 | Top Knobs Hardware & Accessories
How to remove gatehouse door knob?
Look for a small set screw on the side of the deadbolt on the inside of the door loosen the set scrww and remove the cover to expose the screws that hold the door knob on
Oct 31, 2013 | Gatehouse Springfield Satin Nickel...
If I do not have the key, How do I remove the exterior door know on an emtek lock. I was able to remove the inside door knob with a set screw. I have a rectangular plate on the inside with no visible...
There should be a pin set on the outer knob as well. if not the inner knob after it has been removed should thread off, you may need to turn opposite thread.
Oct 02, 2010 | Top Knobs M826 Door Pull
How do I remove the doorknob from a weiser passage set? Want to paint door and remove passage set. Can't seem to find any slot to remove doorknob.
Door knobs have an escutcheon plate (The round part that touches the door ) that covers the screws attaching the knob together.
To get the knob off first look along the shaft of the knob ( The straight part between where you grab the knob and the escutcheon) there should either be a allen head screw or just a metal button. If its a button push in on it while you pull the knob away from the door or if its a screw just unscrew it either way the knob will come off.
Now look at the edge of the escutcheon where it touches the door. On some models there's a little detent or hole where you can put a small flat head screwdriver in to pop the escutcheon loose from the plate. If there is no detent or hole then it may be screwed on. Just grab the escutcheon and turn to the left.
Once you get the escutcheon off you'll be able to see the screws that attach the door hardware together. Just make sure to pay attention to how you took it apart so it goes back the same way.
Hope that helps !
Nov 03, 2009 | Hardware & Accessories
Door lock is loose
Inside plate arond the base of the knob needs to pop off.
Try removing the knob from the inside. Look for a place the push in with a flat head screwdriver. A release point is there some where.
After the knob is off the plate should come off and reveal the screws.
Mar 30, 2009 | Kwikset Professional Door Lock...
Changing doors would like to know how to take off kwikset door
remove the two screws on each side of the door knob from the inside of the door use medium size phillips head screw driver
pull the door handle off
remove the handle from exterior door side
remove two phillips screws from the side door that hold the door bolt pull the door bolt assembly out
reinstall on new door
insert bolt assembly
insert knob for exterior side(a lign it up
insert knob from interior side and align screws and tighten ligtly
check door for easy turning of knob and actuating latch
good luck
remove that assembly
take screw driver and remove the two scres that remove the plate on the side of the door and
Dec 29, 2008 | Kwikset Professional Door Lock...
Schlage ND96PDEU-OME  ND96EUOME612 Satin Bronze D Levers-Series Omega Omega Logo
356 people viewed this question
Top Schlage Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Schlage Electrical Supply Expert? Answer questions, earn points and help others
