Question about Samsung SGH-X200 Cellular Phone
I want to restore it - Samsung SGH-X200 Cellular Phone
Reset to factory defaults
go to windows help & type restore to factory defaults; here is what I found.
Restore system files and settings
System Restore helps you restore your computer's system files to an earlier point in time. Typically, you want to restore your computer to a restore point that was created just before the date and time when you started noticing problems. The descriptions of the restore points that are created automatically correspond with the name of an event, such as Windows Update installing an update. System Restore returns your computer to the state that it was in before the restore point that you choose. To learn more about how System Restore works, see What is System Restore?
To restore system files and settings using a recommended restore point
  1. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. Click Recommended restore, and then click Next.
    If there isn't a recommended restore point, follow the steps below to choose a specific restore point.
  3. Review the restore point, and then click Finish.
To restore system files and settings using a specific restore point
  1. Do one of the following:
    • If there is a recommended restore point, click Choose a different restore point, and then click Next.
    • If there isn't a recommended restore point, click Next.
  2. Click the restore point that you want, and then click Next.
    To view the programs and drivers that will be affected (which could include programs that will be deleted), click Scan for affected programs.
  3. Review the resto
Mar 16, 2015 | Computers & Internet
Tip
WINDOWS XP SYSTEM RESTORE
System Restore is a tool that takes your computer back to a previously working state. This option is available in Windows ME, Windows XP and Windows Vista. Windows takes snapshots of critical system files, program files and registry settings and stores them as "Restore Points". If ever you should have any problem with your computer, you can "restore" your computer to one of these Restore Points, when your computer was working fine.
Please remember - System restore does NOT have any effect on your personal files such as emails, documents or photographs.
HOW TO USE SYSTEM RESTORE TO RESTORE WINDOWS XP TO A PREVIOUSLY WORKING STATE
In order to perform a System Restore, you must have administrative rights in your computer. If this is your own personal computer, then chances are that you will be having administrative rights in it, however if you are on a network computer, say for example in a computer at your workplace, then you will have to request your Network Administrator to help you.
In order to restore Windows to a previously working "Restore Point" follow the steps given below:
1. Log on to Windows with administrative rights.
2. Click Start, go to All Programs, go to Accessories, go to System Tools, and then click System Restore. System Restore starts.
3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
4. On the Select a Restore Point page, click the most recent system restore point and then click Next.
Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
6. Log on back to your computer. The System Restore Restoration Complete page is displayed.
7. Click OK.
If you have successfully restored your computer to a previous state, and the computer is performing as it should be, you can stop here.
But if the restore process completed successfully and the computer is still not performing as you want, you can either restore your computer to a different restore point or just undo the current System Restore. In order to undo a System Restore, please continue reading.
HOW TO RUN SYSTEM RESTORE FROM THE COMMAND PROMPT?
Many times, you may not be able to run System Restore because your computer will not start up normally. But you can still run System Restore from the command prompt.
  • Click on Start -> Run -> and type in %systemrestore%\system32\restore\rstrui.exe and click OK
OR
  1. Start up the computer in Safe Mode or Safe Mode with Command Prompt
  2. At the Command Prompt type %systemrestore%\system32\restore\rstrui.exe
  3. You can replace %systemrestore% with C:\Windows, if you like
  4. You might have to select the Operating System in your computer
  5. You might also have to enter your username and password
  6. You should have Administrator Rights in your computer to do this.
HOW TO UNDO A SYSTEM RESTORE:
You may have unintentionally restored Windows XP to a previous configuration that you do not want. To undo the restoration, follow these steps:
3. On the Welcome to System Restore page, click Undo my last restoration, and then click Next.
4. On the Confirm Restoration Undo page, click Next. System Restore restores the original Windows XP configuration, and then restarts the computer.
5. Logon to the computer as Administrator. The System Restore Undo Complete page appears.
6. Click OK.
You can now run System Restore again from a Different Restore Point.
on Jul 06, 2010 | Computers & Internet
Tip
System Restore
Use System Restore to Undo Changes if Problems Occur
Windows XP Professional makes it easier to resolve problems if they occur in your system. You can use System Restore to remove any system changes that were made since the last time you remember your computer working correctly. System Restore does not affect your personal data files (such as Microsoft Word documents, browsing history, drawings, favorites, or e–mail) so you won’t lose changes made to these files. Windows XP creates “restore points” every day, as well as at the time of significant system events (such as when an application or driver is installed). You can also create and name your own restore points at any time. Creating a restore point can be useful any time you anticipate making changes to your computer that are risky or might make your computer unstable. If something goes wrong, you select a restore point and Windows XP undoes any system changes made since that time.
When you run System Restore, a calendar is displayed to help you find restore points. If you don't use your computer every day, some days might not have any restore points. If you use your computer frequently, you might have restore points almost every day, and some days might have several restore points.
To create a Restore Point
1. Access the System Restore Wizard through Help and Support Center. (Click Start, and then click Help and Support. Click Performance and Maintenance, click Using System Restore to undo changes, and then click Run the System Restore Wizard.
