Question about Dishwashers
The washer is leaking when draining begins. this occurs during the last cycle
  • 4,336 Answers
Well, this can be from anywhere. The proceedure is to remove the bottom panel and determine exactly where the water is dripping from, then extract the machine and investigate that area. It is odd, however that ONLY the last drain cycle produces the issue, I would expect leaking on every drain cycle.
Posted on Oct 01, 2010
Why does it leak all over floor after last spin cycle?
my washing machine leaks water onto the floor during each spin ...
https://answers.yahoo.com/question/index?qid...
Feb 3, 2010 - During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. ... It happened to us due to over loading. ...something can get betwen the two tubs it this all fails your tub seal is ...
Sep 30, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Frigidarie Stackable Washer and Dryer leak
Check the Drain Tube, Check the Screen. When it gets to the FIRST Spin Cycle, Check the Water Level inside the Drum and see if it is Completely Draining... There is a Water Level Switch that should not be allowing it to Overflow so you may have an issue there... But first check for a Blockage
Aug 07, 2014 | Frigidaire FEX831CS Top Load Stacked...
Supra washer/dryer combo leaking significantly
In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Mar 20, 2013 | Supra SW5L65D Front Load Washer / Dryer
Admiral washer begins leaking water from the bottom during the spin cycle
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
Jan 23, 2013 | Admiral AW22 Top Load Washer
Leaking
Jan 16, 2013 | Washing Machines
Leak onto floor...ran rinse and regulr cycle to locate leak...checked undersink connections. no apparent leak with testing.
if your leak occurs during the spin cycle than it is a plastic container-like component located at the bottom aft portion of your washer. Just follow your drain hose down to the bottom and you will see it. Part produces a "venturi" like affect to blast the drain water on out into the drain hose. The plastic gets old and it splits, you may not even be able to see the split until it is under pressure.
Jan 07, 2010 | Dishwashers
GE Frontloader - will spin @ beginning of cycle, but never again
Check the switch on the door where clothes are loaded. I may be failing intermittently.
May 23, 2009 | GE WSXH208A Front Load Washer
Amana Top Load Washer model# LW3502W Washer leaks water somewhere between wash & rinse cycle best I can tell...drain hose checks out fine. At beginning of wash cycle the first minute or two of agitation...
Sounds like the water seal is damaged and the leaking water has damaged the top bearing which is just below the water seal. You will need to have the hub & seal kit replaced.
Oct 30, 2007 | Amana ALW480DA Top Load Washer
Dishwashers Logo
73 people viewed this question
Top Dishwashers Experts
Owen Barnes
