Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
The tractor turn off when the clutch pedal is out
    Scholar:
  • 150 Answers
Check the safety switch on clutch, you can use an ohm meter or using jumpers by pass the switch.
Posted on Oct 01, 2010
1993 Ford 6610 S Tractor clutch problem.
if hydraulic system to work the clutch
bypass internally of master or slave or
system leaking
if a rod adjustment check free play of clutch fork
and pedal height
two types of clutch std or PTO dual clutch
dual clutches do have a higher failure rate
Jul 04, 2016 | Ford Cars & Trucks
Why can't clutch pedal be depressed?
clutch pedal is only to tighten a belt look under the mower and U might see what came loose
Mar 02, 2016 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Clutch pedal sticks while in f/r.
brand/model number please... either a spring issue or a variable speed pulley issue
Aug 31, 2014 | Garden
John deere l130 clutch pedal suddenly froze in off position.Mower will not move
check your linkage to see if a lock pin fell out.
Apr 22, 2014 | Garden
Need to reduce the tension the manual clutch pedal requires
To reduce the pressure on the pedal would mean reducing the spring tention on the clutch idler pulley, this in turn would probably allow the belt to slip and reduce drive, i have seen a long bar welded onto a clutch pedal so as it could be used by hand.
Apr 14, 2013 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Husqvarna YTH2348 when clutch pedal is released, something grinds below and makes a lot of noise, but tractor does move.
Not sure what is going on here, these machines do not have a clutch as such, it will be a idler pulley that is pulled onto the back of the belt to tention it thus taking the drive to the hydro unit, so it may be a simple idler pulley replacment, or slave pulley replacement, with the hydro in neutral have somebody sit in the seat and work the pedal whilst you look under neath and watch what is happening.
Jul 26, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I paid for an answer and have not received one order # 318683 John Deere 110 tractor 1972. tractor started quitting under load but would start then run fine. Tractor quit while mowing and I found 2...
There should be a switch in the clutch pedal area. Usually safety starts for tractors is that your clutch needs to be depressed to start engine and you need to be seated to turn blades. Good Luck....
Aug 31, 2011 | John Deere Garden
I went to go mow the lawn for the first time this season. Tractor started right up. took the deck cleaned and greased it. Went to engage the p.t.o. for the mower and the tractor stalled. Can't figure...
Hi and welcome to FixYa, I am Kelly.
The power sequence for engaging the blade deck is. Clutch brake pedal depressed, operator in seat, Enage selected and brake pedal released. When the blade enages the engine igniton kill wire is routed through the seat switch AND the PTO clutch. If either the PTO Clutch or the seat switch has a problem the engine dies. Same goes for the clutch brake pedal switch... if the clutch brake is not coming all the way up the engine will die.
If you respond with a model number (example LX2000) I can show via a manual where you need to troubleshoot using a meter.
Do a couple of good bounces on the seat, check the clutch brake pedal switch for clicks and then attempt to an engagement.
Also inspect the PTO clutch wires and connectors for corrosion.
Thanks for choosing FixYa,
Kelly
Apr 23, 2011 | Garden
My craftsman 17hp lawn tractor shutters bad when releasing the clutch pedal. is it the clutch and where is it located?
Its not really a clutch, clutch/brake pedal when pressed will release belt pressure which stops pulley from turn axle. When predded all the way down it mechanically applies brakes. The vibration is from a bad pully that the drive belt rides on or a bad belt. Look for chucks of belt missing.With engine off put on parking brake and manually wiggle each pulley that drive belt rides on to see if there is any play. No play should be present. Good luck.
Mar 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
27 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