2. Click Create a restore point, and then click Next.
3. In the Restore point description box, type a name to identify this restore point. System Restore automatically adds to this name the date and time that this Restore Point is created.
  • To finish creating this restore point, click Create.
  • To cancel restore point creation and return to the Welcome to System Restore screen, click Back.
  • To cancel restore point creation and exit the System Restore Wizard, click Cancel.
To view or to return to this restore point, from the Welcome to System Restore screen of the System Restore Wizard select Restore my computer to an earlier time. Then select the date when the restore point was created from the calendar in the Select a Restore Point screen. All of the restore points that were created on the selected date are listed by name in the list box to the right of the calendar.
To set advanced restore options
1. Open Backup. (Click Start, goto to All Programs, point to Accessories, point to System Tools, and then click Backup.) The Backup Utility Wizard starts by default, unless it is disabled.
2. Click the Advanced Mode button in the Backup Utility Wizard.
3. Click the Restore and Manage Media menu and select the files to restore.
4. Click the Start Restore button.
5. On the Confirm Restore dialog box, click Advanced.
6. Set the advanced restore options you want, and then click OK. See the Notes section for a description of each option.
on Dec 01, 2009 | Computers & Internet
Following a System Restore on my Dell Inspiron it has come up with windowsroot system 32 ntoskrnl. The computer was not supplied with the full Window's XP home edition CD, just a Dell reinstallation CD...
If you get that message every time you run system restore, that restore point is no longer any good. You need to try a different restore point on a different date. System restore is NOT meant to be a backup. You need to be running a backup of your computer if you don't want to lose your data. Hopefully you will have another restore point, possibly earlier than the one you used, which is good. If you need to reinstall windows, you will need to get a disk. You can send me a message if you need one.
Jun 13, 2010 | Dell Microsoft Windows XP Home Edition
How do i turn computer back to yesterday
If System Restore has been turned on you can restore it back to the last restore point. May not be yesterday but you can go back. Here is exactly how curtorsey of Microsoft: To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then clickSystem Restore. System Restore starts.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
May 25, 2010 | Computers & Internet
Need to restore computer
if you want restore your computer then just flow the step
1 start
2 all programs
3 accessories
4 systems tools
5 restore systems
after that folow the screen your will able to restore your systems
Apr 24, 2010 | E-Machines T3265 PC Desktop
How do get to the restore options? f key? ibm m 8147-23u desktop
Dear Sir,
plz use this step for restore
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
If the restore process completed successfully but the computer is still not performing as you want, go to the "How to undo a system restoration after you perform a System Restore" section. If you received an error message and the restore process did not finish, or if you cannot run System Restore, go to the "Next Steps" section
Apr 16, 2010 | IBM ThinkCentre A50 PC Desktop
How do I restore my program for santa cruise? i have no sound.
Dear sir,
  7. Click OK.
Mar 31, 2010 | Dell Dimension 3100 PC Desktop
"restart the computer"
This time after you uninstall the norton antivirus, it's been corrupted your VGA Drivers & etc., I don't know what else have been corrupted after you uninstall.
All you have to do is restore the system or system restore.
If you enter at Windows Safe Mode the restore using checkpoints on your system.
If not then reformat you windows.
Here are the tips on how to use system restore.
Using System Restore To start System Restore, click Start, Programs, Accessories, System Tools, System Restore. You'll see options allowing you to create restore points and restore your computer to a previous time. If you've already performed a restoration, you'll see a third option to undo the last restoration.
system_restore_welcome_thumb.jpg To create a restore point:
  1. Choose Create a Restore Point and click Next.
  2. Type a descriptive name for the restore point in the Restore Point Description (the date and time will be added automatically) and click Next.
  3. Click OK.
create_restore_point_thumb.jpg To restore your computer:
  1. Start System Restore, choose Restore My Computer To An Earlier Time, and click Next.
  2. In the calendar, choose a day (those with restore points are bolded) and select a restore point, then click Next.
  3. Make sure your files and programs are closed and click OK, then Next.
  4. Wait while the restoration takes place. You'll need to reboot your computer. If you encounter problems after rebooting, reboot once more.
If you find you need to undo a restoration:
  1. Start System Restore.
  2. Select Undo My Last Restoration.
  3. Close any open files or programs and click Next.
Hope this will you and good luck!
If i am helpful please rate me.
Thank you.
Yboyandrei
Aug 15, 2009 | Symantec Norton AntiVirus 2009 - 3 User...
HOW DO I DO A system restore from within windows
Click on Start/Accessories/SystemTools/SystemRestore Once there, you'll be prompted to Create a Restore Point or Restore to an earlier point in time. Select Restore to an earlier point in time and you will see a calendar. Click on the date you would like to restore to and click Continue. It's important to leave the machine alone while it performs the restore action. Once done, it will automatically reboot. After rebooting, you will get 1 of 2 messages:
  1. Your system have successfully been restored or
  2. System restore was unable to restore your computer, no changes were made to your system
Hope this answers your question. All the best!
Greg
Jun 06, 2009 | Microsoft Windows XP Professional SP2
Samsung SGH-X200 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
