Question about Baumatic B187 Stainless Steel Electric Single Oven
I have recently have had installed a Homeking (Baumatic Group) 60cm Fan oven HOF600SS Into a tall housing unit. My problem is that every time the oven is used condensation droplets form at the bottom of the door and drop into the pan drawer below. I cant get any joy from the installers. Can you please advise solution. Regards Ceri
SOURCE: baumatic 1870ss steel electric oven
sounds like your element is not wired in properly or its faulty get someone to look at it
Posted on Dec 13, 2007
barkencoa
  • 3463 Answers
SOURCE: fan oven not heating up
If fan is working then the element has probably gone
Posted on Nov 30, 2008
barkencoa
  • 3463 Answers
SOURCE: Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Posted on Jan 24, 2009
SOURCE: Baumatic B147SS oven was giving no heat, fan and
might sound silly but have you set the clock. as the oven wont work otherwise.
Posted on Dec 22, 2009
barkencoa
  • 3463 Answers
SOURCE: My Baumatic B180W-B oven does not heat up. The
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
Posted on Feb 21, 2010
BO6255SS - The clock turns on but we are unable to set it and therefore cannot turn it on. Can you help?
this is as much as the manual says
After your appliance is connected to your mains supply for the
first time, the numbers on the timer display will flash. Before
you can select a cooking function or set a temperature, you
must set the appliance into manual operation mode.
o To select manual operation mode, press the manual operation
button (9) on the control panel.
http://www.manualslib.com/manual/956107/Baumatic-Bo625ss.html?page=3#manual
Jun 02, 2016 | Baumatic Ovens
Baumatic OSF60OVEN 60cm fan oven. Grill works, fan works, light works but oven is not heating up. Is it likely to be something I can fix myself?
You possibly have a blown heating coil, the most likely one is in the main oven, as this is the one that's used the most sometimes you can tell as the element shows signs of blowing other time it doesn't the only way to check this is to remove it and put a test lead to either end on connection clips to see if it's dead also on the element it's self to see if it's gone to earth, but must be removed or disconnected on the end terminals so you don't get a false reading. if you are a handy type person there is no reason wye you can't undertake this work just make sure the electricity is disconnected from the oven prior to any work being undertaken Good luck
Mar 02, 2015 | Baumatic Ovens
Homeking oven hof605ss
Try turning off the circuit for a minute, then set timer again.
Often a little picture/icon of a "baking tray with heat" when timer is passing power on to the thermostat.
Also, those timers fail often enough, is the oven brand new (or recent blackout)?
Oct 17, 2013 | Ovens
Homeking zeros are flashing and oven not working
the power in your house unplug your oven then plug back in.
Oct 16, 2012 | Kenmore Ovens
No manual
The light bulb is the oven light.
The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
The big circle with a fan is the Fan forced Oven
The small line at top only is the Grill Mode
The larger line at top only is the Double Grill Mode
The line up top with the fan underneath is Double Grill with Fan mode
The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
Nov 11, 2008 | Baumatic B187 Stainless Steel Electric...
Fitting this cooker into an under bench unit
Yes
Should be no problem as long as you have some kind of vetilation.
Jul 27, 2008 | Baumatic B904SS Stainless Steel Electric...
Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Sep 18, 2007 | Ovens
Baumatic B187 Stainless Steel Electric Single Oven Logo
87 people viewed this question
Top Baumatic Ovens Experts
ashburton
Dennis Boxerman
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
