Question about Honda 2500 PSI Gas Pressure Washer
What weight oil does the honda 5.5 engine require?
  • 183 Answers
Your Honda 5.5 hp engine specifically calls for SAE 5W30 engine oil. Use a good quality oil in the engine, and change it every 50 hours of run time. The pump will take 30weight non-detergent oil.
Using non-detergent oil in the engine will probably void your warranty, and will certainly shorten the life of the engine. Non-detergent oils have not been recommend by engine manufacturers in nearly 20 years.
Oil is cheap, go ahead and spend $4 - 5 on a quart of high quality oil. Your engine uses about 20 ounces per change.
Posted on Oct 21, 2010
    President:
  • Honda Master
  • 1,383 Answers
For non severe climates use 30w non detergent oil. I have also been using the same oil in the pump just to keep things simple. In very cold climates I would use multy viscosity to facilitate starting the engine. It does not get very cold in Texas, however during the winter if I do not store my washer indoors, starting is difficult with 30w.
Posted on Oct 01, 2010
2 Suggested Answers
  • 1015 Answers
SOURCE: what weight oil do i use in a 5 hp honda ?
For normal use I would use straight thirty weight. For colder use I would change to 10W-30.Thank you. I hope this is what you needed.
Posted on Jan 20, 2011
1991 Honda CR 250 what oil weight is reccomended
Engine/gear oil is either 10w40 or you can use light gear oil.if your talking about fork oil it's 5 weight .
Mar 14, 2015 | Honda CR 250 R Motorcycles
What kind of lube goes in gear box on a 2005 honda cr85r
If you have a 2 stroke engine this requires SAE 80W/85W gearbox oil about .55 liters. If yours is a 4 stroker then 10W40 lubes the whole engine and gearbox. You can get a user manual online easily for this bike at owners.honda.com
Sep 13, 2014 | Motorcycles
1995 Honda CB 750 Nighthawk overheating
Hi, Anonymous and the usual suspects are:
1. Engine oil level and SAE weight are too low or not circulating.
2. Insufficient or blocked air flow over the engine.
3. Heavy combustion chamber carbon deposits.
4. Ignition timing retarded due to faulty MAP, CKP, or CMP sensor.
5. Carburetor jetted too lean.
6. Leaking intake or exhaust valve.
7. Water coolant old or low change every two years.
8. Water pump failure.
9. Radiator clogged, cap loose or malfunctioning.
10. Radiator fans not coming on.
11. Clutch slipping, brakes dragging, heavy load, towing a trailer etc.
12. Idling too long without moving.
13. For constant hot weather temperatures, mountain, or desert riding conditions consider adding an oil cooler and or cylinder head cooler.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
SOHC 750 How to judge for overheating
https://www.pnwriders.com/threads/honda-nighthawk-750-opinion-required.176690
Honda CB750F2 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB750F2 Owner Manual
Jul 24, 2014 | 1995 Honda CB 750 Nighthawk
Type and weight of engine oil required
a good high mileage 10w30 is a safe bet, depending on average climate where your located. oil viscosity, or thickness, should change with the seasons
Feb 04, 2011 | 1991 Honda Accord
I have 2003 Honda CR-V with 118 k , changed motor oil , ravenol 5w40 what is the changing interval for oil
First off you are using an incorrect weight oil in your Honda. Your Honda requires 5W20 and not 5W40 which is way too heavy. Change the oil and filter every 5,000 miles and use the correct weight and a quality filter such as Bosch, Purolator, or Wix.
Jul 26, 2010 | 2003 Honda CR-V
What weight viscosity transmission oil?
You actually mean engine oil, the transmission is not separate from the engine.
10w40
Jun 05, 2010 | 1993 Honda CB 250 Nighthawk
WHAT OIL IT NEEDS MY 2000 VW BEETLE 2.0 L WITH 140000 MILES
I found 2 listings for the 2.0L engine, A and B. The 'A' had no info on oil type, the 'B' stated all temperature ranges require type 'SJ' and 5/30 or 5/40 weight. Because the mileage is 140k, I am wondering how often you must add oil between changes. If you add none, or under a quart, 5/30 is ok, if you must add oil more often, use the heavier weight, 5/40.
Nov 09, 2009 | 2000 Volkswagen Beetle
What oil do i use
synthetic 30 weight is the proper oil
Dec 25, 2008 | 2005 Honda CRF 450 R
Honda 2500 PSI Gas Pressure Washer Logo
3,490 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
